oVerRateD Posted January 4, 2011 Report Share Posted January 4, 2011 The compass is a button. It changes map mode. Thank you. Quote Link to post Share on other sites
LonestarROB Posted January 4, 2011 Report Share Posted January 4, 2011 I will look it over again but you seem to have issues that nobody else is having based on how your system is wired. Maybe his system is wired the same way. I was unaware these systems were wired in different ways. Care to fill me in? Mines just wired like a standard install, with the ebrake wire moved. Quote Link to post Share on other sites
diaftia Posted January 4, 2011 Author Report Share Posted January 4, 2011 Here is the original SYS.TXT - when you buy Avic ...sys.txt I wanted the sys.txt that you are running. Is this it? This says that the language and voice types are UK english: [local] voice_key="Eng_uk_f1" default_language="english GB" Is this what you run? Quote Link to post Share on other sites
diaftia Posted January 4, 2011 Author Report Share Posted January 4, 2011 I was unaware these systems were wired in different ways. Care to fill me in? Mines just wired like a standard install, with the ebrake wire moved. You are also supposed to reposition a wire in the harness and then take that repositioned wire and ground it with the parking brake wire: http://avic411.com/index.php?/topic/17288-avic-f-hardwire-bypass-for-dummies/ Quote Link to post Share on other sites
patper Posted January 4, 2011 Report Share Posted January 4, 2011 I wanted the sys.txt that you are running. Is this it? This says that the language and voice types are UK english: [local] voice_key="Eng_uk_f1" default_language="english GB" Is this what you run? Yeah, that's it ... Now I have uploaded a V3, 2, and everything cool. For V3, 1 I gave the following - sys.txt Quote Link to post Share on other sites
diaftia Posted January 4, 2011 Author Report Share Posted January 4, 2011 Yeah, that's it ... Now I have uploaded a V3, 2, and everything cool. For V3, 1 I gave the following - If you are using the english speaking defaults for the EU then you should be able to use the EU option in the install script each time no problem. Quote Link to post Share on other sites
CQ7 Posted January 4, 2011 Report Share Posted January 4, 2011 Can you also send me your sys.txt? This is my sys.txt. It says English GB for language but the system and navigation language is italian... Do you think I can install your 3.2 version and choose italian language in the setup? sys.txt Quote Link to post Share on other sites
diaftia Posted January 4, 2011 Author Report Share Posted January 4, 2011 This is my sys.txt. It says English GB for language but the system and navigation language is italian... Do you think I can install your 3.2 version and choose italian language in the setup? Interesting. It appears so. If you are not sure you can always make a backup of things (all files or just files like the sys.txt) and revert back if it doesn't work the way you want. In my next version (release 3.2.1 which is mostly install script changes) its going to make a backup of the sys.txt so people can revert back if needed. Quote Link to post Share on other sites
CQ7 Posted January 4, 2011 Report Share Posted January 4, 2011 Interesting. It appears so. If you are not sure you can always make a backup of things (all files or just files like the sys.txt) and revert back if it doesn't work the way you want. In my next version (release 3.2.1 which is mostly install script changes) its going to make a backup of the sys.txt so people can revert back if needed. I will try tomorrow and let you know. Thanks for your great job. Quote Link to post Share on other sites
seeker Posted January 5, 2011 Report Share Posted January 5, 2011 They *should*. I have never heard anything about them not working. Did you do a standard install or did you customize anything at all? The only thing non-standard I did was to add 3d car feature in sys.txt and data.zip. Just to be sure, I replaced them with yours, but still no luck. Any other ideas? Quote Link to post Share on other sites
diaftia Posted January 5, 2011 Author Report Share Posted January 5, 2011 The only thing non-standard I did was to add 3d car feature in sys.txt and data.zip. Just to be sure, I replaced them with yours, but still no luck. Any other ideas? Is the device type set correctly at the top? Also, can you make sure that the speedcam_enabled=1 flag is set? (both in sys.txt). Other than that you could try clearing the save files and see if that clears it up. I have seen stranger things happen. The code is working so its either a mis config in the sys.txt on my part or something 500 specific. Other than that we need to see if there is another F500 user that knows of something specific that needs to be done. I would be happy to include any changes that need to happen if that is the case. I know that IDT has an F500. You might need to start a thread if all else fails to see if people can chime in. Quote Link to post Share on other sites
69sixpackbee Posted January 5, 2011 Report Share Posted January 5, 2011 Hey, Alex, Have you incorporated the tripcomputer start delay in your current mod? I am one of the few owners of the "lemons" that this feature hardly ever worked and this particular mod made it a little better. Thanx, Bud Quote Link to post Share on other sites
diaftia Posted January 5, 2011 Author Report Share Posted January 5, 2011 Hey, Alex, Have you incorporated the tripcomputer start delay in your current mod? I am one of the few owners of the "lemons" that this feature hardly ever worked and this particular mod made it a little better. Thanx, Bud I am a Lemon owner myself and yes, its in there. Quote Link to post Share on other sites
patper Posted January 5, 2011 Report Share Posted January 5, 2011 This is my sys.txt. It says English GB for language but the system and navigation language is italian... Do you think I can install your 3.2 version and choose italian language in the setup? I got it anyway - only in Czech language .... and except for a few things that are not translated it works .... Quote Link to post Share on other sites
diaftia Posted January 5, 2011 Author Report Share Posted January 5, 2011 I got it anyway - only in Czech language .... and except for a few things that are not translated it works .... Good to hear! My next version (which I am going to release shortly) is going to let you install the mods without a sys.txt. It should make updating easy for you. Quote Link to post Share on other sites
