Condi's HACKMODE v2.2 - AUTOINSTALL! working also with F40BT, X940BT etc! [updated: 27.09.2012]
  • Replies 1.2k
Here it is
You need "files visible from testmode" (I hope that key file is there) and Ndata (part1 and part2) from that page.
Please chek files especially PRG0/ folder. I hope it should be something like ***.FLG file with zero length. For instance mode.flg or test.flg But do not delete anything yet!
They (pioneer service) should have back door! %)) Also it is possible that testmode can be started different way to get proper working one. so we need someone who will check file by file all software inside.
Hi Ralpharn and many thanks!
I've started checking the file structure and so far, from the first page, everything seems to be the same exept
the User Folder which is shown on top, here I will copy and paste from your text to show the slight difference
X940BT Folders structure:
USER (main applications are here)
NDATA (map and other files)
NDB
SD (sd slot)
SD2 (empty)
SD3 (empty)
SD4 (empty)
USB (usb conector)
USB2 (empty)
USB3 (empty)
USB4 (empty)
Under NDATA I have found
partcode.txt
release.txt
and another \ndata folder
when I go in this folder then I have 8 other pages of subfolders
00
02
03
then the other folders goes in hex
ect ect
The only .flg files I have found so far are under
user\setup\inistate\initstate.flg
user\rw\inistate\initstate.flg
Both of them with the same time stamp and are empty, 0Kb
I can see but can't copy anything, i can take pictures of everything though
just not sure how much I can upload here
Btw, does it matter if I have both testmode and hackmode condi's key file on the sd card or is it one at a time?
Thank you for your effort. NDATA forlder looks like it have same structure as X930 ones. Inside NDATA folder is 3 objects:
partcode.txt (inside the file text "CWW3225-")
release.txt (inside text: "PLU1-3-A")
and another \ndata folder with lots of folders.
BTW are you sure you have 01 folder?
My unit has there:
00, 02, 03, 04, 05, 06, 07, 08, 09, 0A, 0B, 0C, 0D, 0E, 0F, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 1A, 1B, 1C, 1D, 1E, 1F, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 2A, 2B, 2C, 2D, 2E, 2F, 30, 31, 33, 34, 35, 36, 42, 43, 44, 45, 46, 47, 48, 49,4A, 4B, 4C, 4D, 4E, (with map) and AV, BG, BT, FE, INIDATA, L3D, SDUSB, SKY, SOUND, symbol, TEL, TTSData, VBT Folders.
Hackmode.key only works if you have hackmode installed
No it will not. There is a sections in the forum for the previous X series that is full of detail however. Also be aware that most related to the previous F series also applies for your unit. Have a long read in the hacks and mods sections of the F and X series forums.
My unit has there:
my partcode.txt (inside the text is "CWW4587-'' )
my release.txt ( inside the text is "PLU-1-4-B'' )
I will upload pictures of my ndata\ndata
According to your pictures x940bt has folders:
DEMO_IMAGE
RENEWAL
in NDATA\NDATA that not present in x930bt
They don't seem to contain anything interesting, i will upload pictures.
However I did find what seems to be a filter file for USB and SD in ndata\ndata\sdusb\filter.flr , could it be as simple as debug insted of testmode...? could you compare with what you have in the X930 and what you think. I will upload picture as well
