bluesteel Posted December 30, 2011 Report Share Posted December 30, 2011 ok so last night i powered up the HU on my bench and ran a switch from the PB to ground, and i didnt move the mute wire. the screen plays as soon as the switch is on and goes off with a warning display with the switch off. So i'am i missing something here? why does the mute have to be moved? Quote Link to post Share on other sites
RonS Posted December 30, 2011 Report Share Posted December 30, 2011 OK, good test. Now put the whole thing in your front seat and try driving about 30mph for a few minutes. Switch your toggle either on or off, try watching a movie. I wish it was that simple. And to tell the truth, I have no idea how the bypass (added wire in the unused pin/socket) works. It just does. Oh, and I mention again (mainly for those who just tuned-in) that there is nothing special about the Mute wire. It is just usually not used, so it is available as an extra wire in the harness that is handy for use in the bypass pin position. Quote Link to post Share on other sites
bluesteel Posted January 1, 2012 Report Share Posted January 1, 2012 ok thanks for the help, Quote Link to post Share on other sites
jbell73 Posted February 17, 2012 Report Share Posted February 17, 2012 Also, what I did to test my bypass connection was measure the resistance from the chassis of the radio (ie: ground) to the PIN inside the plug socket on the radio (the pin that the mute wire would now be connecting to.) If I recall correctly it measured something like 20.9 K Ohms. I then plugged in my "updated" plug, and tested the resistance from the radio chassis to the mute wire that was supposed to connect to that same PIN, and found that the resistance was exactly the same (this told me there was good contact). I wiggled the wire around a bit to simulate what happens when you stuff it all inside the dashboard, and still had no problems. I've never had a problem with the bypass yet, but it was just done a week ago. Many short drives (<30 minutes), and never had any warnings aside from the default navigation warning you get when you first turn on the unit. Quote Link to post Share on other sites
