gusztim Posted January 30, 2012 Report Share Posted January 30, 2012 Hi, one more person who has an f920bt modell and was successfull with the upgrade . Thanks for you folks for the idea and the detailed descriptions and the for the hacks as well. gusztim Quote Link to post Share on other sites
gusztim Posted February 9, 2012 Report Share Posted February 9, 2012 Hi, did anyone experienced that when a phone call come in the mute won't work? This happened with me after the upgrading. I even can't change the measure of the mute. When I touch the mute doesn't happen anything, it shows nothing, I mean the 10dB, 20dB or so. Please let me know if someone else experienced the same and found solution. gusztim Quote Link to post Share on other sites
sanduciprian_24 Posted February 25, 2012 Report Share Posted February 25, 2012 You make exactly "post 16" method and all is ok for F920 BT ? I'll come back home wednesday to try this... Hello, if I have X920BT am make exacly"post 16" method could make to see european maps?,...the aps will work?, 10x&best regards! Quote Link to post Share on other sites
pirata70 Posted February 29, 2012 Report Share Posted February 29, 2012 HELP To UPDATE MY AVIC F320BT What SHOULD I LOOK For?? CNSD-210FM OKAY? Or YOU HAVE the CNSD-230FM THANKS SE CI FOSSE QUALCHE ANIMA BUONA CHE MI AIUTA !!!! GRAZIE Quote Link to post Share on other sites
rorton Posted March 3, 2012 Report Share Posted March 3, 2012 Im in a similar position with the CNSD upgrade, I got my CNSD files from usenet. I have my F9220 running v2004 now, but when i insert the SD card with the updated maps on, nothing happens. For info, i had an SD1 and SD2 folder. I have wiped my SD card, and just copied the contents of the SD1 folder (Firmware, Update and CARDINFO.cif) to the SD card, nothing else is on the card. Should there also be the content from the AVICZ110 on the SD card, or JUST these 2 folders with their contents and the CARDINFO file? Quote Link to post Share on other sites
RonS Posted March 3, 2012 Report Share Posted March 3, 2012 Are you sure you have CNSD210-FM, and not CNSD110-FM? That would explain why it doesn't update (version 2.00 < 2.004) You are correct, the 1st SD should just have the contents of SD1 in it's root. Not the SD1 folder. Otherwise keep trying. Use another 4GB card, fresh Fat32 format. BTW, the AVIC sometimes has problems with the larger capacity SD cards. Quote Link to post Share on other sites
rorton Posted March 3, 2012 Report Share Posted March 3, 2012 Yep, pretty sure its the 210. Will try a bit more and see what happens. Quote Link to post Share on other sites
rorton Posted March 3, 2012 Report Share Posted March 3, 2012 interesting how i managed to do the other update (2 - 2.4) with the SD card though, would have thought it would be OK then to do the next bit? Quote Link to post Share on other sites
elnefary Posted March 10, 2012 Report Share Posted March 10, 2012 sorry guys . i am new here . i need to ask a direct question . will this update fit in the z110?? and what is the possibility to modify maps? Quote Link to post Share on other sites
elnefary Posted March 12, 2012 Report Share Posted March 12, 2012 what will happen if I am on the f10 ( z110 ) and go directly to CNSD-210FM? without upgradin to CNSD-110FM ? will it fit? Quote Link to post Share on other sites
onnaj Posted March 16, 2012 Report Share Posted March 16, 2012 Can someone please repost the complete CNSD-110FM? The link is broken unfotunately. Quote Link to post Share on other sites
elnefary Posted March 16, 2012 Report Share Posted March 16, 2012 I downloaded the US version and install the 120FM EU version . Quote Link to post Share on other sites
russters Posted March 17, 2012 Report Share Posted March 17, 2012 I have an f20bt and cant seem to get it to update from version 2.000 to ver2.0003 or 2.0004, it does not even try to upgrade to 2.0003, just starts up as normal untill the 2.0004 version sd card is inserted and that fails after reaching 100% (approx 2 mins) I have tried several sd cards all formatted to fat32 with default allocation. bluetooth is 3.10fw but this upgrades and downgrades ok is there any other way of getting this to upgrade I would love some newer maps/apps Quote Link to post Share on other sites
shubert Posted March 18, 2012 Report Share Posted March 18, 2012 Hi everybody, Congratulations for this GREAT forum ! My system : firmware 2.000, BT 3.11 Here is my problem : I've downloaded all files, copy first firmware 2.003 on SD card (formatted with default options), with AVICZ110 folder at the root. The when I put the SD card in my F920BT, NOTHING happens. the radio keeps on, no message. When I switch from radio to SD card, it tries playing the WAV files in TESTMODE folder.... Does anyone have any idea why the update doesn't start ? Thanks, Stéphane (frenchie guy) Quote Link to post Share on other sites
RonS Posted March 18, 2012 Report Share Posted March 18, 2012 Hi everybody, Congratulations for this GREAT forum ! My system : firmware 2.000, BT 3.11 Here is my problem : I've downloaded all files, copy first firmware 2.003 on SD card (formatted with default options), with AVICZ110 folder at the root. The when I put the SD card in my F920BT, NOTHING happens. the radio keeps on, no message. When I switch from radio to SD card, it tries playing the WAV files in TESTMODE folder.... Does anyone have any idea why the update doesn't start ? Thanks, Stéphane (frenchie guy) Probably you are already running 2.003. Just skip this and install the patched 2.004 (which is just 2.003 + two files). One file adjusts the version to 2.004 - so that it can be installed over 2.003 if necessary. The other file hacks the password check for your next upgrade (CNSD210-FM). BTW, did you follow the instructions to display the hidden Application Version screen? Quote Link to post Share on other sites
Join the conversation
