adamhhmay Posted August 19, 2011 Report Share Posted August 19, 2011 First time poster, long time reader.. I just installed the 2011 map update on my AVIC-Z120BT and I am getting a System Error about the tuner, that will not go away.. The problem is that I am on a long road trip and I need the use of the nav, and the error blocks the screen I have talked to Pioneer and they informed me that the MSN Direct tuner needs to be taken out because it no longer works with the new update... I didn't install the system myself, and was wondering how hard it would be to disconnect on my own.... Any help would be very much appreciated. Thanks in advance! -Adam Quote Link to post Share on other sites
RonS Posted August 19, 2011 Report Share Posted August 19, 2011 First time poster, long time reader.. I just installed the 2011 map update on my AVIC-Z120BT and I am getting a System Error about the tuner, that will not go away.. The problem is that I am on a long road trip and I need the use of the nav, and the error blocks the screen I have talked to Pioneer and they informed me that the MSN Direct tuner needs to be taken out because it no longer works with the new update... I didn't install the system myself, and was wondering how hard it would be to disconnect on my own.... Any help would be very much appreciated. Thanks in advance! -Adam To do it the right way, you will need to get to the back of your HU. The car's antenna is daisy-chanined through the MSN Direct tuner. That is, the antenna plugs in to the MSN tuner ANT In, then another coax goes from the MSN tuner to the back of the HU. Then there is a harness that connects the MSN tuner to the HU. This also powers the MSN tuner. That will need to be disconnected from either the HU or the MSN tuner (or both). You might be able to disable the MSN tuner without removing the HU if you can reach it from under the dash. You could just unplug the harness connector. Going this route, I'm not sure if you will loose AM/FM reception. It is possible that the MSN tuner has a passive bypass of the antenna lead. If so, the antenna signal will just pass through the MSN tuner even if it has no power. So your AM/FM will still work. Even if it doesn't, this should eliminate the error that keeps you from accessing the NAV. Hope you follow what I'm saying. I think the hardest part to do on the road would be getting to the back of the units. Can't help you there. Each vehicle is different. Quote Link to post Share on other sites
Stomu Posted August 20, 2011 Report Share Posted August 20, 2011 I'm having the same exact problem. Does anyone know if I can replace the MSN Direct Tuner with CXE2176 Traffic Tuner? Shouldn't be just a matter of swapping one out for the other? Thanks in advance for any help you can provide. Quote Link to post Share on other sites
garrettoomey Posted August 20, 2011 Report Share Posted August 20, 2011 I'm having the same exact problem. Does anyone know if I can replace the MSN Direct Tuner with CXE2176 Traffic Tuner? Shouldn't be just a matter of swapping one out for the other? Thanks in advance for any help you can provide. You will need traffic tuner ND-TMC10. Quote Link to post Share on other sites
Stomu Posted August 20, 2011 Report Share Posted August 20, 2011 You will need traffic tuner ND-TMC10. So your saying that the CXE2176 Traffic Tuner will not work with my updated Avic-120bt (using the most recent update that Pioneer that was just released)? I spoke with the folks at Pioneer and this is the one they told me I would need. Does anyone know anything about the CXE 2176 Traffic Tuner? Quote Link to post Share on other sites
RonS Posted August 20, 2011 Report Share Posted August 20, 2011 So your saying that the CXE2176 Traffic Tuner will not work with my updated Avic-120bt (using the most recent update that Pioneer that was just released)? I spoke with the folks at Pioneer and this is the one they told me I would need. Does anyone know anything about the CXE 2176 Traffic Tuner? Most of the hits when googling "CXE 2176" are from EU sites. It might be for the EU RDS traffic broadcast. Are you in Europe? Quote Link to post Share on other sites
Stomu Posted August 20, 2011 Report Share Posted August 20, 2011 No I'm not. I live in the states. Well I guess I'll find out soon if it works. Thanks for responding. Quote Link to post Share on other sites
RonS Posted August 20, 2011 Report Share Posted August 20, 2011 No I'm not. I live in the states. Well I guess I'll find out soon if it works. Thanks for responding. Where did you buy it from? It's not on the Pioneer USA site. Quote Link to post Share on other sites
Stomu Posted August 21, 2011 Report Share Posted August 21, 2011 http://parts.pioneerelectronics.com/part.asp?productNum=CXE2176 It looks like part is from the American parts shop. It says the part is for the AVIC-130bt. Which is what I've upgraded my avic-120bt too with the most recent upgrade. Let me know what yout thoughts are on this. Quote Link to post Share on other sites
Stomu Posted August 22, 2011 Report Share Posted August 22, 2011 I had the cable installed today and it works great. I highly recommend the cable. Quote Link to post Share on other sites
dahozzman Posted January 20, 2013 Report Share Posted January 20, 2013 So your saying that the CXE2176 Traffic Tuner will not work with my updated Avic-120bt (using the most recent update that Pioneer that was just released)? I spoke with the folks at Pioneer and this is the one they told me I would need. Does anyone know anything about the CXE 2176 Traffic Tuner? Bumping this up as I'm looking for answer to this exact question. I have a z120bt, software updated to Z130bt. Z120 Manual calls for a NC-MDT10 and I came into posession of a CXE2176. So I want to confirm I can use the CXE2176 or if I need to exchange for the NC-MDT10 before I start my installation Thanks. Quote Link to post Share on other sites
pionara Posted January 20, 2013 Report Share Posted January 20, 2013 CXE2176 = ND-TMC10 They are basically the same thing. Will work just fine if you have 2011 or 2012 software update on your Z120 Quote Link to post Share on other sites
dahozzman Posted January 20, 2013 Report Share Posted January 20, 2013 What I was hoping to hear. Thanks. Quote Link to post Share on other sites
