zetaR Posted June 10, 2013 Report Share Posted June 10, 2013 home button: the screen does not go into landscape and the touch is not working properly.I've noticed that starting safari home button function, it must be correctly in landscape. Link to post Share on other sites
holyhandwalker Posted June 10, 2013 Report Share Posted June 10, 2013 Did someone use the external GPS antenna successfully with non supported apps? I remember reading somewhere that it doesn't work but just wanted to make sure. Thanks in advance! I want to know whether this is possible too Link to post Share on other sites
holyhandwalker Posted June 10, 2013 Report Share Posted June 10, 2013 Just posted an update: Fixed the auto rotate issues. Safari seems to run in a special sandbox, so it still doesn't rotate. Updated the Pandora home button to bookmark on double tap (just keep pressing the bookmark button quickly a bunch of times). The AppRadio app is now killed when you unplug the cable. Added the Home button to the AppRadio app menu. I still don't know what's causing the resize issue. The triangles on the sides of the app is actually the ends of the AppRadio app dock across the bottom. I'm thinking it's a problem with overscan but everything I tried hasn't worked yet. Hi Mike, When I was using beta12 the screen usually resized ok with no triangles, if it didn't, closing & reopening the app would fix. With beta13, it's always small with the triangles Is there any way I can download beta12 and reinstall that? Link to post Share on other sites
mikedecaro Posted June 11, 2013 Author Report Share Posted June 11, 2013 Thanks Mike. Any more thoughts on mirroring apps like Pandora? Just pandora? or all supported apps? home button: the screen does not go into landscape and the touch is not working properly. I've noticed that starting safari home button function, it must be correctly in landscape. Safari is a know issue due to sandboxing. I'll look into the home landscape issue though. Hi Mike, When I was using beta12 the screen usually resized ok with no triangles, if it didn't, closing & reopening the app would fix. With beta13, it's always small with the triangles Is there any way I can download beta12 and reinstall that? Use the link in the first post and change the beta number. Link to post Share on other sites
mikedecaro Posted June 11, 2013 Author Report Share Posted June 11, 2013 home button: the screen does not go into landscape and the touch is not working properly. I've noticed that starting safari home button function, it must be correctly in landscape. What are you using to rotate the springboard? Link to post Share on other sites
zetaR Posted June 11, 2013 Report Share Posted June 11, 2013 What are you using to rotate the springboard? Do not use anything to rotate the spirngboard: within the home and open Safari and it automatically rotates. As I said, when I enter the home, the screen does not rotate (it would be nice that it did) and the touch is not working properly (I can not change the page). Link to post Share on other sites
zetaR Posted June 11, 2013 Report Share Posted June 11, 2013 Hi Mike, When I was using beta12 the screen usually resized ok with no triangles, if it didn't, closing & reopening the app would fix. With beta13, it's always small with the triangles Is there any way I can download beta12 and reinstall that? clicca qui: http://mikedecaro.com/repo/AppRadioExtensions_2.1.0_Beta12.deb Link to post Share on other sites
Tomfoolery82 Posted June 11, 2013 Report Share Posted June 11, 2013 https://www.dropbox.com/s/60egoyyw9m0e8zm/VID_20130531_235850.mp4 beta 13 vide of spring board Link to post Share on other sites
WRS Posted June 11, 2013 Report Share Posted June 11, 2013 Just pandora? or all supported apps? Safari is a know issue due to sandboxing. I'll look into the home landscape issue though. Use the link in the first post and change the beta number. Just Pandora for me because using the UK firmware doesn't support it. Thanks Link to post Share on other sites
Maxvr6 Posted June 11, 2013 Report Share Posted June 11, 2013 Thanks for the update Mike! Also thanks for the tweak that kills the app when power is disconnected, means I can use activator to lock the phone at the same time! Mail still doesn't rotate either, not sure if there's much demand for that but it would be nice. Link to post Share on other sites
mikedecaro Posted June 12, 2013 Author Report Share Posted June 12, 2013 Just released another update that fixed the resize/triangle issue on my device. Let me know if it works for you. Just Pandora for me because using the UK firmware doesn't support it. Thanks I'll take a look for the next beta. No promises though. https://www.dropbox.com/s/60egoyyw9m0e8zm/VID_20130531_235850.mp4 beta 13 vide of spring board I'll install SBRotator on my device and see what I can do. Should be able to fix everything related to rotation in your video. Link to post Share on other sites
zetaR Posted June 12, 2013 Report Share Posted June 12, 2013 Just released another update that fixed the resize/triangle issue on my device. Let me know if it works for you. MIKE, BETA 14 is not present in Cydia EDIT: YES NOW Link to post Share on other sites
leetut Posted June 12, 2013 Report Share Posted June 12, 2013 im new so maybe this is all normal but after updating ARextensions this morning an app called soundscape2 is "total" fullscreen, no side black bars, think i had to play music first for it to launch properly and if i start ifile from the app radio then exit using phones homebutton i get full mirroring of phone safari rotates, but i do have phone sideways and coverflow in music app is nice a video: http://www.youtube.com/watch?v=xaQ7yk5IqV8&feature=youtu.be and if soundscape2 app is fullscreen im hoping theres a plist file in my tomtom app to push that fullscreen too, dont mind if it goes letterbox format on phone as im only gonna be using it through the appradio, anyone got any ideas on that? Link to post Share on other sites
leetut Posted June 12, 2013 Report Share Posted June 12, 2013 the soundscape2 app: (it has lots of different animations on phone but seems to be stuck on on on appradio) (gonna try removing it from appradio and mirroring it instead) (cos if i try to launch it from phone while mirroring the phone launches the pioneer AR app and everything goes fubar!) http://www.youtube.com/watch?v=z7JyiEbSrCo&feature=youtu.be Link to post Share on other sites
zetaR Posted June 12, 2013 Report Share Posted June 12, 2013 "AppRadio app is killed when the cable is unplugged to help with battery drain" to me it does not work. Why? Link to post Share on other sites
