antlane Posted June 13, 2013 Report Share Posted June 13, 2013 Here are my results using the file Mike linked to on his DropBox (using an sph-DA100 + iPhone 5) Top-left: 19.180273, 5.998718 Top-right: 1270.390381, 7.492905 Bottom-left: 4.765770,698.993469 Bottom-right: 1271.991943, 698.993469 There looks to be an inconsistency between the top-left and top-right so I can do them again if necessary. My cycript output when using the AppRadio app can be found here: http://pastebin.com/aMRY4y5p And the output when using Google Maps: http://pastebin.com/GDV4TkRb Hope this helps get decent calibration! Link to post Share on other sites
hitman80 Posted June 13, 2013 Report Share Posted June 13, 2013 This is what I got using the iPhone 5, Z150bh and the test deb: Top left - 52.186649,35.992310 Top right - 704.684570,29.986267 Bottom left - 48.583027,448.988312 Bottom right - 701.981873,440.990021 Mine was VERY sensitive, touching the screen in what appeared to be the same place changed some of the numbers significantly. Of course, that could be normal, I'm no expert. If I need to retry, just let me know. Link to post Share on other sites
Tomfoolery82 Posted June 13, 2013 Report Share Posted June 13, 2013 Great work mike the resizing is fixed just tested. I had to hit the ignore button on the appradio for the app to connect to the deck. Also when i use a app like mint (not a landscape app) it shows up fine but when I close the app the springboard is vertical landscape like before. It now does fix the rotation when I first launch thank you mike. It just keeps getting better and better. Link to post Share on other sites
Tomfoolery82 Posted June 14, 2013 Report Share Posted June 14, 2013 Soundscape the black bars are still there just hidden by full screen. They still work. Also with the videos app and all buttons work they are just not on the screen just touch where the buttons should be. This was written on the app radio in landscape Link to post Share on other sites
mikedecaro Posted June 14, 2013 Author Report Share Posted June 14, 2013 Hi mike, with regards to the automatic killing of the appradio app, I use the plugged in tweak to start up the appradio app when I plug it in, however I think this part of appex kills it again, so I have to manually open it again each time. Do you think it is possible to make the appradio app killing feature an option (as this can be achieved with plugged in anyway, but can also be used to open it when plugged in). Cheers! I don't think thats part of the auto kill feature. Sounds like a bug. I'll look into it. Link to post Share on other sites
mikedecaro Posted June 14, 2013 Author Report Share Posted June 14, 2013 Can someone record a quick video of their iPhone 5 running the latest AppEx beta? I want to see where the touches register on different parts of the screen while mirroring. After that, I should have more than enough information to figure out whats wrong. Link to post Share on other sites
Tomfoolery82 Posted June 14, 2013 Report Share Posted June 14, 2013 Hey mike can you fix this https://www.dropbox.com/s/bmlvee1kblyy61l/Video%20Jun%2013%2C%2011%2013%2016%20PM.mov Link to post Share on other sites
S.A.M. Posted June 14, 2013 Report Share Posted June 14, 2013 I don't think thats part of the auto kill feature. Sounds like a bug. I'll look into it. Mine does the same thing since the last update of Extensions... Link to post Share on other sites
freedombrewer Posted June 14, 2013 Report Share Posted June 14, 2013 Hey guys, ive got a problem. if i plugin the phone to my radio and start the appradio my screen becomes black and nothing is starting. Im using: iPhone 4 JB 6.1 AppRadio 2.3.0 newest appradio extensions If i Plug the cable into my phone and press the "mode" button on my radio the screen gets black and nothing happens. do i make something wrong? Greeetings I am having the same problem with a iPhone 4 running 6.1.2 and AppRadio 2.3.0 I have also tried AppRadio 2.0.1 Link to post Share on other sites
mikedecaro Posted June 15, 2013 Author Report Share Posted June 15, 2013 Hey mike can you fix this https://www.dropbox.com/s/bmlvee1kblyy61l/Video%20Jun%2013%2C%2011%2013%2016%20PM.mov Can you try moving Mint out of a folder and see if the problem goes away? I think I know what's causing it, just trying to confirm. Mine does the same thing since the last update of Extensions... I'm working on fixing the launch issue. You can work around it for now by setting the Bypass Launch Alert setting to Accept. It should do the same thing as Activator. Link to post Share on other sites
DMZamora Posted June 15, 2013 Report Share Posted June 15, 2013 I am having the same problem with a iPhone 4 running 6.1.2 and AppRadio 2.3.0 I have also tried AppRadio 2.0.1 Same here on iPhone 4, black screen and having to launch apps directly on the phone's screen. Link to post Share on other sites
Tomfoolery82 Posted June 15, 2013 Report Share Posted June 15, 2013 Can you try moving Mint out of a folder and see if the problem goes away? I think I know what's causing it, just trying to confirm. I moved mint out of the folder it fixed the problem Link to post Share on other sites
Thady Posted June 15, 2013 Report Share Posted June 15, 2013 Hey, im gonna try it again with some more information. I tried that with ios 5 some times ago and it worked perfectly, thanks again for that. iPhone 4 iOS 6.1 JB MobileSubstrate: 0.9.4001 PreferenceLoader: 2.2.1-1 AppList: 1.5.4 AppRadio: 2.3.0 AppRadio Extensions: 2.0.1-294 Pioneer FW: HW05-SW01.27.20 Radio: AVH 8400BT I installed all of that and restartet my iPhone. If i plug my phone in now and start Appradio it doesnt show any apps. I also startet a not supported App and it doesnt work. My screen becomes black und keeps beeing black. Does anybody know why or how to fix that? Sorry for my bad english, im german Greetings Link to post Share on other sites
antlane Posted June 15, 2013 Report Share Posted June 15, 2013 Can someone record a quick video of their iPhone 5 running the latest AppEx beta? I want to see where the touches register on different parts of the screen while mirroring. After that, I should have more than enough information to figure out whats wrong. I'm unable to launch an app to be able to do this as the beta displays the touch coordinate but then doesn't do anything else. If you can fix this, I'll then make a video. Or will doing a video of a supported app be ok? Link to post Share on other sites
mikedecaro Posted June 16, 2013 Author Report Share Posted June 16, 2013 I'm unable to launch an app to be able to do this as the beta displays the touch coordinate but then doesn't do anything else. If you can fix this, I'll then make a video. Or will doing a video of a supported app be ok? You can use the beta from the first page instead of the one with the alert. Link to post Share on other sites
