Jump to content
AVIC411.com
2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
I have looked all over and I can not find a link that works to download the 2012 US/CAN update.
I have a X930bt Ver 3.0000 and I want to upgrade so my Samsung S3 will work better with it. I have even tried to buy the upgrade from NAVTEQ but they no longer offer it.
Please if anyone has the files or has a good link to download the software let me know. I am pulling my hair out here, lol
Looked all over?  The answer is on the first post of this thread.  Follow the instructions here: http://avic411.com/index.php?/topic/35230-2012-uscan-maps-cnsd-310fmuc-upgrade-updated-to-supereasymethod-beta/page-21?&do=findComment&comment=259388
Link to post
Share on other sites
  • 2 weeks later...
  • Replies 644
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
UPDATE: I have found a super easy method to install. No testmode, no hacked dlls, etc.
1. get the update and put it on an SD card (like below) so that the SD card has Cardinfo.cif, Update, Firmware folders at the top (root) level of the sd card.
2. replace the file on sd card: \Update\VERINFO.DAT with this one:
attachicon.gifVERINFO.DAT
3. if you have Z110, Z120, or X920 (not needed for Z130 or X930): Replace the Cardinfo.cif on the SD card with this one that is inside this zip:
attachicon.gifcardinfo.dat.zip
4. insert SD card into unit (make sure you have good power to your vehicle - running, battery charger, etc)... it should ask to upgrade and reboot... no password needed. Will take about 30 mins. After it has completed update it will restart and go through initial settings like voice, etc. It should reboot and you should see 2012 splash screen. After the unit reboots, it may ask you if you want to update again but choose NO (provided update went ok and you have 2012 splash screen which means it updated.)
5. update your bluetooth firmware (to 3.24) in the bluetooth settings menu
please report your success on this thread. If you have problems, make sure you note your current model and version.
update: IAmSuperBleeder posted a nice step-by-step with photos: #301
- applies to x930bt, x920, z110, z120, or z130 US/CAN models. This is for CNSD-310FM/UC- UC means US/Can. No EU updates or other regions yet. The procedure should be the same for F10,20,30 and F920, F930 as soon as there is a Euro version available.
For Euro (EU5) update here: http://avic411.com/i...eu-2012-update/
update: torrent of the full update image posted here: #204
after upgrade:
service information screen. hold top left for detailed info:
Platform version: 4.000
Application version: 4.010
Version: 4.000
Bluetooth firmware version: 3.24
if you like the new version/maps, please do yourself a favor and go pay for it.
Note: it is up to you to legally obtain the update files. I have provided an alternate method of installation that does not require a password for those folks with legally obtained software.
after upgrade:
Version: 4.000
yo can you help me?
Link to post
what if i did use 2.21? i think thats what i used. what do i do now?
v2.21 is known to screw up units bad.  It did screw up mine and I fixed it by removing the file PRG.FLG in the USER directory.
BTW, slow down on the forums.  If you ask something, don't expect a reply 30 minutes later.  Be patient.
Link to post
sorry about that. i just checked under USER directory and i dont see PRG.FLG.
Link to post
If you don't have the PRG.FLG file, create a text file, rename it PRG.FLG and copy it there.
still didnt work sir. this is what i did..
right clicked on desktop, create a text document, save as PRG.FLG then copy to my microsd. put it inside the avic and turned on the car. went to sd card, copy PRG.FLG file and paste to USER directory. turned off the car, took out the microsd. turned on the car and still on that screen.
Link to post
Hi!
In the download there is no FIRMWARE and Update folder to put on the SD card.  I assume I create the FIRMWARE and Update folders on the SD card and unzip all the files in the 2012 upgrade zip to the Update folder, but what to I put in the FIRMWARE folder?
Forgive my newbie question, I appreciate any help.
Thanks!!!
Pioneer X930BT
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
