Jump to content
AVIC411.com
2012 US/CAN Maps - CNSD-310FM/UC upgrade (updated to supereasymethod - beta)
  • Replies 644
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
  • 2 weeks later...
I just did this update tonight and worked without any issues, many thanks all for your help!  One question - what are the Mecha and CAN versions referring to?  My Mecha version is the same, and the CAN version changed from having values to --------- instead.  Is this indicative of an issue?
Link to post
Share on other sites
I believe u can go from 110 to this.
Hey guys if wanting to upgrade from an ORIGINAL z110bt with no previous updates whatsoever can I simply follow the instructions on page 1 and I will have the latest and greatest z140 software AND maps?
I  wouldn't worry so much about that
Link to post
How many files are supposed to be on the SD card? I have 240. I have the X9310bt so I do not have the cardinf file. Is 240 the correct count?
From what source?  If you're talking about the 2012 US/Canada maps, it should be 228 files (5.61gb).  Well, at least, that's what I have.
Link to post
I followed the instructions to a tee. I then discovered I have a x9310bt instead of a x930bt. I made it to %51, then the update asked for the SD card. I was stuck at the screen asking for a SD card, so I deleted the file mentioned in #20. This got my radio working but nothing else. At least I had a radio for the ride home. I extracted all the files again and tried it all from the beginning. The radio will not go into update mode now. Does someone have a copy of StartKnd.log?
#20: I think you can kick the unit out of upgrade mode by deleting \USER\SYSTEM\Download\StartKnd.log
(a value of 0 in this file means start normally. 1 means upgrade, and there is 2 and 3 - not sure what those do.) I believe if this file is missing or zero inside, it will try to start normally.
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
