FreeTime Posted October 25, 2013 Report Share Posted October 25, 2013 does anyone know where the CNSD-310FM US 2012 Pioneer maps can be found. I get no reply from the link in this thread. Quote Link to post Share on other sites
back Posted November 3, 2013 Report Share Posted November 3, 2013 Hi, i'm french sorry for my english ! I performed the update and everything works perfectly on my F10BT. But every time I reboot it asks me "begin update" how to remove this message at boot ? Quote Link to post Share on other sites
lars1977 Posted November 8, 2013 Report Share Posted November 8, 2013 is there any way to check wich map versions are being installed with the 2013 update ? I've done the update on my 920bt with succes, and my language and speech file's are still dutch, the version has changed from 2.00 to 5.00 on my unit... but somehow I have the feeling that there are old maps being installed (not 2013) version, because a lot of new build roads (from 2011 / 2012) are not on the map?? so: how can you check wich map version is currently on the device ? Quote Link to post Share on other sites
lars1977 Posted November 8, 2013 Report Share Posted November 8, 2013 Hi, i'm french sorry for my english ! I performed the update and everything works perfectly on my F10BT. But every time I reboot it asks me "begin update" how to remove this message at boot ? Have you removed the sd card where the update is installed on ? If you don't remove the sd card, or delete the update files on it, each time you start up the device, it will ask to update... Quote Link to post Share on other sites
jepd1973 Posted November 17, 2013 Report Share Posted November 17, 2013 Hi Thanks for making the upgrade available. Everthing working on my 930bt except for app radio which displays a black screen only. Any suggestions? Has this got something to do with IOS 7? Quote Link to post Share on other sites
donaldchaves Posted March 24, 2014 Report Share Posted March 24, 2014 pionara I´m very new in this forum, i am from central america(Costa Rica) and i would like to try out your upgrade on my Avic X920Bt 2.0 to 4.0 however I would like to know what are the improvements by upgrading my Unit from 2.0 to 4.0 Regards Quote Link to post Share on other sites
adyman77 Posted August 11, 2014 Report Share Posted August 11, 2014 And have you tried the sd card I recommended? And make sure you're FAT32 Formatting your SD Card using the windows utility and make sure its a Complete format Hi. I have the same problem. I tried 3 diferent cards but I havo no succes(Kingston 4Gb class4, Kingston 16Gb class10 and Kingmax 16Gb class10).What type of card do you recomended? Thanks in advance radeonrama. Quote Link to post Share on other sites
adyman77 Posted August 11, 2014 Report Share Posted August 11, 2014 Hi. I have the same problem. I tried 3 diferent cards but I havo no succes(Kingston 4Gb class4, Kingston 16Gb class10 and Kingmax 16Gb class10).What type of card do you recomended? Thanks in advance radeonrama. Sorry, not Kingmax the third one I tried, it was Hama. I see up-here a sugestion about instert an item in one folder. It is good to try this option? Quote Link to post Share on other sites
dwkrabz Posted May 9, 2017 Report Share Posted May 9, 2017 Good evening, I have a AVIC-920BT that i bricked a few years ago. I was trying to copy the boot file and i acidently pasted it over itself. When booting the unit, the screen says "Thers is no applicaton software" but the backup camera still works. I can put it into test mode and see all the files but i will need a new file to copy on to the unit. Anyone have any ideas? Quote Link to post Share on other sites
RonS Posted May 9, 2017 Report Share Posted May 9, 2017 Good evening, I have a AVIC-920BT that i bricked a few years ago. I was trying to copy the boot file and i acidently pasted it over itself. When booting the unit, the screen says "Thers is no application software" but the backup camera still works. I can put it into test mode and see all the files but i will need a new file to copy on to the unit. Anyone have any ideas? Several. What file did you clobber? Have you tried switching to the reserve program directory? Does /USER/PRG.FLG exist? If so delete it. If not create it. Have you tried installing the latest software (v6 2015 maps)? Quote Link to post Share on other sites
pasha5163 Posted May 19, 2017 Report Share Posted May 19, 2017 RonS; how can i download (v6 2015 maps)? Could you leave here a link address? Thank you. Quote Link to post Share on other sites
pasha5163 Posted May 19, 2017 Report Share Posted May 19, 2017 Several. What file did you clobber? Have you tried switching to the reserve program directory? Does /USER/PRG.FLG exist? If so delete it. If not create it. Have you tried installing the latest software (v6 2015 maps)? RonS; how can i download (v6 2015 maps)? Could you leave here a link address? Thank you. Quote Link to post Share on other sites
Join the conversation
