EdWRX Posted March 20, 2014 Report Share Posted March 20, 2014 Hello, I have a AVIC-X710BT you think this will work for it???\ The map update is what I mean. Thank you Quote Link to post Share on other sites
misterwoofwoof Posted March 21, 2014 Author Report Share Posted March 21, 2014 Hello, I have a AVIC-X710BT you think this will work for it???\ The map update is what I mean. Thank you No the AVIC-X710B uses compltly different hardware and software. Quote Link to post Share on other sites
retrohunter Posted March 21, 2014 Report Share Posted March 21, 2014 Really hate to pester you all about this but I can't find a definitive answer to the following: Can a X930BT be upgraded to run 5.1? I'd love to run AppRadio, which it seems that 5.0 can't do. Thanks again! Quote Link to post Share on other sites
csviegas Posted March 21, 2014 Report Share Posted March 21, 2014 I noticed that after the update I lost AHA radio and Pandora. They aren't on the scroll wheel anymore? OK, I thought you had installed 5.1. Aha and Pandora both should be there in 5.0. Try a hard reset (disconnect battery for ~ 30 seconds). That sometimes fixes these things. Also, if you are using a Windows or Android smartphone, be sure your App Connection is set to BT. And iPhones only work with wired connection. However, I don't think this would make the icons disappear. I had the same issue. I use the bluetooth connection with Android on my Galaxy S3. I updated my X940BT to 5.0 without the icons disappearing. When I updated to 5.1 the Pandora and Aha Radio icons disappeared. To get them to show up again, turn off any audio source currently being used, then go to settings, av settings, app connection. Change the app connection from 'ipod' to 'others'. Your icons will now show up again. If the app connection options are grayed out in the av settings screen, that means you have not turned off the audio source yet. These settings cant be changed when an audio source is in use. Since 5.1 firmware is really meant for iPhone lightning cable users, I am guessing they designed it to default to that setting. Quote Link to post Share on other sites
rock88 Posted March 21, 2014 Report Share Posted March 21, 2014 Everyone should donate something to mister woof woof , thanks Quote Link to post Share on other sites
retrohunter Posted March 21, 2014 Report Share Posted March 21, 2014 Thanks for the reminder @rock88. Just donated! Quote Link to post Share on other sites
kjchen69 Posted March 21, 2014 Report Share Posted March 21, 2014 This process requires a certain skill set and level of proficiency - I don't have the time to walk you through every keypress. I will help you understand the general process. You're going to have to dig-out the details in existing threads. Beware - there are lots of ways to screw-up. Always avoid doing something you can't undo. Make working backups of any files you need to edit/delete. I make a /BACKUP folder on my SD and move original copies into there (before deleting) just incase I screw something up. 1. Learn how to copy, paste and delete files using Testmode. There is a Youtube vid that covers many of the nuances - but the Testmode user interface is a POS. Be aware that on the video he incorrectly calls it HackMode - don't install hackmode - it's a disaster waiting to happen. To run Testmode, put the file Testmode.key in the root of an SD and insert it into the AVIC. You need to select "File Maintenence". It uses hard buttons to scroll, and select various operations. It is very error - prone so be careful. 2. Now you need to get a copy of NAVI.exe on your PC. You can get it off the HU (in /USER/PRGn/APL) or from the 5.x files you downloaded to do the upgrade. Just to be safe, copy the file somewhere to edit - best not to touch the original. 3. You need a hex editor on your PC. I used (free) HxD. Learn how to use it - practice on something first. Then use it to patch the hex bytes into NAVI.exe as pionara (v5.1) or I (v5.0) describe elsewhere. The offest is the location in the file to begin the patch - replacing the 4 hex numbers already there. 4. Copy your patched NAVI.exe to the SD where you have TestMode.key and insert in the HU - should boot you directly into Testmode. 5. The HU has two sets of application files in /USER (PRG0 and PRG1). If a file called PRG.FLG is present, you need to delete and replace NAVI.exe in /USER/PRG1/APL. Otherwise use /USER/PRG0/APL. 6. Delete NAVI.exe from the directory above. It is best to make a copy of it somewhere on the SD in a different directory than your hacked one. Note: Testmode will not overwrite a file of the same name. 7. Now copy your hacked NAVI.exe to the HU folder from #5 above. It can take a while. 8 When finished, eject the SD and reboot the HU. Good luck. Maybe someone with more time will write a full-blown checklist. UPDATE: I just tried applying pionara's 5.1 patch and managed to bork it. Got stuck in a reboot loop. Good thing I had a backup RonS thank you so much. this is really advanced for me, I'll have to study it more and sure before I performing this. But I really apperciate your help Quote Link to post Share on other sites
vgomez916 Posted March 22, 2014 Report Share Posted March 22, 2014 i updated my Z120BT to 5.0 no problem. can i also update to 5.1? Quote Link to post Share on other sites
josney Posted March 22, 2014 Report Share Posted March 22, 2014 Thanks Op, worked with my 130 Quote Link to post Share on other sites
DTS75 Posted March 22, 2014 Report Share Posted March 22, 2014 Hey all, does anyone know if this update can be applied together with the CNSD-310FM/UC upgrade by replacing the Cardinfo and Verinfo files in this update with the files from that thread? I searched around and didn't see any info regarding that. Seems to me that it could be done, but I just want to make sure before I have a chance at making a brick out of my unit. I have a bone stock, never updated Z110bt, purchased new. Thanks everyone! Quote Link to post Share on other sites
misterwoofwoof Posted March 23, 2014 Author Report Share Posted March 23, 2014 Hey all, does anyone know if this update can be applied together with the CNSD-310FM/UC upgrade by replacing the Cardinfo and Verinfo files in this update with the files from that thread? I searched around and didn't see any info regarding that. Seems to me that it could be done, but I just want to make sure before I have a chance at making a brick out of my unit. I have a bone stock, never updated Z110bt, purchased new. Thanks everyone! Yes that should work but why would you want the 2012 maps when you can just install these 2013 maps? Quote Link to post Share on other sites
GNCC407 Posted March 23, 2014 Report Share Posted March 23, 2014 I cannot for the life of me get this to download onto any of my computers. It takes 2 hours and when It gets to the end it says FAILED?? Quote Link to post Share on other sites
davidbryan72 Posted March 23, 2014 Report Share Posted March 23, 2014 safe to assume this will NOT work on X850BT? Quote Link to post Share on other sites
GNCC407 Posted March 24, 2014 Report Share Posted March 24, 2014 Tried again for the 4th time. The only thing I am getting is a empty zip folder and a PART FILE? Quote Link to post Share on other sites
jigrana Posted March 24, 2014 Report Share Posted March 24, 2014 Downloaded using a download manager program. site is great, downloaded at 2mb/s so it was a quick download, followed the instructions and updated my AVIC-X940BT. the upgrade took about 20 minutes and after was done everything works perfect. one thing I notice was it dint have the pandora and aha icons but as soon as I paired my galaxy s4 to the stereo the icons show up. I'm even able to play and control Iheart radio from the stereo. I just bought this one on craigslist because I was so UNHAPPY with a Kenwood DNX570DH. looks like a great stereo I always love Pioneer. Quote Link to post Share on other sites
