Jump to content
AVIC411.com
installereric
Official AVIC NEX Bypass (AVIC NEX Units Only)
Confirmed that this works on an 8100NEX. Great to see; this factored into my decision to actually buy this head unit.
All I did was hook a T-Tap into the PIoneer wire harness ground, then connected the Pioneer wire harness to it. Then followed the "SET ON" procedure.
(and btw, I'm in the US, lol.)
Share this post
Link to post
Share on other sites
Hi Guys;
I have attempted the soft parking break bypass on the 8100NEX. The bypass worked fine until I have upgraded the firmware to 1.03 for Android Auto. I have re soft bypassed after the firmware upgrade and still received the error message. Anyone having the same issue?
Share this post
Link to post
Please Delete.
The answer to my issues was to simply connect directly to the USB instead of using the MHL adapter. Everything works fine now and the speed wire does not need to be connected.
Share this post
Link to post
Based on some of the Android Auto issues I'm having, I'm almost wondering if on NEX unit you even need to ground the parking brake. I am 100% certain that wire is grounded, and the SET ON/OFF works accordingly as described.
Share this post
Link to post
You do not need to ground the parking brake. The bypass is software only.
Share this post
Link to post
I just installed my 6100NEX and it works great, I did the video bypass. I did not ground the parking brake wire. Video plays fine while driving. My problem is I get a warning screen on power up which I have to select "OK" to get the home screen. Is there any way to get rid of this warning? Thank you.
Share this post
Link to post
Does this bypass allow the Nav (changing address, settings etc) to be used while in motion or is it only for video? Also does it work on a 5100NEX or only the 6 and above?
Share this post
Link to post
Just installed my 6100' grounded the parking brake wire to the black ground wire from the H/U. Will attempt to find the sweet spot for the software bypass in the morning.
Share this post
Link to post
You are likely to start seeing errors from the parking brake not being hooked up correctly. The bypass is software only, and works with the brake wire correctly connected.
Share this post
Link to post
Just ran this on my 6000NEX without grounding the parking break and got the expected responce. I will test tomorrow to see if it actually worked as expected. If not I will go forth with permanently grounding the parking brake ground wire.. Great tip.. Thanks..
Share this post
Link to post
Okay, confirmed on my 6000NEX that only the following steps are required....
Step 2 turn power on push main menu button (bottom center)
Step 3 push AV icon (bottom center)
Step 4 on AV icon screen push off button (towards bottom)
Step 5 touch quadrant 4 (half inch in and half inch up from left lower corner of touch screen) hold your finger there for about 10-12 seconds. "set on" icon will appear that means you are done.
No need to ground the parking brake... Yeah.... TY OP....
Share this post
Link to post
Create an account or sign in to comment
You need to be a member in order to leave a comment
Create an account
Sign up for a new account in our community. It's easy!
Register a new account
Sign in
Already have an account? Sign in here.
Sign In Now
