HawgPhixer Posted August 30, 2007 Report Share Posted August 30, 2007 My GPS antenna is under the dash on the metal plate stuck to a defrost duct. Work great. Quote Link to post Share on other sites
SilveradoJoe Posted August 30, 2007 Report Share Posted August 30, 2007 I mount all my installs under the front dash. Make sure no metal is over the antenna. I just silicone it down and all is well. No one wants to see the antenna and you don't have to. I mounted my under the dash too, no need for silicone however, I agree that nobody wants to see it, I have my sirius antenna on top of the cab and would like to move that somewhere too, preferrably i would like to mount it by the 3rd brake light but would need to feed it under the headliner somehow, some day I'll get to it BTW, my signal status displays reception from all of the satellites shown I never trust the sticky tape. I like silicon because it doesn't fall off, but you can still remove it completely if and when you need to. I always put the satellite radio antennas outside the vehicle. Because reception sometimes cuts out I like to put them in the best possible location. Plus if you put it inside the vehicle and it cuts out the customer usually comes back and wants it located outside for better reception. I have mounted XM antennas inside under the dash pad before and not had problems, but I don't do that unless the customer asks that I hide the antenna. Yes GPS antenna is mounted on a metal base under the dash as well. No need for sticky tape either. And trust me, it's not going anywhere. If you have installed in a Silverado you would know where I am talking about. I did not mean that I was intending to place my Sirius antenna inside the cab. I would still like it mounted outside on the roof of the cab. Currently, I have it mounted above the windsheild (as shown in Sirius' installation guide), off-centered the equivalent and opposite side the shark fin that houses my On-Star and factory XM antennas (the older silverados had two separate antennas for those features; i located my Sirius antenna where the second one would have been). I would prefer that I wire the antenna lead under the headliner and through the opening exposed when the third brake light is removed. It would be six inches or so forward from the top center of my rear window. I would not like to imagine what kind of reception is received by the satellite radio antenna if it were placed inside the vehicle. I live in one of the flatest regions of the U.S., and still the signal cuts out easily when I drive around tall objects such as rows of trees and downtown buildings. I was not able to distinguish and differences in reception between the antenna supplied with my Sirius tuner or the factory XM antenna. Quote Link to post Share on other sites
wacktool Posted August 30, 2007 Report Share Posted August 30, 2007 I actually mounted mine inside the dash where scion would have put the oem navigation. Works fine and out of sight. Quote Link to post Share on other sites
Wizzard005 Posted September 2, 2007 Report Share Posted September 2, 2007 I put mien where the stock navi goes 2007 Nissan Frontier Quote Link to post Share on other sites
Aleksey Posted September 4, 2007 Report Share Posted September 4, 2007 ha-ha, that’s exactly how I did mine on ford focus Quote Link to post Share on other sites
ItsDon Posted September 4, 2007 Report Share Posted September 4, 2007 Mine is mounted in the far front passenger side corner of the dashboard and then covered with my "Dashy" dash mat. It disappears and works flawlessy. Quote Link to post Share on other sites
zeuscc Posted September 5, 2007 Report Share Posted September 5, 2007 I have mine on the dash. hardly notice it, and stay weather free. Quote Link to post Share on other sites
workings Posted September 14, 2007 Report Share Posted September 14, 2007 In your 2004 Pilot, where did you connect your vss wire...thanks Quote Link to post Share on other sites
Join the conversation
