bass_rock Posted July 23, 2015 Report Share Posted July 23, 2015 So tried to get into the test mode on the error screen and no go. And that 5000NEX sdcard looks like it may not be anything. It does not have a valid partition table (assuming ubuntu can read android partition tables). Which could explain the issues AdamOutler and I are having trying to boot from it. Has anyone successfully used that image or the image on the different sites? Quote Link to post Share on other sites
WhatIsWhatIsWhatIsWhat Posted July 23, 2015 Report Share Posted July 23, 2015 [deleted post] Quote Link to post Share on other sites
bass_rock Posted July 23, 2015 Report Share Posted July 23, 2015 Are you speaking about avic_5000nex_sd.img? $ fdisk -l avic_5000nex_sd.img Disk avic_5000nex_sd.img: 7,5 GiB, 8068792320 bytes, 15759360 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x00000000 Device Boot Start End Sectors Size Id Type avic_5000nex_sd.img1 1050624 1071103 20480 10M 83 Linux avic_5000nex_sd.img2 1071104 1091583 20480 10M 83 Linux avic_5000nex_sd.img3 1091584 3573759 2482176 1,2G 5 Extended avic_5000nex_sd.img4 3573760 15042559 11468800 5,5G 83 Linux avic_5000nex_sd.img5 1091585 1153023 61439 30M 83 Linux avic_5000nex_sd.img6 1153025 1214463 61439 30M 83 Linux avic_5000nex_sd.img7 1214465 2263039 1048575 512M 83 Linux avic_5000nex_sd.img8 2263041 2525183 262143 128M 83 Linux avic_5000nex_sd.img9 2525185 3573759 1048575 512M 83 Linux Partition table entries are not in disk order. If yes, you can use kpartx or mount original image using fdisk + mount offset: http://askubuntu.com/questions/445979/mount-sd-card-image-created-using-dd I don't have a .img the file that I have is a .rar from you that I cannot extract. So i ended up dd'd that to the sdcard. Quote Link to post Share on other sites
gotofbi Posted July 23, 2015 Report Share Posted July 23, 2015 $ sudo fdisk avic_5000nex_sd.img Disk: avic_5000nex_sd.img geometry: 980/255/63 [15759360 sectors] Signature: 0xAA55 Starting Ending #: id cyl hd sec - cyl hd sec [ start - size] ------------------------------------------------------------------------ 1: 83 513 0 1 - 522 127 16 [ 1050624 - 20480] Linux files* 2: 83 523 0 1 - 532 127 16 [ 1071104 - 20480] Linux files* 3: 05 533 0 1 - 1023 127 16 [ 1091584 - 2482176] Extended DOS 4: 83 1023 127 16 - 1023 127 16 [ 3573760 - 11468800] Linux files* Signature: 0xAA55 Starting Ending #: id cyl hd sec - cyl hd sec [ start - size] ------------------------------------------------------------------------ 1: 83 533 0 2 - 562 127 16 [ 1091585 - 61439] Linux files* 2: 05 563 0 1 - 1023 127 16 [ 1153024 - 2420736] Extended DOS 3: 00 0 0 0 - 0 0 0 [ 0 - 0] unused 4: 00 0 0 0 - 0 0 0 [ 0 - 0] unused Signature: 0xAA55 Starting Ending #: id cyl hd sec - cyl hd sec [ start - size] ------------------------------------------------------------------------ 1: 83 563 0 2 - 592 127 16 [ 1153025 - 61439] Linux files* 2: 05 593 0 1 - 1023 127 16 [ 1214464 - 2359296] Extended DOS 3: 00 0 0 0 - 0 0 0 [ 0 - 0] unused 4: 00 0 0 0 - 0 0 0 [ 0 - 0] unused Signature: 0xAA55 Starting Ending #: id cyl hd sec - cyl hd sec [ start - size] ------------------------------------------------------------------------ 1: 83 593 0 2 - 1023 127 16 [ 1214465 - 1048575] Linux files* 2: 05 1023 127 16 - 1023 127 16 [ 2263040 - 1310720] Extended DOS 3: 00 0 0 0 - 0 0 0 [ 0 - 0] unused 4: 00 0 0 0 - 0 0 0 [ 0 - 0] unused Signature: 0xAA55 Starting Ending #: id cyl hd sec - cyl hd sec [ start - size] ------------------------------------------------------------------------ 1: 83 1023 127 16 - 1023 127 16 [ 2263041 - 262143] Linux files* 2: 05 1023 127 16 - 1023 127 16 [ 2525184 - 1048576] Extended DOS 3: 00 0 0 0 - 0 0 0 [ 0 - 0] unused 4: 00 0 0 0 - 0 0 0 [ 0 - 0] unused Signature: 0xAA55 Starting Ending #: id cyl hd sec - cyl hd sec [ start - size] ------------------------------------------------------------------------ 1: 83 1023 127 16 - 1023 127 16 [ 2525185 - 1048575] Linux files* 2: 00 0 0 0 - 0 0 0 [ 0 - 0] unused 3: 00 0 0 0 - 0 0 0 [ 0 - 0] unused 4: 00 0 0 0 - 0 0 0 [ 0 - 0] unused osx output Quote Link to post Share on other sites
AdamOutler Posted July 23, 2015 Report Share Posted July 23, 2015 try unrar e /path-to/file.rar here's the layout. adamoutler@adamoutler-desktop:~/Desktop/avic$ fdisk -l ./avic_5000nex_sd.img Disk ./avic_5000nex_sd.img: 8068 MB, 8068792320 bytes 128 heads, 16 sectors/track, 7695 cylinders, total 15759360 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Device Boot Start End Blocks Id System ./avic_5000nex_sd.img1 1050624 1071103 10240 83 Linux ./avic_5000nex_sd.img2 1071104 1091583 10240 83 Linux ./avic_5000nex_sd.img3 1091584 3573759 1241088 5 Extended ./avic_5000nex_sd.img4 3573760 15042559 5734400 83 Linux ./avic_5000nex_sd.img5 1091585 1153023 30719+ 83 Linux ./avic_5000nex_sd.img6 1153025 1214463 30719+ 83 Linux ./avic_5000nex_sd.img7 1214465 2263039 524287+ 83 Linux ./avic_5000nex_sd.img8 2263041 2525183 131071+ 83 Linux ./avic_5000nex_sd.img9 2525185 3573759 524287+ 83 Linux Quote Link to post Share on other sites
bass_rock Posted July 23, 2015 Report Share Posted July 23, 2015 Ah ok. Yes unrar on ubuntu worked, but not the utility I had on my mac. Will try again tonight. Quote Link to post Share on other sites
gotofbi Posted July 23, 2015 Report Share Posted July 23, 2015 Ah ok. Yes unrar on ubuntu worked, but not the utility I had on my mac. Will try again tonight. If you downloaded same file that I downloaded, its rar5 archive and I believe theres no good utility to unpack except official 'unrar' http://www.rarlab.com/rar/rarosx-5.3.b1.tar.gz its command line tool by the way. Quote Link to post Share on other sites
bass_rock Posted July 24, 2015 Report Share Posted July 24, 2015 Ok good news! I was able to successfully dd that sd card img after i got it to unrar. I then popped it into my unit and it went to the Updating screen. At this stage nothing would happen and it sat on Update 0.00 -> 0.00, so I went to my computer loaded the 8000 1.10 onto a usb, unplugged the other sdcard and popped it into the USB 1. The deck then recognized the 1.10 update and began updating. The deck now boots normally and I can resume where I was! (Carefully modifying the init.rc). One thing to note with this is that on the first boot with the sd card I didn't realize I still had my usb with the Testmode key in it. However on subsequent boots I removed that key and still got the Updating 0.00->0.00 screen. Quote Link to post Share on other sites
AdamOutler Posted July 24, 2015 Report Share Posted July 24, 2015 Ok good news! I was able to successfully dd that sd card img after i got it to unrar. I then popped it into my unit and it went to the Updating screen. At this stage nothing would happen and it sat on Update 0.00 -> 0.00, so I went to my computer loaded the 8000 1.10 onto a usb, unplugged the other sdcard and popped it into the USB 1. The deck then recognized the 1.10 update and began updating. The deck now boots normally and I can resume where I was! (Carefully modifying the init.rc). One thing to note with this is that on the first boot with the sd card I didn't realize I still had my usb with the Testmode key in it. However on subsequent boots I removed that key and still got the Updating 0.00->0.00 screen. Please share the sha256 of your rar and image for quality purposes. Quote Link to post Share on other sites
bass_rock Posted July 24, 2015 Report Share Posted July 24, 2015 Here is the shasum f99aacce6347d2c4835fa63b413ed198f0b7fb92 /Users/daniel/Desktop/avic_5000nex_sd.img 2c4962326c1b2ccebd715a22f33c2772e0670c93 /Users/daniel/Downloads/avic_5000nex_sd.rar Quote Link to post Share on other sites
bass_rock Posted July 24, 2015 Report Share Posted July 24, 2015 So whats also interesting is that I now get a map license error and my motorized screen will not work. The options are there for the cd and sdcard, clicking on them does nothing, and the options for the motorized screen are greyed out. It's like there is something saved from the sdcard image (which was not a 8000). Quote Link to post Share on other sites
AdamOutler Posted July 24, 2015 Report Share Posted July 24, 2015 So whats also interesting is that I now get a map license error and my motorized screen will not work. The options are there for the cd and sdcard, clicking on them does nothing, and the options for the motorized screen are greyed out. It's like there is something saved from the sdcard image (which was not a 8000). Sounds like DRM. The deck is likely initialized with some special keys from the factory. Try flashing the original SD Image once again, then perform all available updates even if they are redundant. It's possible one could contain a default DRM. Also, ensure you flash a totally stock image and not modified. Quote Link to post Share on other sites
bass_rock Posted July 24, 2015 Report Share Posted July 24, 2015 Yep. I did the updates a few times. Now I am trying a force write with the Testmode keys. The next idea if that that does not work is to try and dd the right images from the update to the right partitions to on the SD which mean we need to know the right mappings Quote Link to post Share on other sites
WhatIsWhatIsWhatIsWhat Posted July 24, 2015 Report Share Posted July 24, 2015 [deleted post] Quote Link to post Share on other sites
