jokers000 Posted September 14, 2007 Report Share Posted September 14, 2007 hey do u think u could hook up the red power wire to the acc and the key on power??? what im thinking is when u go to acc the hd powers up but when u go to start the car it shuts off and powers again, so if i hook up the acc and key on to the red wire on the hd, will that be fine or i can burn the wire or something??? i would just connect it to key on but would like to turn car to acc and still have the hd on which would be on acc Quote Link to post Share on other sites
HiFiSi Posted September 14, 2007 Report Share Posted September 14, 2007 You realize that would make you unable to turn off the radio, right? Quote Link to post Share on other sites
Raiden Posted September 14, 2007 Report Share Posted September 14, 2007 That could be pretty cool! Draining a battery for dummies! lol Quote Link to post Share on other sites
jokers000 Posted September 14, 2007 Author Report Share Posted September 14, 2007 oops i put turn car off, i meant turn car off to acc Quote Link to post Share on other sites
HiFiSi Posted September 15, 2007 Report Share Posted September 15, 2007 Well virtually anything electronic is going to shut down when you crank the starter unless it's wired directly to the battery. That's the only way I can think of doing what you want to do. Wire both the constant and switched power wires directly to the battery and install a switch on the ACC power wire to the unit? Unless I'm missing something. No offense, but your question is a bit garbled and hard to understand. Quote Link to post Share on other sites
jokers000 Posted September 15, 2007 Author Report Share Posted September 15, 2007 to keep it simple what can happen if i connect the acc wire and the key on power wire together? Quote Link to post Share on other sites
HiFiSi Posted September 15, 2007 Report Share Posted September 15, 2007 If you connect both those wires to a switched source (like the acc power wire coming from the ignition) the unit will reset/lose memory every time you turn off the car. And you don't want that. If you hook them both up to a constant power source, you will not be able to turn off the unit ever unless you install a switch on the ACC power wire from the unit. Quote Link to post Share on other sites
myvekdrifters Posted September 15, 2007 Report Share Posted September 15, 2007 your unit just stay on...ALL THE TIME!!! Even if you leave the car overnight...the unit would still be on. But if you want to do a switch thingy while connected to your method, then fine...but beats the purpose of connecting the red wire to the ACC, which is just exactly a switch for any electronic in the car. Quote Link to post Share on other sites
davemonkee Posted September 15, 2007 Report Share Posted September 15, 2007 jokers000, you can hook-up the acc wire from the radio to an ignition source. the ignition stays "on" when you crank the starter and if shuts off when you turn your car off. dave Quote Link to post Share on other sites
jokers000 Posted September 15, 2007 Author Report Share Posted September 15, 2007 jokers000, you can hook-up the acc wire from the radio to an ignition source. the ignition stays "on" when you crank the starter and if shuts off when you turn your car off. dave i guess thats how u say it ignition source/ keyon start position same? anyway i want to have the unit to stay on when cranking over to start, now when i turn the car one click down, turns off the car but acc is still on and would like to have the unit to stay on til i turn the key off completely now i was thinking to do that, but will have to have the ignition source connected to the acc together and connect it to the red wire on the hd but when connected together will have any effect on the wires or something u know when u turn the key to ignition it powers ur fuel pump and lights and all that.....that power wire connect to the acc is what im trying to say Quote Link to post Share on other sites
autobot152 Posted September 15, 2007 Report Share Posted September 15, 2007 Connecting the 2 wires will solve your problem of your radio powering off during cranking however, if you connect your acc and ignition/source wire to the red wire on the D3 harness, you are then connecting the two positions. You will no longer have an acc position because when you click it to the acc position, 12+ will go to your radio then also go to your ignition/source wire thus creating a short. I tried to do this in my first car (86 ford escort) and found out the hard way. It may be different in your application as the escort was a POS. Give it a try and let us know. Quote Link to post Share on other sites
HiFiSi Posted September 15, 2007 Report Share Posted September 15, 2007 That's not gonna work. Quote Link to post Share on other sites
installermarc Posted September 15, 2007 Report Share Posted September 15, 2007 could be done with a retained accessory power relay setup. don't remember the specifics, but the circuit would basicly keep the acc wire energized to the radio until you shut the key off AND opend a door. i do remember you need 2 relays and 1 diode to make it work. i am sure you could check on me-mag.com forums, there might be more info on something like that over there. Quote Link to post Share on other sites
myvekdrifters Posted September 18, 2007 Report Share Posted September 18, 2007 You could do that, but that still didn't answer his question. I believe he wants to start up the car without having the unit go through the startup cycle again. Joker>You can only have one or the other. Either have the unit stay on forever cuz there is no way you can turn off the unit when leaving the car "IF" you connect the two wires, ACC and Power wire together to the 12+V constant wire of the car, bypassing the ACC. The reason why there is a hicup when starting up the car is because at the back of the key switch on your steering wheel are series of connections that makes contact to series of wires. When the key turns, it will turn the switch to those wires thus making contact. In between contact, there is a delay. ACC turns on accessories and is connected to a fuse to the battery. Ignition on turns all power in the vehicles engine, fuel pump, etc. Turn one more and starts the car, which fires the alternator to send spark to the sparkplug, which basically has no power from the battery. Therefore, there are no volts going to the deck and other areas, needs 12 volts constant to the alternator to start the car, no interference. Solution, you can connect a seperate battery with/or a capacitor and a switch to it to your deck. Using the switch to control the power going to your deck. JUST A THOUGHT. Quote Link to post Share on other sites
myvekdrifters Posted September 18, 2007 Report Share Posted September 18, 2007 sorry correction needs to be made...Alternator doesn't really fire the sparkplug, but helps crank the engine...the ecu fires the sparkplug. alternator helps crank the engine and getting it going, turning the pistons and rods through the crank pulleys and timing belts. Quote Link to post Share on other sites
