Jump to content
AVIC411.com
2017 v7 US/Can Update available for Z110/120/130/140,X920/930/940
Hey all,
I've got a z110bt and I've been able to update in the past without any issues. For some reason, I cannot get this 2017 update to work. I can run the shortfuse script but can't get the maps to install.
I get the "Wrong SD card. Install correct SD card" error before even getting the chance to put in a password. I've tried several things:
- Full format(not quick format) 2 different 8GB cards (used in previous updates) for FAT 32 with default config and 32k. I tried 16k and it wouldn't let it finish.
- I've tried both the cardinfo.cif from the original zip as well as the specified z110 file that was also linked to this thread.
Can anyone lend some insight into this issue?
Thank you in advance!
Edited by Jefe2323
Edit: I've re-formatted at 16k and now get the "An error occurred, update failed". It will also show the message "insert SD card"
Link to post
Share on other sites
  • Replies 219
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
On 6/3/2018 at 6:19 PM, Jefe2323 said:
Hey all,
I can also enter TESTMODE and was able to copy over old files from USER. I'm just not able to update to new maps no matter what I've tried.
Link to post
  • 2 weeks later...
Hello, I have Pioneer_T1000-25818.zip but can't find the proper password. And it isn't "PASSWORDPASSWORD" . Could I please have the right one? Thank you.
I do have ShortFuseScript.zip and would be good to go.
Found what I was looking for, thank you. I was missing the other password. Updating as I type with 18 minutes to go.
Thank you RonS
Link to post
Link to post
RonS, I used the "Easy" method, everything went smooth. But now Ipod wont work. The menu changed, I switch the CARDINFO with Z110Z120X920CARDINFO I have the 120BT. What did I do wrong? I'm going outside right now. It worked fine, cable is good. Any suggestions would be appreciated. Thanx
Link to post
What do you mean? how is your iPod connected? Did you try AV System Settings/App Connection?
Link to post
15 hours ago, Shane H said:
I was in a hurry. Ipod nano connected with the usb/av cable. In the first pic only the settings and eq buttons work.
I never used App Mode - didn't even know it worked with a nano. I can only suggest doing a hard reset by disconnecting the car battery for a couple minutes. This often cures odd behavior after a firmware update.
Link to post
  • 2 weeks later...
I never used app mode either. The selection is either wired or Bluetooth no off. I am going to disconnect the battery now since I can't find the radio fuse on the Hummer.
Just pulled the radio fuse, it was powerless, reinstalled fuse and no change. The ipod function goes into app mode.
I'm not 100% sure but if I remember right App mode was always greyed out before I did the update.
Link to post
On 8/8/2017 at 10:35 AM, RonS said:
Thought I'd post the Installation/operation manuals and info on the two 2017 updates (v7.0 firmware). I recommend that everyone review them before installing. Also note the specific instructions for upgrading BT from older( < 3.10) versions to v3.32. And as before, it doesn't seem possible to add iPhone Lightning connector support(patches 4.6 or 5.1) after the fact. It must be installed before installing firmware 6.0 and higher. IDK if there is a workaround.
Only Compatible With:
  • AVIC-Z110BT, AVIC-Z120BT, AVIC-X920BT         CRD5009A.pdf
  • AVIC-Z130BT, AVIC-X930BT, AVIC-X9310BT, AVIC-Z140BH, AVIC-X940BT          CRD5006A.pdf
As with other updates, either product can be made to install on any of the above units when used with the proper CARDINFO file.  See post #26 for the update files and see Shortfuse Hack for how to hack you unit prior to installing those files.
The manuals wont open up,says page not found.
Link to post
On 7/8/2018 at 1:32 PM, RonS said:
Did you replace the Cardinfo.cif file on the SD? The one in the ZIP is for Z130 or Z140
I've been trying I cant seem to figure out how to do it I guess.. I downloaded winrar (I seen someone suggest using it). But I cant get the one for 130 /140 to delete/move. Apparently I'm not the best with computers. Smdh
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
