All Activity
- Today
I believe that both my usb and sd card are formatted in FAT32. My usb is only 128gb, can’t remember the size of the sd card. Both work fine.
For a long time, I've used an iPod Classic modded with SD cards for 512 gb of memory. Recently with my other car, I discovered iPod Classics are no longer supported, and since neither is iTunes, I thought about modernizing. I used Media Monkey to build a library on a 512 gb flash drive. It works in that car. Decided to do the same for my vehicle that has the AVIC7200NEX. I've now tried loading the library 5 times, but every time it freezes at 60% formatted and i can't select songs or artists when that happens. The drive is a 512 formatted in NTFS. Has anyone gotten a flash drive to work?
Hello everyone, Quick question, this link contains folder F60_1.15 with F860.rar is it right image for AVIC-F860BT for EU market ? If it will work on new SD card should I update to 1.21 downloaded from pioneer website ? https://mega.nz/folder/ezY1FYhb#ued2oydxeZula3ZTm6p1ng
dexbiker joined the community
w4500nex [FIX] SDCard Failed? Software Error on your w4500nex? Look here!
mahdi replied to slackwaredragon's topic in NEX Series
hi if you find please sey to me my avh-z9250 touch not working -
drjg88 joined the community
- Yesterday
Good Luck brother. Hope it works for you since it did for me.
I had researched this enough to know that, so I still have not installed it into my head unit. I am going to attempt to make a back up image of later today if I can make time. Thanks!
Thank you I will purchase a usb sd card reader today and boot up linux mint and hopefully it works. Will report back!
- Last week
Once you put it in your unit it will lock the card and you won’t be able to do any other thing with it like create an image.
When I received my new sd card, I used Linux Mint with an external card reader that plugged into a usb port to create an image file that I then put that image on a Sandisk 16gb card. Windows will not read that card because it is an android program. Now I suppose you could get some program for Windows to read that card but I am no computer guru so I don’t know Linux Mint work great for me.
GermanTith joined the community
Souris82 joined the community
Ruslansak joined the community
pascool joined the community
mahdi joined the community
Did you solve this issue. Mine is blank from the start...
Hello, I purchased a new sd card and would like to back it up before I insert it into my head unit. Windows does not seem to recognize it when using my internal sd card reader and when booting into linux the OS doesnt have the correct drivers to even utilize my internal sd card reader.... Is there a way to accomplish this on Windows? I am very tech savvy, just do not know a ton about all the ins and outs of what Pioneer has going on with these stupid sd cards. If it would register in windows I would be able to easily create a .img file but that is the part I am confused on why it wont
I just purchased a new sd card and havent inserted it into my radio yet, trying to figure out how to make an image from it but not having any luck. I have the same head unit as you. If someone can tell me what to do I will gladly share my image.
Look here: https://avic411.com/index.php?/topic/90861-fix-sdcard-failed-software-error-on-your-w4500nex-look-here/page/3/#comments
Anyone know how to get into test mode for AVIC-HRZ099?
Alexei Navalny replied to protocold's topic in Hacks/Mods
There weren't any replies. Probably because no one who has seen your question knows the answer. Did you try searching for the answer? Try http://avic411.com/index.php?/topic/39638-avic-mrz99-custom-firmware-testmode/&do=findComment&comment=341665 BTW, I have no knowledge of how to convert Japanese units so I won't be of any help -
Chrissie_B replied to protocold's topic in Hacks/Mods
Why can't I see any replies -
Hi, i have MRZ90 on my car but i cannot copy the files from or to my user folder or sd card. anyway to fix it?
- Earlier
Do you have any other background images available please?
Just wondering how have you got your usb hooked up. I bought an ipod input cable ipod/usb and there's a male and female usb halfway down one cord and it doesn't pick up my phone or anything else plugged in. And the ipod only works when the usb male and female are connected. Seems odd
Hello friends. Is there a way to unlock a previously flashed SD card after being inserted into the player? I have an AVH-Z9250BT with boot issues, I flashed an SD card with the 4400nex firmware, and it boot perfectly, every functions works fine, except the AM-FM Radio, I tried to reflash the SD with another firmware, but it apear Access Denied error, and I can't format or reflash the same memory. I'll apreciate any help
Alexei Navalny started following Frankpoowl
Alexei Navalny started following Patricknuats
Alexei Navalny started following DennisDiz
Alexei Navalny started following Edwardgreld
I have a four year old AVIC 8600 NEX unit, and a Sirius subscription that hasn't had any problems. Suddenly this week, the icon is greyed out, and inaccessible. The Sirius settings are inaccessible, etc. Everything else seems to work, and I can play Sirius through Bluetooth from my phone, but obviously that's not the goal. Satellite seems to work (I can access mapping). Sirius refreshed the signal, does nothing. They are no help. I'm comfortable removing the unit, and if I need to replace the sirius receiver, I can prob do that, but I'd prefer to try everything else first. Ideas?
Hello, I do not have the tool you have that switches the illumination and power supply on or off. But will that be okay if I connect the wires to a power supply generator and use a breadboard to give certain ground and voltages to the specific wires? I am thinking of creating a simple switch-button circuit for the illumination
i have a avh-4200 NEX i got the software error on my screen do i just download the 4500 iMG? idk what to do i cant find that image anywhere and im not paying some scam artist on ebay for a fake again
Pioneer AVH-X5500BT - Black Screen fault
Joe444 replied to Shanz's topic in Problems/Troubleshooting
Did you ever fix your stereo? My Pioneer AVH-275BT is doing exactly as you describe. -
soo i have the same problem . did u fix the problem?
