Australian Map Update (R17 Maps Page 23)
By 34by151 · Mar 29, 2009in Hacks/Mods💬 481 posts👁️ 97,204 views
Page 8 of 20
Posted Nov 23, 2009 · 22:22 UTC#176
Recieved mine today for my F500BT. However the item number is XXXX150. Any chance this is compatible with the F900BT?
Posted Nov 24, 2009 · 01:39 UTC#177
I can confirm that you need to go to the Euro website to get the password.
Here's the link:
http://www.pioneer.eu/eur/content/support/support/upgrade/unlock_navi_software.html
Pioneer Australia advised to always go to European site as they do all the testing and any available information is always posted there first. For what its worth!
Cheers...
Posted Nov 24, 2009 · 06:29 UTC#178
Got mine in the post today! Woohoo, just upgrading now...
Thanks JM1065 for the link. The Aussie one doesn't work and I don't know why they bothered posting it there. Just use the link provided above everyone.
Also from my observations SD1 upgrades the unit to 2.1000 probably to give a fresh install to then upgrade with SD2 to 3.02010 and installs maps version 02.000400.
All working smoothly and the new beeps are soooo much better, they fixed a problem I was having with ipod music/video buttons too by the look of it. Now to find a similar data.zip to GTIMatt's. Any ideas anyone?
Posted Nov 25, 2009 · 13:07 UTC#179
Got mine finally,
the Aussie pioneer website is working, tested today... got unlock code generated with no issues :D
It appears they FINALLY got rid of the lag/sluggish response of the hopeless previous releases. About time...:!:
The bundled MIC is a hopeless peace of crap, no software will ever fix it though. Noticed the BT is more stable with Blackberry and iPhone.
Posted Nov 26, 2009 · 00:59 UTC#180
Just a update,
Got the code from the European site.. and software updated perfectly to version 3 something.. TMIC is working now.. :D
thanks again
Mick
Posted Nov 27, 2009 · 15:32 UTC#181
Usual Disclaimer:
These files are for hobbyist use only. Use them at your own risk I can not be responsible for your actions if something goes wrong. Make sure you take a backup of your system prior to any changes
This Update is for V3 Firmware only
Contained in this release:
Test mode for V3
Australian Sensis R16.1 Map (Released June 09)
3D Bulidings
3D Petrol Stations
Updated POI's
Updated Speed Cam
Spoken Street Name Corections (Phoneme.ph file)
Map Warning Bypass
Updated EzRider
Updated SYS.TXT
Udated Map License files
Updated Terrain (more detailed evevations)
This release has been tested on the Australian AVIC-F900BT
Download files from
http://www.4shared.com/file/160754980/9 ... part1.html
http://www.4shared.com/file/160828063/9 ... part2.html
or
http://www.4shared.com/dir/24382274/615 ... dates.html
Instructions
This update will just fit on a 1Gb SD card but it is advisable to use a SD card greater than 1Gb.
1. Start your AVIC normally and verify you have the V2 Firmware installed.
2. Check your map version.
Go into Settings / Navi Settings / About / Maps
Your Maps will display Sensis R15.1
3. Check your frirmware version.
Go into Settings / System Settings / Service Information
Next to Version you must have 3.xxxxxx
4. Extract this update to the root of an empty SD card. Do not modify the directory structure and extract both files. The best software to extract with is winrar
5. Insert the SD card and Start the AVIC
6. Use Test mode to backup your unit.
Make a Directory called "Backup" on the below storage card and copy "My Flash Disk" to this directory
Read the AVIC411 Faq's If you are unsure on Test Mode or make a backup
7. Copy The directories below Storage Card\My Flash Disk to "My Flash Disk" on your AVIC.
Overwrite files as needed
8. Restart Your AVIC
9. Verify you have the new Maps
The Map will now be "Australia R16dot1 Sensis
10. Verify you have Buildings Working. Zoom into a CBD location to see buildings
11. Verify you have updated POI's.
Open POI's and search for McDonalds, you will find it under restaurants if browsing POI's
12. Verify Warning Bypass. Go to the map scraeen and restart the AVIC. Press Map and check the warning is bypassed
Enjoy
34by151
Posted Nov 27, 2009 · 20:15 UTC#182
Hi 34by151,
I've just joined the site.
I just received the map update from Pionner. All installed ok. Firmaware version 3.02, maps 2.004. Can I apply your changes? I also notice that the safety camera database is not as uptodate as the previous vesion of the maps. Lots of cameras are missing. Not sure if othes have found the same.
Regards,
BlueGolf
Posted Nov 27, 2009 · 21:35 UTC#183
Yes, this is for V3 firmware only which is what you now have
You will find the maps are V15.1. This release will update the maps to 16.1
All the poi's are back and the camera's data is the latest. BTW this also includes variable time and speed limits
IE School zones drop the speed to the correct one when in effect ect
The really sad thing is the Maps released by pioneer have half the data missing as well as being 3 versions behind
My initial release for V2.0 firmware upgraded the Maps to this same version (15.1) later releases upgraded to 15.1a and 15.1b.
The official V3.0 release is missing
3d buildings (landmarks);
Petrol Station Hallmarks
A tiny terrain file (38mb) so elevation is way off affecting calcs. This release has a 132mb version
Old Poi's
Old Speed cams
No Phonetic speech
The Latest Sensis maps are Version 16.1 that were released in June 09.
The next update is expected in Dec which will be 16.1a this is expected not to update the map but the data, things like Pio's and cameras.
I just noticed I left the 3dCars in the content directory. If you don't have a data.zip that supports this you can remove it. I am working on a new Data.Zip to be in my next release This has 3dcars in it among many other things and will have the look of the gurjon skin
see http://www.gurjon.com/gj_scr/ for the origional
and viewtopic.php?f=34&t=26699&hilit=gurjon for BorisM's AVIC verion
I'm customising that with mods already completed by BorisM, IDT and Drifta, credit to them for their work
Cheers
34by151
Posted Nov 27, 2009 · 21:48 UTC#184
Thanks for your quick response 34by151.
Posted Nov 27, 2009 · 23:47 UTC#185
Another great job by 34by151. The Pioneer update was such a disapointment! I'm glad you've put together this update to help everyone get the full benefit of their system. Thanks.
Posted Nov 29, 2009 · 01:26 UTC#186
Hi 34by151
I downloaded the two files as per your instructions and expanded them to a 2gig sd card. I noticed that only 262mb of the sd card was used. Is this right?
I have the following folders -
My Flash Disk
APL
APL2
testmode
Utils
I noticed when I expanded the smaller file it asked to overwrite some files.. I answred yes.
Apologies if the above sound like stupid questions....I'm still new at this..
Cheers....BlueGolf
Posted Nov 29, 2009 · 01:37 UTC#187
Extract the rar file and keep the directory structure. The easiest way is to use winrar to do that.
The APL and APL2 folders are below "My Flash Disk" in the archive
If you have trouble and have followed the posted instructions try deleting the files in
"\My Flash Disk\USER\UserData\iGo\save"
Cheers
34by151
Posted Nov 29, 2009 · 07:50 UTC#188
I have the gurjon skin running. I have made some TMC changes to it for more SUNA info and options. Still getting used to all the options but it looks very good so far. I need to fix the positions of some of the icons as well as add-in in some tilt/zoom options before an initial release.
All of the TMC changes from my V2 release are included. You can look those up in earlier posts.
Auto/Manual tune switching is included as well as default TMC tuner mode. I finished the Spoken TMC warnings. Still working on getting a TMC warning distance going. This will restrict spoken TMC warnings to TMC warnings to those within a selected distance. New warnings will be spoken right away if inside your distance. Warnings outside the distance will be spoken when they come within the distance. Expired warnings will be spoken only if within your distance
I'm hoping to complete an initial release by Monday next week. This will work on V3 firmware with or without the updated 16.1 maps
Cheers
34by151
Posted Nov 29, 2009 · 13:23 UTC#189
hi there I new to the forum. Ive done some reading and thought i was ready for som mods... I downloaded the the two files as directed in the thread. I have extracted the first file to the SD card, but when i go to extract the second file and when i select to replace files I get an error message, which i can copy, but the details are: Extracting file: E:\V3UPDATE01.part2.rar
Extracting to "E:\"
Use Path: yes Overlay Files: no
Extracting My Flash Disk\APL2\iGO\content\map\Australia.fbl Error: CRC mismatch in file "My Flash Disk\APL2\iGO\content\map\Australia.fbl" in the archive "E:\V3UPDATE01.part2.rar"
any suggestions??? I tried to copy just the first file.... it clearly didnt like it because now it just keeps rebooting. some help would be really appreciated.
Posted Nov 29, 2009 · 19:26 UTC#190
Downlaod and install winrar
Put the 2 rar files in the same directory
Right click on the part1 files and select extract to V3update01
If you still get a crc error download the second files again.
I have checked the files I uploaded and they are working
Cheers
34by151
Posted Nov 29, 2009 · 20:00 UTC#191
Hi there, I was using winzip, is there a difference? After extracting part 1, do I try to extract part 2 onto the sd card aswell? Or is it enough that both are in the same directory when I extract part1? Thanks again and I apologies if this sounds darft.
Posted Nov 30, 2009 · 01:14 UTC#192
Yes you need both extracted. The Rar file is split into 2 file because 4shared limits uploads to 200mb per file.
If you are still having issues download and extract with winrar as per my last reply.
You will need this anyway if you want to update a data.zip file later on.
Cheers
34by151
Posted Nov 30, 2009 · 02:20 UTC#193
hello, I have followed your instructions and was able to extract both files onto the SD card overwriting some of the files. I then copied the content of MyFlash to the device and rebooted. the device seems to go into an endless loop of restarting. there is some sort of counter in the top right corner which does advance as time progresses. is this normal? how long should it take if it is. I had it going for about 20 minutes before i powered the device down. any suggestions????
Posted Nov 30, 2009 · 03:49 UTC#194
Try deleting the files in "\My Flash Disk\USER\UserData\iGo\save" on your unit
If that does not work try restoreing your backup.
If you extracted the files correctly you would have overwitten some files in APL and APL2/content
Did you follow the release instructions?
Cheers
34by151
Posted Nov 30, 2009 · 04:08 UTC#195
thanks, ill give it a go tonight when i get home. cheers
Posted Nov 30, 2009 · 08:38 UTC#196
hello again, well there seems to be some progress...but still no cigar. it now hangs on top menu screen with "system startup in progress. Please wait." (it does come up with a message that mobile phone is connected, then continues with message as above). I gave it a good 10 minutes, but nada. I have also discovered that during all this copying to and fro, I have erased my original backup...I know, I'm an idiot. does anyone have a backup of f500bt for australia? What are my options? help......please
Posted Nov 30, 2009 · 08:47 UTC#197
i just discovered that the bluetooth still works and i can bring up all the phone menu as well as the av source menu just not the maps as it still has that system startup in progress message displayed. when i select the settings tab just below this messagei get the settings menu and i have access to both system settings and av settings but not navi. does any of this help to figure out what i did wrong? but more importantly, what can be done now????help...
Posted Nov 30, 2009 · 10:28 UTC#198
Sounds like you have the incorrect device type in sys.ini
For The 900 it is
[device]
type="PIONEER746EW"
You can manually restore using the V3 SD cards
Copy the APL and APL2 directories from SD2 onto you AVIC
Use a generic SYS.TXT and make sure the device type is correct.
When you say NAVI is not working
If you switch to Map right after the Mainmenu or Audio starts. You will see Igo loading data.
What item does it stop on?
Another way to do this is load a backup of what you have now into the emulator and load ezrider
34by151
Posted Nov 30, 2009 · 10:59 UTC#199
Any idea what the device type should be for the f500bt?
when i go into the service information details the map version is 02.000400 and version: 2.001000
any idea why? shouldnt it be version 3?
incedently in av system settings in the top left corner it has a picture of cd thr letters ROM and below it 24:4:: does this mean anything?
For The 900 it is
[device]
type="PIONEER746EW"
Posted Nov 30, 2009 · 11:11 UTC#200
cant switch to maps, it selects and flicks but doesnt switch to it just like navi settings.
ps it now wont go into testmode!!! im pullig my hair out now...
Another way to do this is load a backup of what you have now into the emulator and load ezriderbeluga
Private message
Page 8 of 20
