Another question!
How do you make an icon fade after a few seconds e.g. the icon to the avoid/detour screen?
Colin
Another question!
Colin
Another question!
Colin
After any event write something like
500 run sc_fade_my_icon
500 means delay after the event you chose
fade effect could be gotten by .alpha parameters of your button
500 means delay after the event you chosefade effect could be gotten by .alpha parameters of your button
I think I understand what you mean, but cannot find this in your mod, so as to fade the two buttons on the navigation screen. Can you tell me where it is?
I am very grateful for your help and advice.
Colin
script sc_NavigateMapClick ... map.ONMAPCLICK sc_NaviMenuAlphaRestore ...
Will now go and try!
Colin
the beeps were generated from the following sequence of script
You are right, it must work.
check please, may be you did not update ui file or place it in a wrong place
All other help you have provided has sorted out problems. However, still having problem with sounds.
In the settings for speedcam audio could you confirm what is the difference between Full, Custom and On?
Many thanks
Colin
Many thanks
Colin
"Full" and "On" are the standard behavior of iGo speedcam warning system. "On" warns only if you are overspeed, "Full" - forever. The way how to warn, sound etc are managed by exe and sys.txt.
"Custom" is fully mod-designed warning completely substituting standard one. In fact "custom" switch off standard speedcam warning and the mod produces own logic and mod-determined sounds.
Just to confirm.....
this is still for the 2.0 firmware, right? Nothing yet available from S. / BorisM for the 3.0 firmware....?
(Not that I wanna sound greedy or anything. ![]()
Just to confirm.....this is still for the 2.0 firmware, right? Nothing yet available from S. / BorisM for the 3.0 firmware....?
yet 2.0 ![]()
I am still having problems with changing speed cam warning sounds.
The following code works giving me an audible warning when using Reminder
Speedcam Sound scripts ;****************************************************** .....
I then have tried to replace this with
This doesn't work and as I have no previous experience of such script writing I would appreciate any help in getting it to work.
Colin
Hi,
this is the best mod I've ever seen.. Awesome job..
I have some questions
1) There is a Cockpit button on the menu. But nothing happend when I click it. What is it?
2) Is it possible to have a shortcut to delete route or stop navigation on the map screen?
3) On the original pioneer skin, when you tap somewhere on the 3d map it is possible to change the elevation and view angle. Is it possible on this one too?
Thanks,
No idea, i hope Boris can clarify it. ![]()
It's one click away. If you tap on the turn signal pic then u come to another screen and in the lower corners you find the mute and cancel route buttons.
Stanislavovich didn't want to have these buttons on the map screen itself.
I'm happy that it is no longer there... ![]()
3) On the original pioneer skin, when you tap somewhere on the 3d map it is possible to change the elevation and view angle. Is it possible on this one too?I'm happy that it is no longer there...
is it possible to change the angle from somewhere else then?
Hi, just starting out with the F series. I am in the Uk.
Can I ask the update for this mod, posted by Boris on the 6/08, is this the full mod as I obviously missed out on the original mod. Also does this still allow me to use TMC?
Hi, just starting out with the F series. I am in the Uk.Can I ask the update for this mod, posted by Boris on the 6/08, is this the full mod as I obviously missed out on the original mod. Also does this still allow me to use TMC?
Yes, all uploads are completely self-contained. As far as I know, TMC should be available. Unfortunately neither author nor I can actually test it (in the US we have MSN Direct instead of TMC, and in Russia there's no TMC at all). It should be there, though.
You can adjust angles in SmartZoom settings. You can also hardcode them in SYS.TXT
if you see that button that means you have switched on test mode in regional settings. please switch it off, it is only for my testing, you do not need that button at all.
runif bSpeedcamVerificationBeep 1 'PLAYSOUND "Attention"'
else_runif vSCAudibleAlert 3 'run sc_cs_sound'
in your script sc_cs_sound is called only if vSCAudibleAlert=3 , look carefully! that is why else_runif further do nothing
data file on page 1 is no longer downloadable?
In this mod how do you add advanced cameras? Does this have to be individually or can it be done in bulk via the spud file.
If yes, can you put two or more spud files, with different names of course, in the speedcam folder, so that the AVIC will read each of them?
Colin
Colin
You could do it through a SPUD or a normal speedcam.txt. Not sure if iGO will read multiple SPUD files. It certainly does with TXT files.
First version that works with firmware 3.0
http://www.4shared.com/file/128294916/8 ... /data.html
So far, a straight port by andr2000.
Hej Boris.
Thank's for the v3.0 version. I have a EU version and get an error when I press the Traffic button in the Destination Menu.
FFUIERROR: Unknown object identifier
Identifier=[vTmcFlowEventsSelected]
Script "st_TmcEventsList_init" command 7
I press ok and it then continues into a empty screen where I can choose Settings for TMC, it scans and finds a TMC station but does not show any events.
I hope it can be solved
regards
In this mod, does anyone know which variable can be used to determine whether in mph or kph?
Colin
Hej Boris.Thank's for the v3.0 version. I have a EU version and get an error when I press the Traffic button in the Destination Menu.
regards
Sorry, you need to add:
to variable_def.ui file.
First version that works with firmware 3.0http://www.4shared.com/file/128294916/8 ... /data.html
Boris have you try this yet?
I just downloaded it but doubt I will have time to try it for a while. I am fairly busy at the moment. Just wondering if you got it working correctly or found any problems with this port. Take care Boris.
