after someone reports that the proposed change is working properly I will
integrate it into the next release
I cannot fully test it myself cause CarteBlanche doesn't put any road sign info into my map ![]()
after someone reports that the proposed change is working properly I willintegrate it into the next release
I'll give it a test tonight when I have a chance to install it and I'll let you know...
The road signs fix works beautifully... Thank you so much!
There is only one thing I notice functionality wise that is missing vs stock data.zip
In the original firmware when searching for a poi it gave the option of adding it as a via point. In this mod the only way to navigate to a poi is to make it a new destination. Adding say a gas station along a route during a road trip is pain if you can't add a via point easily. Oh and also one of the best features of the other mod I was using is the ability to mute the voice guidance with a button on the map screen. Any chance something like this can be added?
Again thank you so much for such a great mod ![]()
Well, in order to mute the guidance you may tap on the first direction icon
and then select mute/unmute. We do not have a button on the navi screen for this
Stanislavovich did the mod to be as simple on the screen as possible and
this is why I love it
Adding POI as a via... is this what you want? (see attach)
I am using this mod with version 2 software.
If you tap the screen a circular image of a car appears just to the left of the speed limit sign, bottom right.
Does this serve any purpose. I thought it showed what sort of vehicle was assumed Car Lorry Emergency etc but this doesn't appear to be the case.
Colin
That was fast.Boris - How's the turn restrictions working for you. It still seems screwy in 3.0. Sometimes a restriction would show where there is no street, and when it does show with a street nearby it'll turn off well before the street or into the street. I'd guess in the area I've driven it's about a 50/50 chance of being accurate.
They are totally messed up in 3.0 build. Maps are correct (routing is fine) but the iGO executable still is returning something pretty random for turnrestriction phasemodel...
Just tried to install 9-25 version but got an error:ui_igo8/common/trackinglist.spr Looks like it's referring a wrong directory. Appreciate any help.
These must be your color schemes. Not the skin.
If you tap the screen a circular image of a car appears just to the left of the speed limit sign, bottom right. Does this serve any purpose. I thought it showed what sort of vehicle was assumed Car Lorry Emergency etc but this doesn't appear to be the case.Colin
For both versions (2 and 3). Just like in stock navi, clicking the screen sets cursor at that position. After that, car icon moves but the map stays static. Clicking the car icon switches system back to "follow GPS" mode. (on stocvk screen you need to hit MAP to do that).
Sept. 28th update
- Fixed time placement when using AM/PM format.
- Added Shield display setting: Always/Never/Only when navigating.
- Can add POI as a VIA point, not only as final destination.
- Added Ukrainian keyboard to config/keyboard.ini
All thanks to Andr2000.
Another feature:
Can automatically substitute POI icons from iGo/defaults/poi_visiblities.txt:
After changing POI visibility settings in iGo/defaults/poi_visiblities.txt icon settings are reset. I.e. instead of
Petrol_StationKLO|petrol_station.klo|2500
there will be
Petrol_StationKLO||2500
If you need to temporarily turn a POI group on and then off, there's a patch in Visual Settings. You need the attached executable and default visibility TXT file:
iGo/poi_patch.exe
Great work! clock is back!
Mod still have a strange behaviors with turn restriction but, it seems has an igo's problem.
Great work! clock is back!Mod still have a strange behaviors with turn restriction but, it seems has an igo's problem.
Yes, whatever the program is returning as a turn restriction number seems to be pretty random. I still haven't figured a rhyme or reason to it...
Any chance of getting the tilt and zoom controls put in somewhere? Would be nice to be able to use those and not get stuck on whatever is set by the unit or hardcoded by the software
Even though there's no tilt and zoom settings on the map, it does work better in this version on my unit. I have my sys txt max tilt level at 8300 and both of tilt settings in the program set at 90. It gives me about 3/4 inch of sky.
I added the keepers quicklaunch buttons but never use them for tilt.
Stanislovovich, andr200 and Boris. I just wanted to say thanks again for all the work you guys put into this mod package. I put a few personnel modifications on it, but what you guys did is amazing. Thanks again.
I'll give those a try I think I'm at 85 for the tilt and not sure about the tilt level in sys.txt
I just translate the release notes and upload it... Stanislavovich and Andr2000 are doing all the hard work ![]()
Sept. 30, 2009 update
+ Added lite version of Multidraw from GJ&DVS1 skin. Avalialble through Multiplan -> Show on Map. Unlike the original, allows only viewing of routes. Chose desired route through Multiplan, as before.
To have routes displayed in different colors, add these to your color scheme's color.ini and color3d.ini files, after the line that defines planned_road_ext:
planned_road_alt1 = "",255,0,0 planned_road_alt2 = "",0,255,0 planned_road_alt3 = "",0,0,255 planned_road_alt4 = "",255,255,0 planned_road_alt5 = "",0,255,255
- Removed route delete confirmation when selecting "Return Home".
- Fixed: if you exit Multiplan without selecting a route, then select "Return Home," map would not be displayed (relevant only for Andr2000's 3,? port. Stanislavovich's oioginal works fine).
As usual, all thanks to Andr2000.
Boris,
Can you describe what you chnaged to allow chosing the desired rout in multiroute
Made the slight changes in my sys.txt and your right it is better and does work fine. Thanks
I'm always confused which is the latest 2.0 and 3.0 Version of the mod. Is it possible to make it easier on page 1?
For me i use version 2, cause i don't see any advantage to go to iGo 8.3 with this mod. Thank you guys for the work, i love it!
Esi
Esi
Stanislavovich is for 2.x, and Andr2000's port is for 3.x
Boris,
Can you describe what you changed in multirout to select the desired route?
Thanks,
Bryan
does this have the driver alert from gurjon? if not are you planning on adding it?
nothing. the only change there is an additional button to view all those routes
on the map. This is GJ&DVS1's MultiDraw extension. I've just reduced its
functinonality to read-only mode
what is this "driver alert"?
When using this mod, does it disable the MSN Direct?
I noticed it no longer overlays the traffic information or redirects me around traffic jams.
Thanks.
