Can someone tell me if there is a button, when in route to put in a next address???
So you can put in multiple addresses and make an optimal route?
Thx
Sounds like you want to add in a via point when in a route to a stop along the way.
This can be dine several ways:
1. If it's a POI you want to add a via for just search for it and click the button that says add via at the bottom of the POI details.
2. If you want to stop at a specific address while in route you can do this two ways:
A). Using plan mode; Go to the plan mode screen and do the search from there. Once you search the cursor will be on the address you entered on the plan mode screen. Expand the top most menu with the green arrow if not already done. Click add via to make it a stop along the way.
. Using the quick menu; When not in route the quick menu buttons will automatically start a route when you start a search from those buttons. When in a route already and you perform a search from the quick menu the search results will bring you to the plan mode screen. Once you do that just expand the menu if not already done and click add via.
It's much easier to do than to read. Try it out and the nav should know where you are (in or out of route) and guide you to the correct screen.
Hope this helps.
Alex
