AVIC-MRZ99 Custom Firmware / Testmode
By crankz · Oct 09, 2014in Hacks/Mods💬 972 posts👁️ 566,761 views
Page 34 of 39
Posted May 14, 2020 · 19:59 UTC#826
6 hours ago, shadrack said:
Many thanks Shadrack for the link to download the backup, which I have done.
My real problem with this unit MRZ09 as described in detail(with image ) on Page 47 and 49 is that the unit does not paste any file to USER folder including the backup. Do you or any one here has an idea what to do  to enable this backup wake up the unit.?
Posted May 30, 2020 · 05:58 UTC#827
Hi all in this useful forum,
I have another unit, Carrozzeria AVIC-HRZ099, that needs translation of menu from Japanese to English. Does anyone here has any idea how to do it? Is there any similarities with MRZ99?  Attached is the unit's card.
Please help and thanks in advance.
Posted Jun 10, 2020 · 14:42 UTC#828
On 04/01/2020 at 8:57 PM, Kikumu said:
Greetings, I have my avic mrz09 displaying the above screen of not loading programs and number 6 at the bottom any help on how to fix it. Regards
did you solve the problem please?
Posted Jul 03, 2020 · 07:17 UTC#829
On 26/03/2020 at 7:16 AM, shadrack said:
i was able to fix this error thanks alot.
how did you fix it please?? i would really appreciate your help.
Posted Jul 07, 2020 · 06:42 UTC#830
All hi.
I have AVIC MRZ09 does not display the image on the screen from the reverse camera.
The camera is on correctly and serviceable.
I found information that for normal operation you need to train a 3D sensor, without this it does not work.
Is it possible to replace a file that is responsible for training with a file from another tape backup?
Which file is responsible for this?
Posted Jul 07, 2020 · 14:04 UTC#831
On 19.04.2020 at 2:16 AM, Jhony said:
hello I have this problem in my avic-mrz09 and I want to copy the backup files and when copying nothing happens, the same thing happens when I try to delete any file from USER it does not delete them .... I would be very grateful for your help
Hello! I have the same problem on mrz-06, but the number on bottom "7"
Привет всем, аналогичная проблема при запуске. Кто-нибудь нашел решение проблемы?
Edited Jul 07, 2020 by Valik_nsk
Posted Jul 08, 2020 · 06:26 UTC#832
14.05.2020 в 08:48 Шедрак сказал:
Привет, вот ссылка на файлы резервных копий mrz 07
https://yadi.sk/d/hGnQktfNFBcchw с  наилучшими пожеланиями
21.11.2016 в 10:54 air22 сказал:
Hello, is there any recent files for translation from Japanese to English on MRZ-09. The link that you previously threw does not work. Thanks
Posted Jul 09, 2020 · 12:39 UTC#833
On 06.03.2020 at 13:25, Shtirlitz said:
Здравствуй @Mwassaru
Просто используйте источники:  https://github.com/Shtirlitz/RZ09
Вырежьте 0x200 заголовок PRG-файла - вы получите прошивку .NB0.
Извлеките файл initDB.dat из файла .NB0, используйте мои инструменты для перевода.
Замените переведенный файл initDB.dat в .NB0 и используйте makever.c для создания обновленных файлов FW.
Вот пошаговое руководство (2 сообщения):  http://4pda.ru/forum/index.php?showtopic=847671&st=20#entry90149444
Это на русском, но я думаю, что это легко перевести на английский.
Удачи!
Alex
привет Алекс ,подскажи а нельзя в rw09 поменять языковой файл как в mrz99.
Posted Jul 19, 2020 · 05:16 UTC#834
On 7/7/2020 at 2:42 PM, fry740 said:
All hi.
hi bro. can you show me where is the mrz09 reverse camera port ? Because i dont know my mrz09 (japan model) have or not. Appreciate your respond and thanks in advance.
Posted Jul 30, 2020 · 22:07 UTC#835
I have mp310-a radio. Tried replacing the langdata files and messed up before i backed up, now the radio is still working but doesnt show texts on the boxes for menu. I gues i messed with the original files other than what i was supposed to replace. I either need the original prg0 and prg1 or either get a solution to get english text on the menu boxes. Thanks in advance
Posted Aug 17, 2020 · 13:19 UTC#836
Hi Dzo
I've MRZ09 but is not starting up sometimes is showing blacks screen with number 6, other 7 and 10 what can i do
Posted Aug 26, 2020 · 02:24 UTC#838
can the avic mrz05 change to english ?
Posted Aug 28, 2020 · 23:23 UTC#839
HI guys!
How r u? Sorry for my English in advance, I am not English speaker)))
Most of the letters in your messages are no appears on my computer correctly (please have a look to atached file below), it appears like unknown symbols.  I have a trouble witth Mitsubishi NR-MZ03 (as Google told me, it is close similar to MRZ-03). After few tryings to change language (ofcourse without saving backup((() my receiver stats to work abnormal. Language still Japanese.
1.After turning ON it starts playing music and display shows normal screen.
2. After few second receiver instantly turns off without any notificaions on the display.
3. No access to Boot Menu by pressing NAVI-right-left-right-left-right-left.
Appreciate if you share some info about reinstalling firmwire by using autorun on flash card etc.
Thanks in advance.
Edited Aug 28, 2020 by Dee_Tkm — Reason: Photo atached, made some amendments for text
Posted Sep 06, 2020 · 08:34 UTC#840
I Have an MRZ-02 and while trying to update from the files provided here, I deleted PRG0 from the USER folder by mistake. Can someone who has an MRZ-02 available give me a copy of PRG0 since that is where the PRG.FLG was please?
Thanks in advance
Edited Sep 06, 2020 by SimRacing
Posted Sep 17, 2020 · 03:00 UTC#842
Hello everyone! I have a avic-zh07, is it possible for translate to english?
Posted Oct 05, 2020 · 07:31 UTC#843
Hey guys! This worked awesome on my MR77 but will it work the same with the AVIC RZ300? I am scared to use the USB method because its a newer model. Also, how can I edit or create my own .lng file? Thank you DZO
Posted Oct 19, 2020 · 22:48 UTC#844
Hey guys, I bought a Honda Fit and it came with Avic RZ33. I want to switch the clock. It seems, the clock is set for Japan time zone and I wanna change it to European zones. Is there anyway to do it? My radio is in Japanese language so, any pictures are welcome here :)
Thanks in advance.
Posted Oct 20, 2020 · 16:01 UTC#845
Thanks in advance.
Hello!
As far as I know, there is no manual setting in our devices (I have AVIC RZ-05).
I read somewhere that to configure you need to connect a GPS antenna and the system itself will set the clock on the device after some time. I have no antenna, I have no way to check it.
Posted Oct 20, 2020 · 20:32 UTC#846
On 07/09/2019 at 2:23 AM, DriveNSK said:
Hi Alex
The instruction is excellent, everything worked out.
Made a copy (Just in case)
Thanks again!
Hi,
I have the above backup, but cannot copy or paste , as these options do not appear on teh menu,
am I doing something wrong? DZo, can you please advise?
Posted Oct 21, 2020 · 07:58 UTC#847
On 31.07.2020 at 07:07, morris mwenda said:
У меня есть mp310-a радио. Попробовал заменить файлы langdata и все испортил до того, как я сделал резервную копию, теперь радио все еще работает, но не показывает тексты на полях меню. Я думаю, что испортил исходные файлы, кроме тех, которые должен был заменить. Мне либо нужны оригинальные prg0 и prg1, либо нужно найти решение для получения английского текста в полях меню. Заранее спасибо
15961467951391250370187.JPGbekup prg
Posted Oct 21, 2020 · 08:17 UTC#848
15 hours ago, DriveNSK said:
Hello!
Hey man, thanks for the reply. I think there is a gps antenna connected to my car but I don't think it is working. I see a black small box shaped next to front glass. I checked some settings in my radio and it showed me like 9 red sattelites instead of green ones. Any ideas how to switch that? I live in Cyprus, North side.
Posted Oct 21, 2020 · 14:20 UTC#849
Watch this video. Try to do the same.
I hope it helps you)
https://www.youtube.com/watch?v=-cEdovxMMfU
Posted Oct 21, 2020 · 14:34 UTC#850
18 hours ago, Schubawi said:
Hi,
Is the testmode.key file correct?
If it's not correct, you won't be able to copy or write.
Try other files if the one you have doesn't work.
Page 34 of 39
