All Activity
- Today
faerss2 joined the community
saq joined the community
cetayi2912 joined the community
- Yesterday
burhanlc joined the community
RonS replied to RonS's topic in Hacks/Mods
What model are you trying to update? It is likely you don't have the correct cardinfo file. -
Pen3 replied to RonS's topic in Hacks/Mods
I need some help. After i installed the shortfuse and it says i am ready to update the map. I remove the sd card and restart the unit. I inset the sd card with the map update, but nothing happens. Is it possible to use the supertest mode and force install the update? - Last week
RonS changed their profile photo
boyoboyletsgo joined the community
Is your parking brake set (or has it been bypassed)? Maybe it was never wired. Many settings can only be changed when the parking brake is set. In fact, this is controlled by the "Safe Mode" set to On. Is this a newly installed unit, possibly a used one? "Safe Mode" defaults to On. So it sounds like someone had previously turned it Off Disclaimer: mine is a US unit (Z110-BT), and we don't have a "Safe Mode" option. So I'm guessing about the behavior of "Safe Mode" based on looking in the F-9xx series user manual.
It's possible that the headunit needs power to boot up fully and access the bootloader via UART. Try connecting it to power and then retrying the UART connection. Ensure the baud rate matches and check for any hardware or wiring issues.
- 720 replies
nathan25 joined the community
https://mega.nz/folder/PNhjXCyZ#i27AkYewqDz9y5I1EW8ywQ/file/CEgyyQSJ European model (EW):AVIC-Fx60_EU5_FW_Ver_120.Zip
scaneraSheef joined the community
Sooo, should I download test mode and that way try to instal older firmware version ? But in this mega there is only 1.14 for eu and image I put on SD is 1.15
https://mega.nz/folder/PNhjXCyZ#i27AkYewqDz9y5I1EW8ywQ/folder/CApgnQIK
Williams Forrest joined the community
tim wood started following F930bt stuck in safe mode
Help please, stupidly clicked on safe mode. Now can't even enter password. Tried positive direct from battery to yellow and red wires but still get greyed out keyboard. Thanks in advance
Can You explain to me like I'm dumb ?
It is necessary to check what updates from 1.15 to 1.21 ... and set them in order
This ! Exactly what I mean. It would be really nice if one skilled developer could make some kind of an app or website with all files, scripts, apps and instructions that are needed to keep those devices up and running or resurecting if failed already. And explain it with words simple enough that people that are handy with computers and stuff but are not programmers could understand it and make it work. I know that servers, hostings etc costs money, so access to all the knowledge and database could be behind some few dollars paywall.
- 720 replies
Ok, I made a new SD card with image and unit started to the system, then I downloaded upgrade to 1.21 put it on usb stick and into the first USB slot, started update thru menu like the instructions says and then I got "update failed", unit no longer starts to the system, and SD card cant be read by any of my computers, so I bought new SD card, put an image on it, put it into unit and its still trying to install update even without usb stick in unit, after powering on I only get "Reading, please wait for a while" then "failed" ... Any clues ?
lucassanabria started following Help with AVIC-H99
Hi!! I have this two units: AVIC-H99 and AVIC-V77MD, and the HDD of the H99 gone bad, and I need the system image to restore in another HDD. Can someone help me with this please?? Thanks in Advance!! Lucas.
- Earlier
http://avic411.com/index.php?/topic/90861-fix-sdcard-failed-software-error-on-your-w4500nex-look-here/&do=findComment&comment=364060
Ive been trying to make a backup of a newly purchased sd card. I need some guidance as I am at my wits end with this. I have booted into linux mint which I am told should be able to read this card format, it can't.... I am experienced with linux and even command line only linux from days past. I am not able to mount this card at all while other sd cards from cameras etc. work just fine. gparted doesnt see this card either. How are you guys able to make a copy of the card before putting it into the head unit. I am trying to share it here even when done. Id like to make a backup .img fil
Ok....this is frustrating. I made a bootable usb drive and loaded linux mint on it, boots up fine and recognizes various other cards form cameras etc. but not the stupid android formatted pioneer one. How on earth have you guys made copies of these cards!!!???
I believe that both my usb and sd card are formatted in FAT32. My usb is only 128gb, can’t remember the size of the sd card. Both work fine.
For a long time, I've used an iPod Classic modded with SD cards for 512 gb of memory. Recently with my other car, I discovered iPod Classics are no longer supported, and since neither is iTunes, I thought about modernizing. I used Media Monkey to build a library on a 512 gb flash drive. It works in that car. Decided to do the same for my vehicle that has the AVIC7200NEX. I've now tried loading the library 5 times, but every time it freezes at 60% formatted and i can't select songs or artists when that happens. The drive is a 512 formatted in NTFS. Has anyone gotten a flash drive to work?
Hello everyone, Quick question, this link contains folder F60_1.15 with F860.rar is it right image for AVIC-F860BT for EU market ? If it will work on new SD card should I update to 1.21 downloaded from pioneer website ? https://mega.nz/folder/ezY1FYhb#ued2oydxeZula3ZTm6p1ng
w4500nex [FIX] SDCard Failed? Software Error on your w4500nex? Look here!
mahdi replied to slackwaredragon's topic in NEX Series
hi if you find please sey to me my avh-z9250 touch not working -
Good Luck brother. Hope it works for you since it did for me.
I had researched this enough to know that, so I still have not installed it into my head unit. I am going to attempt to make a back up image of later today if I can make time. Thanks!
Thank you I will purchase a usb sd card reader today and boot up linux mint and hopefully it works. Will report back!
