dianebrat Posted October 17, 2010 Report Share Posted October 17, 2010 Mine still stops working after 10 mph. My connection is good. Should I ground the parking brake, mute, and ground cable seperately?? Please help. It means the relocated mute wire part of the bypass isn't done correctly Quote Link to post Share on other sites
Element1208 Posted October 21, 2010 Report Share Posted October 21, 2010 I have a 700bt that was supposedly bypassed by the installers. They added a switch that was supposed to bypass the parking break and allow me to watch video, access navi, phone...Anyhow, I relocated the mute wire and grounded to factory ground wire location, but left the parking brake wire alone. I figured they already grounded it with a switch. I played video off of my ipod and the bypass worked fine. Drove past 15mph...worked fine. Phone dial pad worked, navi worked...I thought everything was going good. Then all of a sudden, the whole radio shut off. Turned the radio back on, ipod wasn't recognized, so i unplugged the ipod and plugged back in. Then ipod started working again and I played the video again. Worked fine, but a couple of minutes later...same thing...radio shut off. Repeated the same steps, same result. Radio even shuts off when I'm parked watching video w/ parking brake down. Any thoughts on what could be going wrong? The bypass "switch" is in the position to simulate ground(I think this is what the switch is supposed to do). Why would it work fine, and then after a while not work at all? Should I try resetting the unit? Thanks in advance for any insight into my problem! Update: I grounded both the relocated mute wire and parking brake wire. Video will play from the ipod for about 10-15 minutes before the whole unit shuts off. I was able to play video off of the SD card and from a flash drive with no problems. So the problem occurs only when playing video from the ipod. Quote Link to post Share on other sites
WM. Posted December 2, 2010 Report Share Posted December 2, 2010 does the vss wire still have to be connected for this bypass to work. Please give a full description of what needs to be connect beside the obvious bypass!!!!! Quote Link to post Share on other sites
VBLUE42 Posted December 2, 2010 Report Share Posted December 2, 2010 The VSS has nothing to do with the bypass. Quote Link to post Share on other sites
casemods Posted December 29, 2010 Report Share Posted December 29, 2010 When I got the unit, the guy told me to ground the yellow wire along with the obvious ground wire. Maybe he didn't move it? Or I probably wired it wrong. I'm going to look tomorrow. Can anyone post pictures of before or after? Quote Link to post Share on other sites
VBLUE42 Posted December 29, 2010 Report Share Posted December 29, 2010 http://avic411.com/index.php?app=forums&module=forums§ion=attach&tid=13475 Its all right there dude. All you gotta do is look. Quote Link to post Share on other sites
Join the conversation
