ANTP228 Posted August 4, 2008 Report Share Posted August 4, 2008 i have had a similar problem with an ipod, the cable is faulty or there are loose pins in it, on the one i had i reset the loose pins and then dropped in a little hot glue to keep them all steady.problem solved!! Quote Link to post Share on other sites
Rds10005 Posted August 4, 2008 Report Share Posted August 4, 2008 i have had a similar problem with an ipod, the cable is faulty or there are loose pins in it, on the one i had i reset the loose pins and then dropped in a little hot glue to keep them all steady.problem solved!! Can you take a picture of what you've done? I'm having problems visualising it. Quote Link to post Share on other sites
ryan420 Posted August 4, 2008 Report Share Posted August 4, 2008 yo probally dont want to use glue cause u will never be able to take the connector off the unit again.. or when the glue hardens wil not be able to plug it in Quote Link to post Share on other sites
ryan420 Posted August 4, 2008 Report Share Posted August 4, 2008 you probally dont want to use glue cause u will never be able to take the connector off the unit again.. or when the glue hardens wil not be able to plug it in..if u have a multi meter then do a resistance check on each end of the plug to see if u have broken or high resistance in the wire each should read the same Quote Link to post Share on other sites
ANTP228 Posted August 4, 2008 Report Share Posted August 4, 2008 no you dont glue the unit and plug together i mean you drop some hot glue into the back of the plug where the pins slide into the grooves, of the i pod cable Quote Link to post Share on other sites
Kebo72 Posted August 11, 2008 Report Share Posted August 11, 2008 OK folks my issues must have been the pioneer ipod cable after all. I've had my new cable in for 4 days now and everything works perfect. Quote Link to post Share on other sites
bluesti Posted August 12, 2008 Author Report Share Posted August 12, 2008 Looks like I'll be going to get a cable! Quote Link to post Share on other sites
jahlinux Posted August 14, 2008 Report Share Posted August 14, 2008 I'm having the same problem with the new iPhone 3G. If a lot of people are having the same problem how will getting a new cable fix the problem? Can you use something other then the Pioneer cable? Quote Link to post Share on other sites
Kebo72 Posted August 15, 2008 Report Share Posted August 15, 2008 I'm having the same problem with the new iPhone 3G. If a lot of people are having the same problem how will getting a new cable fix the problem? Can you use something other then the Pioneer cable? I think Apple makes a cable that should work just the same as the Pioneer and I think the Apple Cable is a little cheaper believe it or not. Quote Link to post Share on other sites
jahlinux Posted September 9, 2008 Report Share Posted September 9, 2008 Are people still having good luck after replacing the cable? I'm having mine replaced next week so I hope that fixes the problem. Quote Link to post Share on other sites
Kebo72 Posted September 9, 2008 Report Share Posted September 9, 2008 Are people still having good luck after replacing the cable? I'm having mine replaced next week so I hope that fixes the problem. Mine works fine after replacing the cable. Yours should too. Quote Link to post Share on other sites
jrdiesel Posted September 11, 2008 Report Share Posted September 11, 2008 I had a similar problem. The negative pin broke on the front left RCA input at the white harness on the back of the deck. http://avic411.com/forum/viewtopic.php?t=17786 Quote Link to post Share on other sites
bluesti Posted October 8, 2008 Author Report Share Posted October 8, 2008 Yep... replaced the ipod cable, and it's been fine for about a month now! Quote Link to post Share on other sites
methodbasic Posted October 24, 2008 Report Share Posted October 24, 2008 can anyone else confirm this is the ipod cable and not the ground wire(s) on the white plug? Quote Link to post Share on other sites
lasrx Posted October 30, 2008 Report Share Posted October 30, 2008 Is the cable warrantied by Pioneer? This cord costs $50! Quote Link to post Share on other sites
Join the conversation
