NickyD32 Posted August 22, 2008 Report Share Posted August 22, 2008 so i was listening to my ipod, and recently has been playing fine then saying "ipod connection failed. please reconnect" ... anyone else having this problem? i bought a unit with the new firmware already installed. ... anyone have a fix? Quote Link to post Share on other sites
leetcoder Posted August 23, 2008 Report Share Posted August 23, 2008 Same here, im having the same problem. Its very annoying that I have to unplug the usb and then replug it back in. Quote Link to post Share on other sites
VBLUE42 Posted August 23, 2008 Report Share Posted August 23, 2008 Its happened to me a couple of times along with some bluetooth instability. Just part of the overall instability of the F series os. There's still work that needs to be done on these units. There is a rumored Update 2 coming out so lets hope this stuff is addressed then. Quote Link to post Share on other sites
cigga24 Posted August 28, 2008 Report Share Posted August 28, 2008 Mine started doing this as well with a 5th gen 30gb. Also i started receiving static in my sound and low volume. Anyone else notice this or should i start a new thread? Quote Link to post Share on other sites
Media Man Posted August 29, 2008 Report Share Posted August 29, 2008 Mine started doing this as well with a 5th gen 30gb. Also i started receiving static in my sound and low volume. Anyone else notice this or should i start a new thread? same here. I called Pioneer and gave them detailed descriptions of the problems. They for some reason they sounded surprised on the other end of the phone. Their solution was assanine. I was told there was no plans for a second update and I would have to send my unit out for repair and go back to my factory stereo until they can figure out the problems, with no time frame for getting back the unit. BS I called Cruthcfield and they sent me a new unit, at least one company knows about customer service. Quote Link to post Share on other sites
cigga24 Posted August 29, 2008 Report Share Posted August 29, 2008 Well i think i got my static worked out. I used a friends 6th gen nano and noticed the connector fully connected with his unit. on my 5G it was a little loose and i could wiggle it. So i just started wiggleing it in then it locked into place. Hopefully that does the trick. Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted August 29, 2008 Report Share Posted August 29, 2008 I get a failed connection at least once a day. Quote Link to post Share on other sites
1fastrsx Posted August 31, 2008 Report Share Posted August 31, 2008 I also get failed connection on my 1g ipod Nano. Irritating to say the least. Quote Link to post Share on other sites
swede67 Posted September 1, 2008 Report Share Posted September 1, 2008 When I first installed my unit, I was using my 4GB 3rd generation nano with no problems whatsoever. A couple of days ago, I started using my 30GB video (5th generation), and have had numerous disconnects. I'm not sure what the difference is between the iPods, but the nano definitely works better than the video. Quote Link to post Share on other sites
CDN James Posted September 1, 2008 Report Share Posted September 1, 2008 I get a failed connection at least once a day. im with you.. MIN of once a day... which has become more like several times a day since i'm in and out of my truck a few times a day (work and personal truck all in one) it doesn't matter if i'm using the ipod or not, the error just shows up regularly. Quote Link to post Share on other sites
HiFiSi Posted September 1, 2008 Report Share Posted September 1, 2008 I've had 4 or 5 since i bought the unit back when it was first released... And it only seemed to do it when it was really really hot outside and my car had been sitting in the sun with the windows up. Quote Link to post Share on other sites
parisioa Posted September 2, 2008 Report Share Posted September 2, 2008 mine fails within two minutes of starting my car 50% of the time. if i start/stop 10 times in one day (only done this once), it dies like 95% of the time. this is really getting annoying. on a side note, i'm using the Apple iPod cable, not the pioneer one. what does everybody else have? Quote Link to post Share on other sites
CatchMeIfYouCan631 Posted September 2, 2008 Report Share Posted September 2, 2008 I'm using the Pioneer cable. I forgot to mention. Aside from it failing, I leave my iPod in the car, unless I bring it with me to work, and if it stays in the car, the unit doesn't even reconize it unless it unplug/plug it back in. Does anybody else have the problem? I'm using an 80 gig video Quote Link to post Share on other sites
parisioa Posted September 2, 2008 Report Share Posted September 2, 2008 I'm using the Pioneer cable. I forgot to mention. Aside from it failing, I leave my iPod in the car, unless I bring it with me to work, and if it stays in the car, the unit doesn't even reconize it unless it unplug/plug it back in. Does anybody else have the problem? I'm using an 80 gig video I'm using a 60gb video 5th gen Quote Link to post Share on other sites
CDN James Posted September 2, 2008 Report Share Posted September 2, 2008 I'm using the Pioneer cable. I forgot to mention. Aside from it failing, I leave my iPod in the car, unless I bring it with me to work, and if it stays in the car, the unit doesn't even reconize it unless it unplug/plug it back in. Does anybody else have the problem? I'm using an 80 gig video i leave mine in the truck all the time, just like a hard drive. only time i remove it is to reload the music or see if there is an update avail. i have the 30g video.. mine doesn't usually fail first start of the day, just the rest of the day almost everytime i use the truck .. and the start of the day, is a 60% working, rest is fail Quote Link to post Share on other sites
