wizzardeel Posted January 3, 2009 Report Share Posted January 3, 2009 is there any way that somebody can send me a small silence.wav file? because i downloaded one and its 170kb which is bigger than the 40kb ones that the navi had. thanks. pm pe with the silence.wav file Quote Link to post Share on other sites
dannyavic Posted May 17, 2009 Report Share Posted May 17, 2009 You guys don't need to replace the wav files. Simply create a new folder, and drag and drop those 4 files into the new folder. Thus you delete and backup in one step. You don't need to replace the files. They don't program the software as some flawless program.. it would be terribly bloated if they did. They obviously didn't putin a "check for wav file, if missing EXIT" line in their code.. worse case scenario if they did, they may have put "check for wav file, if exist play it, if not, skip playing it" line. People have already stated they have deleted the file successfully. You can too. If you put a dummy file in there then you are giving it an extra order to carry out that you dont' need, and in theory that is slower. As far as deleting states you dont' need... That depends on what GPS software you're using. I use IGO 8 and it doesn't load all of the maps by default, it loads them as needed, like when you type in a state with it's address or you cross state lines. HOWEVER There *IS* a benefit to being tidy and neatly tucking away the states you don't need. Go into your igo8/content/map directory... create a new folder.. and move all the maps you rarely need (once a year) there. Thus you eliminate them from the drop down choice menu for your day to day selection, instead of having to scroll through multiple menu screens of states you dont' need to get ot the ones that's physically closer but not alphabetically. For instance, I on a daily basis live in a tri-state area, but i also go down the east coast once a year.. so I put all those states outside of the tri-state area in the new folder to pull them bakc up later for that out of area trip.. but now on a daily basis when i need to change states, there's the only 3 I have right in the menu and no scrolling through useless states. That's a time saver and annoyance saver. Quote Link to post Share on other sites
jevans102 Posted December 18, 2009 Report Share Posted December 18, 2009 Love the advice in this thread and can't wait to try it out! Keep it up everyone! Quote Link to post Share on other sites
69sixpackbee Posted December 18, 2009 Report Share Posted December 18, 2009 That's atime saver and annoyance saver. True, but in the case of needing more memory I had to delete the uneeded states altogether so I could use more graphics and more schemes. Memory is memory and once it gets close to being full you cannot believe how slow these things operate! Bud Quote Link to post Share on other sites
Ramon Posted December 22, 2009 Report Share Posted December 22, 2009 Hi I was just wondering if I delete these four sound files then I would lose the key beeps for entering characters on the keyboard too? thanks Quote Link to post Share on other sites
Join the conversation
