wratran Posted September 15, 2006 Report Share Posted September 15, 2006 i downloaded the 60MP east torrent w/ an Alcohol 120 image...but the file keep saying "invalid format"... Does anyone know how to fix this? The west disk image was OK Quote Link to post Share on other sites
boost3dsupra Posted September 17, 2006 Report Share Posted September 17, 2006 when you unrar the file make sure you remove the "set file security" check box in the advanced tab of winrar and check "clear attributes archive" Dont know if you need this but i did it anyways. Then I used poweriso to burn the image the mdf file not the mds. Used a verbatim DVD+R DL at highest speed and worked fine. Hope this helps Quote Link to post Share on other sites
toolbag0w5 Posted September 20, 2006 Report Share Posted September 20, 2006 where did you find this torrent? Quote Link to post Share on other sites
engravingtags Posted October 3, 2006 Report Share Posted October 3, 2006 boost3dsupra you are the shiznit!!!! I have been trying to fix this issue for the longest... settings in winrar... ahh heck!! thanx much. I travel so much, and needed these maps!!! Quote Link to post Share on other sites
law 3 Posted November 21, 2006 Report Share Posted November 21, 2006 does the n1 load the 60mp disk automatically or do i have to make any adjustments Quote Link to post Share on other sites
bcd1 Posted November 22, 2006 Report Share Posted November 22, 2006 law 3 from what I've read it automatically updates when you insert the dvd. BCD1 Quote Link to post Share on other sites
law 3 Posted November 22, 2006 Report Share Posted November 22, 2006 bcd1 i had a friend burn the torrent for me maybe it was not done correctly when i insert the disc it says reconizing disc the screen turns white then black then back to the normal screen Quote Link to post Share on other sites
tillithz Posted November 22, 2006 Report Share Posted November 22, 2006 you arent burning a torrent. or you shouldnt be. burn the files directly to the root or an image with like nero. it should be pretty simple Quote Link to post Share on other sites
law 3 Posted November 25, 2006 Report Share Posted November 25, 2006 do i have to convert the mdf file to iso because when i try to copy the mdf file it says error verifying the iso with power iso nero and imageburn im kinda in spindle heaven right now Quote Link to post Share on other sites
tillithz Posted November 25, 2006 Report Share Posted November 25, 2006 welp, i would guess that you have to burn the file with a compatible burner. I dont recall what is compatible with md5. but I believe I posted the file your working with on the newsgroups and it probably is still there. Quote Link to post Share on other sites
gordata Posted December 6, 2006 Report Share Posted December 6, 2006 Ok, I think I already burn my first torrent. I used nero to burn a DL Dvd, My question is do I burn the MDF file or do I have to open it and burn all the files inside there. Quote Link to post Share on other sites
kaotek Posted December 6, 2006 Report Share Posted December 6, 2006 Burn the .mdf file..i use dvd decrypter and i burn the .mdf and it work for me.. Quote Link to post Share on other sites
free_refil Posted December 12, 2006 Report Share Posted December 12, 2006 I took my unit in today to be modded to an N3. The guy who does the mod's told me to watch out for downloaded ISO's because there's one out that will fry the GPS capabilities of the unit when loaded. He also told me how to tell the difference. He said that when you first load the software, if the screen says 1/1 instead of 1/2 when the loading first begins, you should cut off the unit immediately or it will corrupt the unit. However, I have been running N3 software on my N2 for quite some time and I also acquired it off of a .torrent. However, it worked perfectly fine. I hosted the .torrent myself for some time, and also created the first .torrents of the v1.2 of the N2 software (50MP I believe). I still have the image file on my PC and if there is an issue with the .torrents everyone here is using, I will recreate a torrent and post it up so that a working copy can be utilized. Note, as I do have both the East and West disks, I loaded my copy utilizing the East DVD and have not in fact burned and used the West DVD. Quote Link to post Share on other sites
hunter_michael Posted January 6, 2007 Report Share Posted January 6, 2007 What is the .mds file ? Quote Link to post Share on other sites
free_refil Posted January 6, 2007 Report Share Posted January 6, 2007 It's a file you need to burn it with Alcohol. Quote Link to post Share on other sites
