interplay Posted January 5, 2009 Report Share Posted January 5, 2009 Does it make any difference whether you are using 1.0 or the 2.0 update? Please post the firmware you are using. Thanx Quote Link to post Share on other sites
hkgms3 Posted January 28, 2009 Report Share Posted January 28, 2009 Has anyone see this issue? Before this mod,when I make a call from the unit, once the call was dialed, the "end call" bar pop up. After the mod, the "end call" will not show after the other end of the call disconnected. I saw this issue under a few different conditions such as in route, not in route, I called, and someone else called in. Any comment? Quote Link to post Share on other sites
bigdaddy496 Posted May 23, 2009 Report Share Posted May 23, 2009 sounds great, but i actually live in germany! how can i get the benefits of this without any issues? im tring to mod my unit right now so it will run european maps Quote Link to post Share on other sites
timored Posted May 24, 2009 Report Share Posted May 24, 2009 One question. I just bought a f900bt and how to i access any of these files? Arent they on the harddrive off the f900bt? Please help. Thanks, TIM Quote Link to post Share on other sites
ill.die.trying Posted May 24, 2009 Report Share Posted May 24, 2009 One question. I just bought a f900bt and how to i access any of these files? Arent they on the harddrive off the f900bt? Please help. Thanks, TIM please start reading the hacks thread Quote Link to post Share on other sites
Nikos_GR Posted May 27, 2009 Report Share Posted May 27, 2009 I just did that mod to my Euro F900BT and works fine! It almost made button response immediate! I think that button response IS immediate, but what gives you the feeling that takes time, is the long wmv file with the "ding" sound, which I think is too long (there is silence in the begining and in the end of the file). I am going to "chop" the wmv file a bit or find something else, "shorter". I will let you know... Congrats to thextreme1! Quote Link to post Share on other sites
meCka Posted June 1, 2009 Report Share Posted June 1, 2009 so what about those that are in California? what do i remove and what do i keep ? Quote Link to post Share on other sites
Nikos_GR Posted June 1, 2009 Report Share Posted June 1, 2009 I checked the sound files for the "ding" when pushing a button. The sound lasts 0.100secs and the whole file is 0.500secs. So there are 0.400secs of silence! I chopped it a bit, keeping just the first 0.100secs and the response improved, specialy when changing radio stations (because you hear the next station about 0.400secs faster!). Also the file got smaller (40KB original, 17KB the new one) so I believe it loads faster! The files are in DATA.ZIP in the folder \audio\. Those that I changed are the most used and are (all incuded in the wavfiles.zip): !back.wav !button.wav !checkoff.wav !checkon.wav !click.wav !invalid.wav !radio.wav !sectionbeepA.wav !success.wav Quote Link to post Share on other sites
meCka Posted June 2, 2009 Report Share Posted June 2, 2009 awesome ill try it out now with those wav files? so does anyone know what do i remove and keep in the preload file if im in CA? Quote Link to post Share on other sites
Nikos_GR Posted June 2, 2009 Report Share Posted June 2, 2009 awesome ill try it out now with those wav files? so does anyone know what do i remove and keep in the preload file if im in CA? I would recomended you to keep a backup of your original file and follow the instructions of the initial post (just keep section [1]). The worst case scenario that I can imagine (I am not 100% sure) is the AVIC to load data when you actually need it and not already preload it when booting. But even if things won't work at all, you just put back your backup file. In my previous post I forgot to attach some extra sounds that you can find in \Flash Disk\DATA\Sound\ : PSG1Hi.wav PSG1Low.wav PSG2Hi.wav PSG2Low.wav PSG3.wav PSG5.wav VR.wav I would recomend to everyone to keep a backup of the original files, just in case. If someone didn't keep the original ones and need them, I've got them all,so just ask... Quote Link to post Share on other sites
DonMac21 Posted June 2, 2009 Report Share Posted June 2, 2009 Great find. Changing my settings today. Just noticed alot of .xpd files in the same folder for Europe I think. ie..._AUT,_BEL,_CZE,_DEN, etc Just wondering if I can delete all of them if I am only using North America Maps? Quote Link to post Share on other sites
Join the conversation
