ovalball Posted January 23, 2010 Report Share Posted January 23, 2010 Just realised my Smartzoom reverts to OFF each time I turn my unit off.Any ideas please? Assuming you have tried deleting the user\userdata\igo\save files. Look at the settings you have in sys.txt Delete user\userdata\igo\save files again startup and set the smartzoom do another startup and check if it's working in and if not look at the user\userdata\igo\save\system.ini post your smartzoom settings from system.ini Cheers 34by151 That's sorted it,thank you.I think it was the settings within sys.txt that was the problem.Thanks very much for your help. Quote Link to post Share on other sites
ovalball Posted January 23, 2010 Report Share Posted January 23, 2010 Ok guys...I'm very busy with my work and social commitments and I'm on the edge to get ill (like a lot of others... ).But if you all want I can up the EU version of 2.3 but be aware that TMC does not work... I added the links on the first page. Can someone tell me if they are seeing strangeness under the TMC config screen? Installed with no problems.TMC button works just fine No strangeness in my settings......... Quote Link to post Share on other sites
rwijnhov Posted January 23, 2010 Report Share Posted January 23, 2010 with me i am missing some tmc settings and it doesn't work. Quote Link to post Share on other sites
Segler1963 Posted January 23, 2010 Report Share Posted January 23, 2010 Ok guys...I'm very busy with my work and social commitments and I'm on the edge to get ill (like a lot of others... ).But if you all want I can up the EU version of 2.3 but be aware that TMC does not work... I added the links on the first page. Can someone tell me if they are seeing strangeness under the TMC config screen? Haven't installed it yet, but on the first glance SYS.TXT points to device 746UC instead of 746EW, hence TMC cannot work. If I have time I will edit the sys.txt and install today Jörg Quote Link to post Share on other sites
Segler1963 Posted January 23, 2010 Report Share Posted January 23, 2010 Ok guys...I'm very busy with my work and social commitments and I'm on the edge to get ill (like a lot of others... ).But if you all want I can up the EU version of 2.3 but be aware that TMC does not work... I added the links on the first page. Can someone tell me if they are seeing strangeness under the TMC config screen? Haven't installed it yet, but on the first glance SYS.TXT points to device 746UC instead of 746EW, hence TMC cannot work. If I have time I will edit the sys.txt and install today Jörg OK, installed it and TMC works with the edited SYS.TXT! There is no TMC Button though! There are a few things which I propably have to understand before I can comment or give feedback, but so far it looks great. The TMC button is the only thing I'm currently desperate for. I also might change the angles for 3 D in SYS.TXT, but thats a personal preference. Jörg Quote Link to post Share on other sites
ovalball Posted January 23, 2010 Report Share Posted January 23, 2010 On mine,TMC button is in the quick menu,and works fine Quote Link to post Share on other sites
Segler1963 Posted January 23, 2010 Report Share Posted January 23, 2010 On mine,TMC button is in the quick menu,and works fine Yes, I have it there as well, but as I use it quite often during navigation, thought on screen would be nice. In the quick menu you save just one click compared to stock. Maybe Merten or Diaftia can use the speedsign to access TMC Jörg Quote Link to post Share on other sites
ovalball Posted January 23, 2010 Report Share Posted January 23, 2010 On mine,TMC button is in the quick menu,and works fine Yes, I have it there as well, but as I use it quite often during navigation, thought on screen would be nice. In the quick menu you save just one click compared to stock. Maybe Merten or Diaftia can use the speedsign to access TMC Jörg Yes,having it on screen would be ideal.I'm sure if it can be done Alex will do it Quote Link to post Share on other sites
34by151 Posted January 23, 2010 Report Share Posted January 23, 2010 Maybe Merten or Diaftia can use the speedsign to access TMC In navigatemap_800_480.ui Change this ;Posted Speed To This ;Posted Speed Currently clicking on the Speed Limit Sign will add a new speed cam. With the change above this will happen on a long click. A short click will take you to the TMC events Cheers 34by151 Quote Link to post Share on other sites
ovalball Posted January 23, 2010 Report Share Posted January 23, 2010 Maybe Merten or Diaftia can use the speedsign to access TMC In navigatemap_800_480.ui Change this ;Posted Speed To This ;Posted Speed Currently clicking on the Speed Limit Sign will add a new speed cam. With the change above this will happen on a long click. A short click will take you to the TMC events Cheers 34by151 That works absolutely spot on.Thanks very much. Quote Link to post Share on other sites
AndreasF Posted January 23, 2010 Report Share Posted January 23, 2010 Diaftia, Jörg, 34by151, Thanks! You are my heroes!! Now everythings works, as it should do! TMC works and a easy access to TMC is possible, kind regards Andreas Quote Link to post Share on other sites
merten3000 Posted January 23, 2010 Report Share Posted January 23, 2010 double post...whoops Quote Link to post Share on other sites
merten3000 Posted January 23, 2010 Report Share Posted January 23, 2010 Maybe Merten or Diaftia can use the speedsign to access TMC In navigatemap_800_480.ui Change this ;Posted Speed To This ;Posted Speed Currently clicking on the Speed Limit Sign will add a new speed cam. With the change above this will happen on a long click. A short click will take you to the TMC events Cheers 34by151 That works indeed! I will put it in my next EU version. As for TMC: I did forget to change UC to EW! Further I did some more testing. TMC settings screen works fine if you reset and use the 'old' way or through 34by151 shortcut way. But if you use the new TMC button it messes up the settings screen. After that all settings screens atre messed up even if you go there through the other ways. If you turn off and on your AVIC everything works again... Quote Link to post Share on other sites
34by151 Posted January 23, 2010 Report Share Posted January 23, 2010 if you use the new TMC button it messes up the settings screen. After that all settings screens atre messed up even if you go there through the other ways In navigatemap_800_480.ui / Change this line to Cheers 34by151 Quote Link to post Share on other sites
merten3000 Posted January 23, 2010 Report Share Posted January 23, 2010 if you use the new TMC button it messes up the settings screen. After that all settings screens atre messed up even if you go there through the other ways In navigatemap_800_480.ui / Change this line to Cheers 34by151 Thnx again!!! Will give it a try and if it works I will send Alex DaftiaV2.3_EU_fixed.rar with all your fixes applied!! Have to wait for testing untill my wife gets back from groceries with the car... Quote Link to post Share on other sites
