ariestav Posted February 23, 2011 Report Share Posted February 23, 2011 I'm glad I found this thread. My VR commands were working great before I had to take my care in for some repairs to my bumper. When I received the car from the repair garage, everything works fine EXCEPT for the VR commands--regardless of me pressing the OK button before my iPhone BT connection is made! Is it possible that the repair technicians "reset" my AVIC unit so that it ended up in a state where the VR catalog was destroyed or something? Any suggestions I can try to completely reset my AVIC unit? I should note that when I speak the command "Play Artist" the unit does recognize that, and then announces: "which artist do you want to play", and then the VR fails. So, it's as if the problem is only with the catalog, not the standard commands that ship with the unit. Thanks for your time and help! Quote Link to post Share on other sites
RonS Posted February 23, 2011 Report Share Posted February 23, 2011 I'm glad I found this thread. My VR commands were working great before I had to take my care in for some repairs to my bumper. When I received the car from the repair garage, everything works fine EXCEPT for the VR commands--regardless of me pressing the OK button before my iPhone BT connection is made! Is it possible that the repair technicians "reset" my AVIC unit so that it ended up in a state where the VR catalog was destroyed or something? Any suggestions I can try to completely reset my AVIC unit? I should note that when I speak the command "Play Artist" the unit does recognize that, and then announces: "which artist do you want to play", and then the VR fails. So, it's as if the problem is only with the catalog, not the standard commands that ship with the unit. Thanks for your time and help! Sounds like the VR catalog is hosed. Try a few more "canned" commands that don't require recognizing the songs, artists, or albumns on your iPod. Like "Next song", "Previous Song", Change Source to FM", "Change Source to iPod", ... If these work, then it isn't your mic, it is the iPod VR catalog. That can be rebuilt in the AV System Settings menu by turning VR Catalog Mode OFF, then ON. It should take several minutes. Oh, make sure Echo Cancel is turned ON in the BT Settings menu. Quote Link to post Share on other sites
ariestav Posted February 23, 2011 Report Share Posted February 23, 2011 Thanks for the reply Ron. I appreciate your time. I will give those suggestions a try. When I turn the VR Catalog Mode to OFF, should I turn the car off then on again so the unit reboots? Quote Link to post Share on other sites
RonS Posted February 23, 2011 Report Share Posted February 23, 2011 Thanks for the reply Ron. I appreciate your time. I will give those suggestions a try. When I turn the VR Catalog Mode to OFF, should I turn the car off then on again so the unit reboots? You're welcome. As far as forcing the VR re-catalog, I'm not exactly sure of the proper sequence to force it. Thae manual isn't exactly clear either. It certainly couldn't hurt to reboot after turning OFF. It might also work by just disconnecting and re-connecting the iPod. Here is what normally seems to happen. Once a full VR catalog has been done, subsequent reboots just do a quick check. On mine it only takes a few (5-10) seconds. A full rebuild takes several minutes. If you have a Z120, check out pgs 170-171. There are a few things there that you should check. (Language in settings is English, iPod is selected in the AV Source screen, you answerer OK on the Pledge screen. I should of asked earlier, but I am assuming your iPod can play normally besides VR commands, right? If re-building your iPod catalog doesn't work, the only other thing I can think of is to restore your iPod from iTunes. BTW, you didn't leave your iPod in the car & connected during the service, did you? Maybe the mechanic changed some setting. Quote Link to post Share on other sites
ariestav Posted February 23, 2011 Report Share Posted February 23, 2011 Thanks again for the tips. I did what you said to rebuild the VR catalog and still no dice. All the commands that ship with the unit work fine, but the variable ones (the names of my songs in my iPhone) simply do not get recognized. What a disappointment! So, I called tech support at Pioneer and they suggested I do the same things you recommended, but then they said I should update my firmware to the latest. Not sure if that will do the trick, but I'm going to give it a shot. I just don't know what the deal is. Ever since I got my car back nothing is recognized. You mentioned something about "resported my iPod from iTunes". What do you mean by that? Like completely removing everything from my iPhone and trying again? I'll post more as I learn more. Quote Link to post Share on other sites
RonS Posted February 23, 2011 Report Share Posted February 23, 2011 You mentioned something about "restore my iPod from iTunes". What do you mean by that? Like completely removing everything from my iPhone and trying again? I'll post more as I learn more. First I was thinking you had an iPod, not an iPhone. I have an iTouch, but I'm not sure if there are differences.that matter here. When you connect your iPhone to your PC, it starts iTunes (if so configured, otherwise start it up manually). In iTunes is a menu to manage your device (IPod/Phone). You can update the OS and/or restore it, which reloads all your music and videos. Quote Link to post Share on other sites
ariestav Posted February 24, 2011 Report Share Posted February 24, 2011 Well I updated the unit with the latest firmware, and was crossing my fingers, but still same issue. All the commands that are shipped with the unit work, but anything related to my catalog simply won't get recognized in the slightest. It just fails fails fails. I'll try doing a restore on the device, but in the meantime I'm on the phone with support to see if another agent can help out. More later . . . Thanks! Quote Link to post Share on other sites
ariestav Posted February 24, 2011 Report Share Posted February 24, 2011 Okay, so I spoke to the rep. at Pioneer who recommended I try out a different iPod / iPhone with the unit just to see if it was the unit or the iPod software. So, I borrowed my wife's iPhone, plugged it in, the unit cataloged all the songs from her iPhone, and the voice commands were recognized! So, I thought maybe if I connected my own iPhone it would work since the VR catalog got "reset" in a way. Sure enough it worked!! So, I suppose the iPod app was in a bad state or something. Who knows! All I know, is I'm glad I can finally control my songs and calls with voice commands once again. I assume if I had done a restore that it would have worked, but since this solution worked I'm good to go. Thanks for all the help! Quote Link to post Share on other sites
RonS Posted February 24, 2011 Report Share Posted February 24, 2011 Okay, so I spoke to the rep. at Pioneer who recommended I try out a different iPod / iPhone with the unit just to see if it was the unit or the iPod software. So, I borrowed my wife's iPhone, plugged it in, the unit cataloged all the songs from her iPhone, and the voice commands were recognized! So, I thought maybe if I connected my own iPhone it would work since the VR catalog got "reset" in a way. Sure enough it worked!! So, I suppose the iPod app was in a bad state or something. Who knows! All I know, is I'm glad I can finally control my songs and calls with voice commands once again. I assume if I had done a restore that it would have worked, but since this solution worked I'm good to go. Thanks for all the help! I have a feeling that switching iPod/iPhones accomplished what I was trying to do by turning OFF & ON VR Cataloging. Unfortuantely, that doesn't seem to force it to rebuild the catalog. I tried it yesterday on mine and it just used the old catalog (which, in my case, was still good). This may only apply to my particular installation, but I accidently found a reliable way. With the car stopped, I insert the key to ACC. I let the aVIC boot and listen to iPod. A few minutes later I start the engine - which causes the AVIC to reboot. After the reboot, and after pressing OK, it takes several minutes for the VR catalog to completely rebuild. My only theory as to why it rebuilds in this scenario it that the car cuts the constant +12 power when I crank the starter, so the AVIC looses it's memory and has to rebuild. If this is true, then all you needed to do was disconnect your battery for a few seconds. Or pull the fuse that feeds the constalant +12v if that is easier. So, if it happens again, give that a try first. It isn't as cumbersome as a full reset of the AVIC since other settings are retained. Anyway, glad you're in business again. Quote Link to post Share on other sites
AJO Posted August 14, 2011 Report Share Posted August 14, 2011 I had the exact same problem. Thanks for figuring it out to the point were all I had to do was read. Quote Link to post Share on other sites
rastta Posted December 5, 2011 Report Share Posted December 5, 2011 I was having this same problems - all VR commands except my phone would work. Kept saying it didn't understand etc. I tried the repairing, the turning cataloging on and off etc. and it didn't work. Finally I went into the phone menu and deleted all - all calls and contacts. Next time I turned the unit on - all my contacts downloaded and VR worked fine. Quote Link to post Share on other sites
stargate125645 Posted February 20, 2012 Report Share Posted February 20, 2012 Is there any way to make the voice recognition faster - particularly when trying to call someone? It always pauses for a few seconds before determining the name you said and it's quite annoying. I also noticed that some have said the VR startup routine has been adjusted, but I still have problems with it understanding what I'm saying when trying to call someone. I have the Z130BT, so are you all sure the software bug was removed? P.S. On a side note relating to other people's comments, for a head unit this expensive Pioneer should have put voice recognition for any USB or SD Card source. Only allowing it to work with Apple products is a sham! The same goes for displaying album art. Quote Link to post Share on other sites
Join the conversation
