motte Posted January 2, 2011 Report Share Posted January 2, 2011 If I delete these, I get no warnings anymore, I just want to get rid of the Icons on the map- Jörg Hello You create a translucent image bmp named speedwarn To put in: DATA-ZIP/ui_pioneer/common Here is the image speedwarn.rar Quote Link to post Share on other sites
Segler1963 Posted January 2, 2011 Report Share Posted January 2, 2011 Hello You create a translucent image bmp named speedwarn To put in: DATA-ZIP/ui_pioneer/common Here is the image Thx, will give it a try Jörg Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 Hi Diaftia, Afther installing the 3.2 version i got problems with the voice, i life in holland en want to use the dutch voice . I have sound but no voice directions. Greetings, Martijn You might need to go in and edit the sys.txt to point to your voice file. Unfortunately its hard for me to include all countries since there are so many. If you send me the voice file and sys.txt entries I might be able to add it in to the next release. Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 Hi Alex All was working well after deleting the save file. I uploaded your new version today and found that even though I selected the model I have in Australia it didn't change the sys.txt file nor did it erase the save files. I changed the sys.txt file manually to the correct version, deleted the save files and all worked ok. Not sure if it was something I was doing wrong or a bug in the loader. Great mod, works well. Interesting. I am not sure. In all my tests and beta testers it worked fine. Are your paths different than everyone elses? Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 Wow, didnt notice this update... I know its a long shot, but i have always wondered if its possible to have a split screen mode like what is found in the 04+ Yukon Denali factory/Delphi/Eclipse navigation systems. Here is a pic of it: Basically, on the right bottom of the screen, it lists your current street. Above that it lists the distance of the next turn, the direction of the turn, and the name of the street. Then above that, it lists the next 2 turns. And when you are close to the turn, the right side of the screen changes, to show you the lane assist picture thing. For example, if the exit has 2 exits on it, it will have an overlay picture of the exit and will draw a line on which lane to take when the exit splits into 2 different directions Hmmmm... really tall order. I might be able to do something similar but I had my split screen as a variation on this. I will see what I can do though. Unfortunately there are a ton of components to what you explained and its not going to be anytime all that soon. Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 This is the sys file i am using, maybe i am doing something wrong? Your file says you are using english: [local] voice_key="Eng_us_m1" default_language="english US" Maybe I am missing the problem? Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 Hey Alex, you are way too quick for me . I'm still on 3.1 and have at least one thing which I find needs improvement: to toggle between the map styles you have to press the compass, but I find it very hard to touch the button so it responds in the right way. 90% I end up setting the cursor in the to right corner instead of toggling between 2d and 3d. Maybe it's just me, but takes a lot of attention off the road. In addition I have one question: Is there a way to hide the speedcam icons on the map? Here in Europe you can get serious fines in some countries if cought with a System like that. Thanks Jörg I think you need to calibrate your screen. Its actually very easy to press and I have huge hands. The compass is actually one of the largest buttons on the screen minus the quick menu buttons. Can you try that to see if it helps? Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 What size sd card do I need for this.. I have a 8gb but it says the file is too big? How do I add the TELEATLAS 2010.06 North America Maps from here: http://avic411.com/index.php?/topic/29747-avic-x910-software-3010100-extras-mods/? I'm lost without directions.. Any help is much appreciated.. My files are 79mb. What else is on your 8gb SD card? You need to replace your map files in apl2/igo/content/maps. You should probably take up map replacement in a different thread so we keep things on topic as map replacement is not really a part of my mods. Only reason I ask is that it can get hard to keep up with things as it is. Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 Hello You create a translucent image bmp named speedwarn To put in: DATA-ZIP/ui_pioneer/common Here is the image You can also just put this in \My Flash Disk\APL2\iGo\ui_pioneer\common (make the last two folders) and put the file in there. Should work. If not then just open the zip file and replace the image motte posted. Quote Link to post Share on other sites
zach5555 Posted January 3, 2011 Report Share Posted January 3, 2011 Thanks, i have been using v2.3 for over a year now and this new version is awesome!! Keep up the good work:) Quote Link to post Share on other sites
LonestarROB Posted January 3, 2011 Report Share Posted January 3, 2011 I think you need to calibrate your screen. Its actually very easy to press and I have huge hands. The compass is actually one of the largest buttons on the screen minus the quick menu buttons. Can you try that to see if it helps? I've had this issue as well(In all previous versions too). Never been able to push the compass to change. Always just moves the marker to the top corner. Yes, I've calibrated. Quote Link to post Share on other sites
69sixpackbee Posted January 3, 2011 Report Share Posted January 3, 2011 Hey, Alex, Will your hacked EZrider for the elevation fix work with the TA 2010 Q6 maps? Thanx, Bud Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 Hey, Alex, Will your hacked EZrider for the elevation fix work with the TA 2010 Q6 maps? Thanx, Bud Its a hacked/hacked ezrider so yes. As long as you have the license files. Quote Link to post Share on other sites
diaftia Posted January 3, 2011 Author Report Share Posted January 3, 2011 I've had this issue as well(In all previous versions too). Never been able to push the compass to change. Always just moves the marker to the top corner. Yes, I've calibrated. I will look it over again but you seem to have issues that nobody else is having based on how your system is wired. Maybe his system is wired the same way. Quote Link to post Share on other sites
69sixpackbee Posted January 3, 2011 Report Share Posted January 3, 2011 Its a hacked/hacked ezrider so yes. As long as you have the license files. Cool! Thanx! Quote Link to post Share on other sites
