gmaker Posted October 6, 2013 Report Share Posted October 6, 2013 Help!Make for AVIC-F950BT the testmode.key file.Any file from a forum doesn't approach.Thanks in advance Quote Link to post Share on other sites
elitehunter Posted October 14, 2013 Report Share Posted October 14, 2013 hi all, i have a question. I installed igo primo on my pioneer avic f320bt. Everything works perfect. Only tmc. Whitch port and baud works tmc on igo primo. In igo8 u have a automatic search. In primo not. Can someone help me. Quote Link to post Share on other sites
BRRRYAN Posted October 21, 2013 Report Share Posted October 21, 2013 anyone ever get "error, installer files not found. is the sd inside the device?" please help me. i have no clue what else i can do. Quote Link to post Share on other sites
Chevelle427 Posted October 22, 2013 Report Share Posted October 22, 2013 Hello guys I have forgotten my Password in my Avic F940BT, and I can not start the radio, because at the beginning of the password directly held quest. how or what do I do so I reset the Password? Greetings from Germany Quote Link to post Share on other sites
mightymike1988 Posted October 23, 2013 Report Share Posted October 23, 2013 going to test it on a F940 this weekend! Quote Link to post Share on other sites
mightymike1988 Posted October 25, 2013 Report Share Posted October 25, 2013 Hi All, after running the auto install and remove the password.dat file my keyboard is disabled and most of the features in the menu are disabled... anyone a clue on how to fix this? Quote Link to post Share on other sites
Lyverbe Posted October 25, 2013 Report Share Posted October 25, 2013 Hi All, after running the auto install and remove the password.dat file my keyboard is disabled and most of the features in the menu are disabled... anyone a clue on how to fix this? Remove? Why did you remove it? I believe the system expects to find the file and, if it doesn't, it locks up the unit. Create an empty password.dat file and put it back in the folder. Quote Link to post Share on other sites
mightymike1988 Posted October 25, 2013 Report Share Posted October 25, 2013 I bought it from the internet, and the person told me there was no password on it but unfortunately there was a password,.. so I removed the file to gain access... will try to put an empty file in that folder tomorrow morning ( its 11:52 PM here) Quote Link to post Share on other sites
mightymike1988 Posted October 26, 2013 Report Share Posted October 26, 2013 So far no luck, will try to put the original password.dat file back and see if it makes a difference. but please keep your suggestions coming. if it fails is it an options to create a dump out of a F930 (all the directories etc) and then copy it back on the F940? (my other car has a F930 radio) EDIT: Just tried the Original file which contains the password but it does not even ask for a password. I even checked the log files, as far as they are written in several directories, but no error or what so ever. the weird thing is sometimes after rebooting I get the question if I want to set a password, and if I say I want to the keyboard is disabled,... I also though I saw 2 files in the NAND/SYSTEM/SECURITY directory, but their was none before I copied the password.dat file. I cant remember the name of the other file. could someone create a dump of their F940 and provide me the files? Kind Regards Quote Link to post Share on other sites
Lyverbe Posted October 26, 2013 Report Share Posted October 26, 2013 the weird thing is sometimes after rebooting I get the question if I want to set a password, and if I say I want to the keyboard is disabled,... Have you properly connected the parking brake wire? Check in your connection settings in "Navi Settings->Connection Status->Parking Brake" to make sure it's "On" when the parking brake is pulled. The keyboard is always disabled if the parking brake is not pulled to ensure you're not typing while driving. Quote Link to post Share on other sites
mightymike1988 Posted October 26, 2013 Report Share Posted October 26, 2013 alright will check that asap, sounds like a legit reason,.. the only function from the menu I could enter are the sound settings and A/V settings. all the navigation and keyboard stuff was disabled Quote Link to post Share on other sites
mightymike1988 Posted October 26, 2013 Report Share Posted October 26, 2013 MAN U ARE THE BOMB! I tested it on the table with a PSU... never thought of the handbrake signal cable Quote Link to post Share on other sites
garabatak Posted October 30, 2013 Report Share Posted October 30, 2013 Hello, did you donate 5$ F930BT my device sd card giving you copied the file to the device plugged v2.21 hackmode took place predicate, he said, and came to the green screen. there is no applicable program screen but then stayed to help me. I sent a picture. Quote Link to post Share on other sites
Lyverbe Posted October 30, 2013 Report Share Posted October 30, 2013 Hello, did you donate 5$ F930BT my device sd card giving you copied the file to the device plugged v2.21 hackmode took place predicate, he said, and came to the green screen. there is no applicable program screen but then stayed to help me. I sent a picture. If you would have read the many many many many many many many many many many posts made about v2.21, you would have never touched it. This thing screws up units. Try to put a PRG.FLG file in the USER folder. If there's already one, try to remove it. ADMINISTRATORS: Are any administrators in this forum reading this?! Please add a SERIOUS warning about the dangers of v2.21 and strongly suggest readers to use v1.4 instead or, hey, remove v.21 completely! We're the ones stuck with helping users who fell in the trap of using v2.21. Quote Link to post Share on other sites
garabatak Posted October 31, 2013 Report Share Posted October 31, 2013 How to turn back to normal ? Quote Link to post Share on other sites
Join the conversation
