ryar Posted October 13, 2011 Author Report Share Posted October 13, 2011 I tried it and error message came up for line 26 testmode 1? I believe it is in the start.ui.. Jimbo Delete the ui_pioneer folder and add: 1 run 'START_APPLICATION "\My Flash Disk\APL2\iGo\run\button\button.exe" ""' in your start.ui file inside your data zip right under <state st_Start> <script init>. Quote Link to post Share on other sites
ryar Posted October 13, 2011 Author Report Share Posted October 13, 2011 For Euro AVIC users try the file below. It is a never initialized fresh copy of the May 2011 release with a minimal sys.txt. Delete the entire Primo directory in My Flash Disk and copy onto your unit. I tested it on my US f500bt and it worked perfectly. I hope it solves your satellite and speedcam warning issues. Please leave some feedback as to how it works and if it solved any issues you have been having. http://hotfile.com/d...ay2011.rar.html Quote Link to post Share on other sites
palexr Posted October 13, 2011 Report Share Posted October 13, 2011 Oops, double post - dangers of using smartphones. Quote Link to post Share on other sites
Jfinley0 Posted October 13, 2011 Report Share Posted October 13, 2011 Delete the ui_pioneer folder and add: 1 run 'START_APPLICATION "\My Flash Disk\APL2\iGo\run\button\button.exe" ""' in your start.ui file inside your data zip right under <state st_Start> <script init>. Thanks I got it working. I will let you know how everything works. Thanks Again Jimbo Quote Link to post Share on other sites
palexr Posted October 14, 2011 Report Share Posted October 14, 2011 For Euro AVIC users try the file below. It is a never initialized fresh copy of the May 2011 release with a minimal sys.txt. Delete the entire Primo directory in My Flash Disk and copy onto your unit. I tested it on my US f500bt and it worked perfectly. I hope it solves your satellite and speedcam warning issues. Please leave some feedback as to how it works and if it solved any issues you have been having. http://hotfile.com/d...ay2011.rar.html thanks for you efforts, but, nope, still in central Paris apparently... I haven't been able to get it to work for past dozen goes now, not sure what else to do. As i said the Lat and Long are correct, I believe, they certainly move with me as does the altitude, it just doesn't seem to translate into an postion on the map very often. Quote Link to post Share on other sites
ovalball Posted October 14, 2011 Report Share Posted October 14, 2011 Just completed first trip using Primo,about 150 miles.Apart from losing traffic info,everything went perfectly.Junction views are brilliant,a big improvement on IGO.Looking forward to learning more about it in the days to come. Quote Link to post Share on other sites
palexr Posted October 14, 2011 Report Share Posted October 14, 2011 Just completed first trip using Primo,about 150 miles.Apart from losing traffic info,everything went perfectly.Junction views are brilliant,a big improvement on IGO.Looking forward to learning more about it in the days to come. I PM'ed you about the sys.txt? I'm having no luck. which is really annoying as it is clearly so much better than std IGO. Quote Link to post Share on other sites
patper Posted October 14, 2011 Report Share Posted October 14, 2011 I am on it as well as Palexr Quote Link to post Share on other sites
palexr Posted October 14, 2011 Report Share Posted October 14, 2011 Does anyone read Russian? I believe there a few threads on other forums about this - I think that is where this came from... Quote Link to post Share on other sites
ryar Posted October 14, 2011 Author Report Share Posted October 14, 2011 thanks for you efforts, but, nope, still in central Paris apparently... I haven't been able to get it to work for past dozen goes now, not sure what else to do. As i said the Lat and Long are correct, I believe, they certainly move with me as does the altitude, it just doesn't seem to translate into an postion on the map very often. So weird. More then half the people posting in Primo threads seem to be from Europe and no one has mentioned similar problems. Even a newer version and sys.txt didn't help? Maybe ovalball can help since he seems to no have the problem. Quote Link to post Share on other sites
ryar Posted October 14, 2011 Author Report Share Posted October 14, 2011 Does anyone read Russian? I believe there a few threads on other forums about this - I think that is where this came from... Use Google Chrome, it will translate the page to English for you. Quote Link to post Share on other sites
ryar Posted October 14, 2011 Author Report Share Posted October 14, 2011 oops, double post Quote Link to post Share on other sites
patper Posted October 16, 2011 Report Share Posted October 16, 2011 I PM'ed you about the sys.txt? I'm having no luck. which is really annoying as it is clearly so much better than std IGO. Hello, please also about SYS.TXT Thanks in advance Pat. Quote Link to post Share on other sites
ovalball Posted October 16, 2011 Report Share Posted October 16, 2011 Hi all.Just completed a round trip of over 300 miles with no real problems.Lost traffic info but I think this is an issue with settings in so much the TMC info is available at the outset of the journey but doesn't update.As soon as I can I will post my sys.txt on here(hopefully tonight)and maybe other European users can try them and see if things improve. Quote Link to post Share on other sites
ovalball Posted October 16, 2011 Report Share Posted October 16, 2011 Please see below the sys.txt I have been using(quite successfully)with my 900. [device] :type="PIONEER746UC" ; US F700/900/710/910 ;type="PIONEER749UC" ; US F500 type="PIONEER746EW" ; Euro F700/900/710/910 ;type="PIONEER749EW" ; Euro F500 [utility] calibratefix=0 ; ; If gps signal don't lost write - "0"; if lost write "1" [interface] vga=0 show_exit=1 show_minimize=1 extra_settings=1 shutdown_time=0 capture_to_jpeg=1 show_mapchanger=1 show_programs=1 [rawdisplay] highres=0 stretch=1 screen_x=800 screen_y=480 class="landscape" [Keybind] xa6 = "ZOOMIN";Up xa8 = "ZoomOut" ;Down xC4 = "MINIMIZE" ;Menu xaf = "VOLUMEUP" ;Dial right xae = "VOLUMEDOWN" ;Dial left xD5 = "ROTATELEFT" ;Left xa7 = "ROTATERIGHT" ;Right xC3 = "MAINMENU" ;Map x8D = "ANNOUNCE" ;Middle button [folders] has_secondary_root=0 sdcardpath="\my flash disk\APL2\" ;app="..\..\Primo" maps="..\..\IGO\content\map" buildings="..\..\IGO\content\building" dem="..\..\IGO\content\dem" poi="..\..\IGO\content\poi" [gps] baud=9600 ;- write "baud rate" port=7 ;- write port source="virtserial" set_messages="0" ; [mapchanger] map_ta="TELEATLAS" ; - you can write other title map_nt="NAVTEQ" map_ot="TOP MAP" [tripcomputer] num_of_trips=4 [vr] disabled=0 [3d_config] disable_roadsign_navigation_mode=0 roadsign_lines_per_screen=10 rotated_roadsigns=0 [sound] csv_voice_enabled=1 ding=0 [debug] skip_eula=1 screenshotsavecameraini=0 screenshotfilename="\captures\ecran_%02d.jpg" show_battery_percent=1 experimental_features=1 show_networkservices=1 catch_all_keys = 0 ; 0=No 1=Yes (I suppose) [lua] backlightdetails=1 [gestures] border_width=130 [network] available="0" [tmc-http] enabled=0 [http] enabled=0 [other] demo_enabled=1 [map] show_oneway=1 2dheadup=1 show_oneway_3d=1 poi_grouping_distance=0 3d_max_zoomlevel=800; 3d_min_zoomlevel=30;40 speedcam_visibility=500; 3d_max_tiltlevel="8700" 3d_default_tiltlevel="8200" 3d_max_zfar=5000 3d_buildings=1 3d_landmarks="1" 3d_roads="1" 3d_tunnels="1" follow_gps=1 [2d] guidancearrow_disappearlevel=600 guidancearrow_maxshift=12 minguidancearrowsize=20 minguidancearrowsize_zoomlevel=1200 maxguidancearrowsize=65 maxguidancearrowsize_zoomlevel=0 [3d] planned_route_track_width="5" planned_route_track_contour_width="1" planned_route_contour_width="1" max_pois_on_horizont="5" [navigation] junction_view_distance=300 ;(200) junction_view_distance_ramp=300 ;(400) junction_view_distance_highway=400 ;(800) simple_crossborder_warning=1 use_duration_for_tunnel=0 show_current_city=1 show_city_in_next_street = 1 show_city_in_next_street_distance = 1000 autoreplan_action="AUTO" gps_pos_to_road=1 show_countrychange=1 [camera.roundabout] enabled=1 [feature] text_guidance=1 signpost_coloring=1 tmc_event_coloring=1 tmc_traffic_side=1 ding=0 [dynamiccompressor] ;TTS voice compressor=1 gain=10 [tts] automatic_direction_conversion=1 announce_exit_directions=1 always_say_road_names=3 skip_exit_numbers=1 [warning] speedcam_enabled=1 speedcam_warning=1 speedcam_max_lookahead=1000 speedcam_maxdistance_from_road=50 ; S P E E D C A M - C A T : 0 [speedcam_category:0] approach_beep_distances="950,450" approach_beep_sound="Fixed_Camera" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 1 [speedcam_category:1] approach_beep_distances="450,450" approach_beep_sound="Mobile_Camera" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 2 [speedcam_category:2] approach_beep_distances="950,150" approach_beep_sound="Redlight_Camera" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 3 [speedcam_category:3] approach_beep_distances="950,150" approach_beep_sound="Section_Start" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 4 [speedcam_category:4] approach_beep_distances="950,150" approach_beep_sound="Redlight_Camera2" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 5 [speedcam_category:5] approach_beep_distances="950,150" approach_beep_sound="Railroad" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 6 [speedcam_category:6] approach_beep_distances="950,150" approach_beep_sound="Give_Way2" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 7 [speedcam_category:7] approach_beep_distances="950,550" approach_beep_sound="FixMobil" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 8 [speedcam_category:8] approach_beep_distances="450,150" approach_beep_sound="Speed_Breaker" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 9 [speedcam_category:9] approach_beep_distances="450,150" approach_beep_sound="Children" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 10 [speedcam_category:10] approach_beep_distances="450,450" approach_beep_sound="Dangerous_turn" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 11 [speedcam_category:11] approach_beep_distances="450,450" approach_beep_sound="Tunnel" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 12 [speedcam_category:12] approach_beep_distances="450,450" approach_beep_sound="Dangerous_way" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 13 [speedcam_category:13] approach_beep_distances="450,450" approach_beep_sound="POI" overspeed_sound="over_speed_limit" min_frc=5 ; S P E E D C A M - C A T : 14 [speedcam_category:14] approach_beep_distances="950,150" approach_beep_sound="RPS_Post" overspeed_sound="over_speed_limit" min_frc=5 Quote Link to post Share on other sites
Join the conversation
