Dejan Posted February 21, 2014 Author Report Share Posted February 21, 2014 try this package if you have any probleme just boot in wince (insert sd card with official pionner firmware and manually launch UpgradeMPU.exe) i have install sucessfully in my appradio and work perfectly with ios 7 (my config, appradio 2.64 + jailbreak , iphone 4 ios 7.0.4 + jailbreak) AppRadio_plus_26_264.rar Quote Link to post Share on other sites
Tone987 Posted February 22, 2014 Report Share Posted February 22, 2014 Thanks Dejan that file worked, just a slight problem with the clock. Can you or anyone recommend a good source for UK/Europe Igo maps? Quote Link to post Share on other sites
Dejan Posted February 22, 2014 Author Report Share Posted February 22, 2014 Thepiratebay for download recent map But the must is official igo with appradio (on iphone) Quote Link to post Share on other sites
reverend666 Posted February 24, 2014 Report Share Posted February 24, 2014 try this package if you have any probleme just boot in wince (insert sd card with official pionner firmware and manually launch UpgradeMPU.exe) i have install sucessfully in my appradio and work perfectly with ios 7 (my config, appradio 2.64 + jailbreak , iphone 4 ios 7.0.4 + jailbreak) Will this work on a AVH X2500bt too??? Or only for the "AppRadios"? Quote Link to post Share on other sites
Dejan Posted February 24, 2014 Author Report Share Posted February 24, 2014 Will this work on a AVH X2500bt too??? Or only for the "AppRadios"? Sph-da01 Only.... Quote Link to post Share on other sites
reverend666 Posted February 24, 2014 Report Share Posted February 24, 2014 Okay Thank you Quote Link to post Share on other sites
Tone987 Posted February 26, 2014 Report Share Posted February 26, 2014 Downloaded about 24Gb of maps, a lot do not work but have finally managed to pick out most of the European ones that I need that do. The clock still keeps losing time, is there a setting that I am missing???? Registry key is set for European time. Does WinCe loose the time when unit is switched off? Quote Link to post Share on other sites
unknwon00 Posted March 4, 2014 Report Share Posted March 4, 2014 so i can confirm that you can install sph-da01 firmware on sph-da02 decks below are the instructions. 1. update to the latest sph-da02 firmware 4.17. 2. download the sph-da01 firmware 2.64 3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory. 4. extract the CE66 folder from the sph-da01 firmware. 5. boot up the deck with the sd card. This will boot the deck to the desktop. 6. click start, programs, windows explorer. select the SD card directory. double click on the "UpgradeMPU.exe" this will install the sph-da01 firmware on the deck. when prompted, remove the SD Card before rebooting. 7. reboot the deck, check to make sure everything is working, you can check the firmware version on the settings page. 8. now extract all the files and folders from the AppRadio_plus_26_264.rar to the CD card. 9. reboot the deck again with the SD card in and start the install of the appradio plus. 10 remove the SD card after the install. 11 reboot and verify, you should see the new background on the screen. The only thing i haven`t tested yet is running the igo program as i can`t find a download link for the mips version. Can someone send me the link for the download? Quote Link to post Share on other sites
Dejan Posted March 4, 2014 Author Report Share Posted March 4, 2014 so i can confirm that you can install sph-da01 firmware on sph-da02 decks below are the instructions. 1. update to the latest sph-da02 firmware 4.17. 2. download the sph-da01 firmware 2.64 3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory. 4. extract the CE66 folder from the sph-da01 firmware. 5. boot up the deck with the sd card. This will boot the deck to the desktop. 6. click start, programs, windows explorer. select the SD card directory. double click on the "UpgradeMPU.exe" this will install the sph-da01 firmware on the deck. when prompted, remove the SD Card before rebooting. 7. reboot the deck, check to make sure everything is working, you can check the firmware version on the settings page. 8. now extract all the files and folders from the AppRadio_plus_26_264.rar to the CD card. 9. reboot the deck again with the SD card in and start the install of the appradio plus. 10 remove the SD card after the install. 11 reboot and verify, you should see the new background on the screen. The only thing i haven`t tested yet is running the igo program as i can`t find a download link for the mips version. Can someone send me the link for the download? Good news and tuto Find igo in my dropbox : http://dl.dropbox.com/u/31548666/APL.rar But sound not work on sphda01 Quote Link to post Share on other sites
nudels64 Posted March 4, 2014 Report Share Posted March 4, 2014 Class work unknwon00. Can I back to the original firmware? Quote Link to post Share on other sites
unknwon00 Posted March 5, 2014 Report Share Posted March 5, 2014 Good news and tuto Find igo in my dropbox : http://dl.dropbox.com/u/31548666/APL.rar But sound not work on sphda01 thanks i can confirm that the igo/gps works now to find a mp3 player that works, then i can disconnect the iphone forever Quote Link to post Share on other sites
Tone987 Posted March 5, 2014 Report Share Posted March 5, 2014 There's no audio driver for the WinCe so you can't play Mp3's off the microSD card if that's what you where planning. I leave a jailbroke iPod touch permanently connected. Quote Link to post Share on other sites
unknwon00 Posted March 6, 2014 Report Share Posted March 6, 2014 i`ll work on the audio driver after i get back from holidays. Quote Link to post Share on other sites
duner Posted March 21, 2014 Report Share Posted March 21, 2014 Will this work with Appradio3 and Iphone5 jailbroke with 7.04? Looking for alternatives since Appradio extensions doesnt work. Quote Link to post Share on other sites
pony1609 Posted May 8, 2014 Report Share Posted May 8, 2014 moi j'ai testé quelques applications, genre VNC et lecteur MP3 mais sinon j'utilise rien d'autre j'ai essayer les applications des systemes AVIC mais sa marche pas snif application non compatible WinCE !! En faite tu trouvera des applications essentiellement pour pocketPC c'est la ou j'ai trouvé tout ce qui tourne sur l'appradio, sinon Pioneer prevoi une mise a jour à la fin du mois et une autre fin Mai !!!! Bonjour Dejan, Tu les telecharges ou tes apps ? Quote Link to post Share on other sites
