Dejan Posted May 11, 2014 Author Report Share Posted May 11, 2014 Bonjour Dejan, Tu les telecharges ou tes apps ? Recherche ds google toutes les applications compatible MIPS fonctionnerons mais helas pas de son... Merci pioneer pour ce matos de m***** Quote Link to post Share on other sites
jonmeeker Posted May 21, 2014 Report Share Posted May 21, 2014 so i can confirm that you can install sph-da01 firmware on sph-da02 decks below are the instructions. 1. update to the latest sph-da02 firmware 4.17. 2. download the sph-da01 firmware 2.64 3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory. 4. extract the CE66 folder from the sph-da01 firmware. 5. boot up the deck with the sd card. This will boot the deck to the desktop. 6. click start, programs, windows explorer. select the SD card directory. double click on the "UpgradeMPU.exe" this will install the sph-da01 firmware on the deck. when prompted, remove the SD Card before rebooting. 7. reboot the deck, check to make sure everything is working, you can check the firmware version on the settings page. 8. now extract all the files and folders from the AppRadio_plus_26_264.rar to the CD card. 9. reboot the deck again with the SD card in and start the install of the appradio plus. 10 remove the SD card after the install. 11 reboot and verify, you should see the new background on the screen. The only thing i haven`t tested yet is running the igo program as i can`t find a download link for the mips version. Can someone send me the link for the download? Ive completed this whole process until after installation of plus. It says it installs fine and everything goes smoothly and I reboot but, nothing has changed whatsoever. Any ideas? Quote Link to post Share on other sites
mega1800 Posted June 24, 2014 Report Share Posted June 24, 2014 Bonsoir, je dois faire le domade. Comment puis-je traduire en italien? Après avoir modifié le firmware, vous pouvez revenir à 04h17? Vous pouvez l'utiliser sans l'iphone? Quote Link to post Share on other sites
Dejan Posted July 5, 2014 Author Report Share Posted July 5, 2014 Bonsoir, je dois faire le domade. Comment puis-je traduire en italien? Après avoir modifié le firmware, vous pouvez revenir à 04h17? Vous pouvez l'utiliser sans l'iphone? Il faut regarder le fichier language et ajouter la langue voulu. Impossible sans iphone. Quote Link to post Share on other sites
Gengis Posted August 21, 2014 Report Share Posted August 21, 2014 3. extract the files from AppRadio_plus_26_264.rar, but not the appradio directory. Hi, "but not the appradio directory" --> does it mean I have to delete all that is under the appradio directory? Thank You Gengis Jésus m'aime Jesus Liebt Mich Jesus Loves Me Quote Link to post Share on other sites
Redina Posted August 29, 2014 Report Share Posted August 29, 2014 salut Dejan, Possesseur depuis longtemps d'un pioneer sph da 01 je viens juste de découvrir le jailbreak et tu m'en vois émerveillé. J'ai donc téléchargé le jailbreak pour la version 2.64 installé sur la carte sd installé sur le poste. Le soucis c'est que lorsque j'appuie sur le bouton paramètre du poste sa ne se lance pas comme je peux le voir sur la video en fait rien ne se lance je ne peux pas accéder aux applications. J'ai beau avoir tout lu mais j'ai vraiment du mal avec l'anglais Pourrais tu m'expliquer un peu merci Quote Link to post Share on other sites
Dejan Posted September 9, 2014 Author Report Share Posted September 9, 2014 salut Dejan, Possesseur depuis longtemps d'un pioneer sph da 01 je viens juste de découvrir le jailbreak et tu m'en vois émerveillé. J'ai donc téléchargé le jailbreak pour la version 2.64 installé sur la carte sd installé sur le poste. Le soucis c'est que lorsque j'appuie sur le bouton paramètre du poste sa ne se lance pas comme je peux le voir sur la video en fait rien ne se lance je ne peux pas accéder aux applications. J'ai beau avoir tout lu mais j'ai vraiment du mal avec l'anglais Pourrais tu m'expliquer un peu merci Salut, c'est bien installé? Le warning message est bien valide au demarrage tte seul sans que tu valide ? Quote Link to post Share on other sites
nadnava Posted September 16, 2014 Report Share Posted September 16, 2014 fonctionne en PIONEER AVIC Z-140? Quote Link to post Share on other sites
Dejan Posted September 20, 2014 Author Report Share Posted September 20, 2014 fonctionne en PIONEER AVIC Z-140? Non Only Appradio 1et2 Quote Link to post Share on other sites
Psico Posted September 25, 2014 Report Share Posted September 25, 2014 hi guys, i'm very gratefull to you for your help. i was installed appradio plus in my sph-da01, all good... works fine.... BUT, i can't launch igo.... "Cannot fin run" .... i see that the files isn't in the nand or SD card. im from chile, here isn't usefull this GPS App... how can i delete this icon from the "menu", in other hand, how can i install another app? i have to copy it to APL folder in the SD? pleasy explain it.... cheers and thanks.... (sorry if i wrote something bad, i'ts not my native languaje) Quote Link to post Share on other sites
Dejan Posted November 5, 2014 Author Report Share Posted November 5, 2014 hi guys, i'm very gratefull to you for your help. i was installed appradio plus in my sph-da01, all good... works fine.... BUT, i can't launch igo.... "Cannot fin run" .... i see that the files isn't in the nand or SD card. im from chile, here isn't usefull this GPS App... how can i delete this icon from the "menu", in other hand, how can i install another app? i have to copy it to APL folder in the SD? pleasy explain it.... cheers and thanks.... (sorry if i wrote something bad, i'ts not my native languaje) Sorry for my late reponse, try that https://dl.dropboxusercontent.com/u/31548666/APL.rar works 100% with appradio 1 SPH-DA01 but, the must is you use igo iphone jailbreak and install background manager Quote Link to post Share on other sites
Psico Posted November 19, 2014 Report Share Posted November 19, 2014 Sorry for my late reponse, try that https://dl.dropboxusercontent.com/u/31548666/APL.rar works 100% with appradio 1 SPH-DA01 but, the must is you use igo iphone jailbreak and install background manager Thank you very much, i will try with this file.... please, one more question: i'm using an iphone 4, but the image is yellow and i can ear some interference (i used an iphone 3gs, and the same result), but when i connect my dad iphone 4, the image is normal and have no interference. do you have an idea about the problem? thanks again!!! Quote Link to post Share on other sites
Dejan Posted November 23, 2014 Author Report Share Posted November 23, 2014 Thank you very much, i will try with this file.... please, one more question: i'm using an iphone 4, but the image is yellow and i can ear some interference (i used an iphone 3gs, and the same result), but when i connect my dad iphone 4, the image is normal and have no interference. do you have an idea about the problem? thanks again!!! try to clean up connector 40 pin in your phone for me, the best usage for appradio 1 or 2 is iphone 4 + background manager result here : http://avic411.com/index.php?/topic/38423-appradio-backgrounding-application-with-ios-7/ (jailbreak with pangu... and background manager work fine...) Quote Link to post Share on other sites
Psico Posted November 23, 2014 Report Share Posted November 23, 2014 Thanks, I'll try cleaning it... The iPhone that I use, is already jailbroken, I will install background manager to see what can do Ah, and thanks for the Igo files, works great with the Chilean map.... Cheers from chile!!!! Quote Link to post Share on other sites
Dejan Posted November 27, 2014 Author Report Share Posted November 27, 2014 Thanks, I'll try cleaning it... The iPhone that I use, is already jailbroken, I will install background manager to see what can do Ah, and thanks for the Igo files, works great with the Chilean map.... Cheers from chile!!!! pleasure Quote Link to post Share on other sites
