ritalwinner Posted November 20, 2012 Report Share Posted November 20, 2012 Hello, ok thanks, sorry, i'm french and i'm not sure to have good anderstand all instruction, it's was why i prefere ask before do something. I have a last question, please, how i can do i save of my actual firmware, is a have problem, for come back? i don't find tuto. please, thanks Quote Link to post Share on other sites
voviks Posted November 20, 2012 Report Share Posted November 20, 2012 Worked like a charm on F930BT! Thank you so much! Greetings from Austria! Quote Link to post Share on other sites
RafRoo Posted November 21, 2012 Report Share Posted November 21, 2012 Hey, Also tested this firmware and on my F930BT works realy FINE. THANKS !! About the cabel please look: http://allegro.pl/ka...html#tabsAnchor I have bought my F930BT unit from this guy. The cost is about 32 pounds but i don't know the cost of sending abroad (England If I good understand) ?? Quote Link to post Share on other sites
radeonorama Posted November 21, 2012 Author Report Share Posted November 21, 2012 Hey, Also tested this firmware and on my F930BT works realy FINE. THANKS !! About the cabel please look: http://allegro.pl/ka...html#tabsAnchor I have bought my F930BT unit from this guy. The cost is about 32 pounds but i don't know the cost of sending abroad (England If I good understand) ?? Thanks for the suggestion but it would appear they dont ship to the UK. Thanks again. Quote Link to post Share on other sites
ritalwinner Posted November 22, 2012 Report Share Posted November 22, 2012 hello, someone know if i can make a backup of my original firmware before upgrade. it's a f10bt thanks Quote Link to post Share on other sites
urguplu Posted November 23, 2012 Report Share Posted November 23, 2012 I have upgraded my 9210bt. So it was tested and worked with 9210 as expected. Thanks a lot! Quote Link to post Share on other sites
bodziek75 Posted November 24, 2012 Report Share Posted November 24, 2012 Hi Avic F9210BT, System after passing 99% shows me the "wrong card, change the card to continue." I do not know what to do next, nothing works. Please Help. Someone may have a solution. Quote Link to post Share on other sites
idude Posted November 24, 2012 Report Share Posted November 24, 2012 hai thanx for all the work I have a strange problem. I followed the instructions but when i put the sd card in the unit nothing happens. The files and directories are in the way that is described in the posts. I have succesfully updated the bluetooth to 3.24, but the unit does'nt start the firmware upgrade. I am using an 8gb sdcard (instead of a 4gb), but is that a problem? I have an f9220bt which i have previously updated to f30BT-software using more or less the same method, and the same Sdcard. But now nothing happens. Anyone can help? Quote Link to post Share on other sites
ritalwinner Posted November 24, 2012 Report Share Posted November 24, 2012 hello, perfect on f10bt, thanks Quote Link to post Share on other sites
simbad88 Posted November 24, 2012 Report Share Posted November 24, 2012 Thanks Pionara. It works flawlesly, F920BT from Spain. Quote Link to post Share on other sites
pionara Posted November 24, 2012 Report Share Posted November 24, 2012 bodziek, try reformat sdcard, then recopy files. if that doesnt work, try new sdcard, reformatted, and recopy files idude, did you follow instructions about editing Cardinfo.cif? Quote Link to post Share on other sites
joss Posted November 24, 2012 Report Share Posted November 24, 2012 Hi everyone, Pleased to enter your forum. I followed the radeonorama's procedure (post #1) with the VERINFO.DAT from pionara (post #2). This CNSD-310FM EU 2012 upgrade works well on a F9310BT (september 2011 release). Thanks to you radeonorama and to you pionara For information the versions below are retrieved booting with pionara's "supertestmode" testmode.key copied on a microSD (note: copy/paste functions enabled). AVIC F9310BT initial versions: PRODUCT NUMBER= AVIC-F930BT / XNEU5 NAVI INFORMATION= NX072/EU5 REGION CODE= 2 APL PROGRAM= 3.001 VOLUME INFORMATION= 3 BLUETOOTH FIRMWARE= 3.22 Versions upgraded: APL PROGRAM= 4.01 VOLUME INFORMATION= 4 BLUETOOTH FIRMWARE= 3.24 Note: -First boot after upgrade i set the french language but the next boot the system was in a kind of norvegian language. Looking in the regional settings the french softkey is selected. Switched to english (reboot), came back to the regional settings, and reselected french to recover my language, and a normal heart rhythm..! That's all for this thread. I'm now on the quest of the softmod to neutralize the caution screen for the video while driving. @pionara: you let understand that there is a solution, in the post #2 of this thread: http://avic411.com/index.php?/topic/35540-new-firmware-pioneer-401-and-bypass/page__hl__f940bt&do=findComment&comment=258314 But I have some difficulties to find the method. Is it because there is no softmod for this feature but only hardmod (around Velocity Speed Sensor signal) ? @radeonorama: sorry I cannot help you for your cable. Thanks to everyone helping, if I can, just ask. Quote Link to post Share on other sites
bodziek75 Posted November 24, 2012 Report Share Posted November 24, 2012 hi pionara i used memory card 16gb, maybe my card is too large, Quote Link to post Share on other sites
simple.cavalier Posted November 25, 2012 Report Share Posted November 25, 2012 hi pionara i used memory card 16gb, maybe my card is too large, Is it a cheap brand of card or one of the known good brands such as Sandisk? Did you format it in Windows using the Default allocation unit size? I had no issues updating with this using a Sandisk 8GB MicroSD card on an F920BT. Quote Link to post Share on other sites
syros Posted November 25, 2012 Report Share Posted November 25, 2012 Worked well on F10-BT (was on version 3) However, the upgrade from 4.00 to 4.01 was not successful (system doesn't recognize/start any upgrade.) Can 4.01 be achieved with older hardware models than Fx40-BT? Quote Link to post Share on other sites
