Jump to content
AVIC411.com
2015 European Map Update for Pioneer AVIC-F30BT, F930BT, F9310BT, F40BT, F940BT, F840BT, F8430BT
  • Replies 789
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I think that those who have the last firmware version, cannot have any more the detection of radars!! (speedcams)
What is strange, it is that some people say that that works, but he does not say which is the firmware version
the f940bt and f40bt No detected radar (speedcams)
The solutions to put radars on of other forums, tell to add files in the file  APL2.
On the former AVIC there is a file APL2 in them avicf940 f40 it no file APL2 only APL.
I understand nothing! Why that worked before?
It's certain !! My Avic F940BT before the radars detected very well
since 2 or 3 months , Before making modify my avic, he stopped to detect radar
If it is necessary to modify something it is in this file RW\POINT (Points of Interest)
I see no something else
Link to post
Share on other sites
This is a post for dutch and belgium users that are using speedcams.
http://s000.tinyupload.com/?file_id=09205970760400181779
This is only Holland and Belgium ,
Just put the PC dir on a sd card and insert this in the navigation, just install zwarte punten and the should be in your navigation.
Dus gewoon de map PC kopiëren op een sd en dan de zwarte punten installeren, ik heb het alleen zelf met 6.0 nog niet geprobeerd en hoop dat iemand mij kan vertellen of het werkt :)
Link to post
Flosmen la password dei zip ? sto cervellando nel primo post....ma non ci arrico...grazie
Nel primo post a circa metà c'è scritto "Update File: Use at Your Own Risk!" subito a fianco più in piccolo è specificato che la parola chiave è visibile nel suo profilo. Per accedere al profilo basta cliccare sulla foto del suo avatar, comparirà una schermata con varie voci, li troverai ciò che interessa a te.
Ciao ciao.
Link to post
pas sur !! je vais donné 10 € pour quelque chose qui ne va pas fonctionné ?
je veux être sur que ça fonctionne avant de faire l'achat.
quand même !! comment expliqué ,que mon f940bt indiquait bien les radars avant ,et que maintenant
plus aucun signalement de radars ?
Not on!! I go given 10 € for something who does not go worked?
I want to be on that that works before purchasing.
How explained, my f940bt indicated well radars before, and that now , no indicated of radars?
Link to post
You should donate the 10€ to me instead ;)
Link to post
Pour activer les radars tu va dans paramètre navigation, ensuite dans traffic ,info traffic et infos affichés puis tu selectionne contrôle police .
Link to post
Hallo,
ich finde es ganz toll, das hier der europ. Map Update für mein Pioneer AVIC F940BT für eine freiwillige Spende zu Verfügung gestellt wird.
Leider kann und könnte ich davon keinen Gebrauch machen, da ich nicht mit der Testmode 2.3 in das Betriebssystem von meinem F940BT komme.
Ich lebe seit ca einem Jahr in Chile un möchte mir nur die NAVTEQ Karte von Südamerika 2013 machen, aber seit mehreren Monaten versuche ich vergeblich mit verschiedenen Downloads der Testmode 2.3
und auch verschiedenen Micro Sd-Karten ind das Betriebssystem von meinem Navi F940BT zu kommen. Ich habe schon alle möglichen Foren zu diesem Thema durch gearbeitet, aber auch leider dort keine
Lösung gefunden.
Ich hoffe, dass mir hier im Forum einer weiter helfen kann.
Viele Grüße aus dem fernen Chile
Uli
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
Loading...
  • Create New...
