RonS Posted October 22, 2015 Report Share Posted October 22, 2015 Is the bluetooth firmware for the 2015 map update available? I tried to update the bluetooth firmware that was included with this package but the firmware(3.10) is lower than the one that came with the 2013 map update(3.32). The 2015 upgrade still comes with 3.32. Quote Link to post Share on other sites
jfwalsh99 Posted October 22, 2015 Report Share Posted October 22, 2015 Would it be possible for someone to upload the 2015 CARDINFO.CIF and VERINFO.DAT files for Z130, Z140, and Z150 users. Quote Link to post Share on other sites
vicdawg Posted October 22, 2015 Report Share Posted October 22, 2015 The 2015 upgrade still comes with 3.32. Thanks for the reply. I downgraded back to the 2013 map update and everything is working as it should. Quote Link to post Share on other sites
kellinaradway Posted October 22, 2015 Author Report Share Posted October 22, 2015 Would it be possible for someone to upload the 2015 CARDINFO.CIF and VERINFO.DAT files for Z130, Z140, and Z150 users. I tried to download it for you, but they have that thing locked down and you need permission so it's not easy to get too. Quote Link to post Share on other sites
siaopao Posted October 26, 2015 Report Share Posted October 26, 2015 Can someone provide step by step info to update to 2015 map for X930BT? Mine has 2014 map on it. Thanks in advance. Quote Link to post Share on other sites
kellinaradway Posted October 29, 2015 Author Report Share Posted October 29, 2015 Can someone provide step by step info to update to 2015 map for X930BT? Mine has 2014 map on it. Thanks in advance. If you choose to actually read the thread you would know that it's not available for that model yet. Quote Link to post Share on other sites
BlakeStone Posted October 29, 2015 Report Share Posted October 29, 2015 2015 Maps CIF DAT.zip These are for: AVIC-Z130BTAVIC-X930BTAVIC-X9310BTAVIC-Z140BHAVIC-X940BT Quote Link to post Share on other sites
RonS Posted October 29, 2015 Report Share Posted October 29, 2015 2015 Maps CIF DAT.zip These are for: AVIC-Z130BT AVIC-X930BT AVIC-X9310BT AVIC-Z140BH AVIC-X940BT Just to spell it out clearly, use this CardInfo.cif file (after unzipping of course) for the above mentioned headunits. Thanks for posting this BlakeStone. Quote Link to post Share on other sites
kellinaradway Posted October 29, 2015 Author Report Share Posted October 29, 2015 Just to spell it out clearly, use this CardInfo.cif file (after unzipping of course) for the above mentioned headunits. Thanks for posting this BlakeStone. These are the stock files and haven't been password hacked yet correct? Quote Link to post Share on other sites
RonS Posted October 29, 2015 Report Share Posted October 29, 2015 These are the stock files and haven't been password hacked yet correct? According to the txt file in the zip, VERINFO.DAT has not been hacked. I notice that it is totally different from the one I used from the original 2015 X920bt update (prior to the published VERINFO.DAT hack). The CardInfo.cif file doesn't need any modifications for the newer HUs. Quote Link to post Share on other sites
randomwalk101 Posted October 29, 2015 Report Share Posted October 29, 2015 Hey BlakeStone, Do you have the actual update map 2015 for the 2015 Maps CIF DAT.zip These are for: AVIC-Z130BTAVIC-X930BTAVIC-X9310BTAVIC-Z140BHAVIC-X940BT BlakeStone: Do you have the actual 2015 map update for the unit posted above? I tried to put the two files you posted in the zip combine with the 2015 map update files from kellinaradway and it didn't work in the AVIC-Z140BH. Quote Link to post Share on other sites
BlakeStone Posted October 30, 2015 Report Share Posted October 30, 2015 Sure, but I thought it was just the 2 files that were needed. Quote Link to post Share on other sites
randomwalk101 Posted October 30, 2015 Report Share Posted October 30, 2015 Sure, but I thought it was just the 2 files that were needed. BlakeStone. Much appreciated. I tried different cardinfo & verinfo files and none worked on the Z140BH unit so just wanted to try your version. This version is not the same as the one killiradway posted? Quote Link to post Share on other sites
randomwalk101 Posted October 30, 2015 Report Share Posted October 30, 2015 Sure, but I thought it was just the 2 files that were needed. IT WORKS!!!!! this version works on Z140BT (mine) and so probably all other newer models. Basically use everything but replace the verinfo with pionara verinfo file (to bypass the password) and it'll start updating like it should Many thanks BlakeStone!!!! I am attaching the Pionara's verinfo file here as well to make it easier for the rest of the guys behind me. VERINFO.DAT Quote Link to post Share on other sites
ThePiston Posted October 30, 2015 Report Share Posted October 30, 2015 random walk, just so i am 100 percent clear, you took the blackstone map update and put the verinfo.dat into it and it worked for 140, does that mean it will work for 130? Also, any password of passwordpassword or no password at all? Quote Link to post Share on other sites
