vtss Posted July 24, 2017 Report Share Posted July 24, 2017 atm you just have to have alot of patience btw i think you can downgrade the unit to an older version, then the patch/crack will work. You sir are a genius - I'd assumed it couldnt be rolled back (Pioneer website says you cannot) - downloaded the 1.14 from the link on this forum, fired it up on the headunit - got a warning it was older than current did I wish to continue, then simply said yes and installed 1.14 over the top! Had to do the bluetooth rollback too, but now working fine - testmode works perfectly, and I've patched out the annoying nav warning 'OK' screen Quote Link to post Share on other sites
Mod2Future Posted July 24, 2017 Report Share Posted July 24, 2017 You can get a complete System Dump from a previous version of the NEX 6000 to downgrade the Device. Quote Link to post Share on other sites
cjust Posted July 25, 2017 Report Share Posted July 25, 2017 platform x200: AVH-X8800BT - 1.06 download AVIC-F980BT - European (EU5) model - 1.07 download AVIC-F980BT - Russian (UR) model - 1.07 download Is the 8200NEX different than the AVH-X800BT? I'm just confused as to why this is firmware version 1.06 but the Pioneer web site only has version 1.04 for the x200 series. Thanks for any help educating me. Quote Link to post Share on other sites
josney Posted July 25, 2017 Report Share Posted July 25, 2017 will this work on the 4200? Quote Link to post Share on other sites
SpecTrax Posted July 30, 2017 Report Share Posted July 30, 2017 NEW Firmware for AVIC\AVH x000\x100\x200 platforms update: june 2017 Test Mode does not work with old keys platform x000: AVH-X8600BT - 1.15 download AVIC-Fx6x EU5 верÑÐ¸Ñ - 1.15 - download AVIC-Fx6x UW5 верÑÐ¸Ñ - 1.15 - download SPH-DA120 EU - 1.18 download platform x100: AVH-X8700BT - 1.10 - download AVIC-F970BT - European (EU) Model - 1.10 download AVIC-F970BT - Russian (UR) Model - 1.10 download platform x200: AVH-X8800BT - 1.06 download AVIC-F980BT - European (EU5) model - 1.07 download AVIC-F980BT - Russian (UR) model - 1.07 download New keys available for the new firmware asd255 was so kind to share some Golden apples & eggs with us. The content he provided contained some different versions of testkeys. The one we need (i thnk) is the tech one, so this is the one im sharing. Use the goldenapple.tst key with your preffered patch . pass: avic411 Hopefully admins/asd255 dont mind if i share this file,...otherwise please edit this post GOLDENAPPLE.zip Quote Link to post Share on other sites
josney Posted August 4, 2017 Report Share Posted August 4, 2017 will this work on the 4200? anyone?? Quote Link to post Share on other sites
dc2r Posted August 7, 2017 Report Share Posted August 7, 2017 anyone?? Also interested. Just downloaded frokm web and it says 1.05 is newest ver Quote Link to post Share on other sites
Mod2Future Posted August 11, 2017 Report Share Posted August 11, 2017 Replace the "old" tesmode_a.key with the goldenapple.tst Dont replace or rename the file. Just copy goldenapple.tst and then you can enter to Testmode. Can confirm that v1.15 and Testmode is working. Quote Link to post Share on other sites
erock1 Posted September 7, 2017 Report Share Posted September 7, 2017 New keys available for the new firmware asd255 was so kind to share some Golden apples & eggs with us. The content he provided contained some different versions of testkeys. The one we need (i thnk) is the tech one, so this is the one im sharing. Use the goldenapple.tst key with your preffered patch . pass: avic411 Hopefully admins/asd255 dont mind if i share this file,...otherwise please edit this post Can you please provide instructions on how to bypass OK Screen at startup using this Golden Egg? Did a quick search, can't find anything. Thanks! Quote Link to post Share on other sites
SpecTrax Posted September 8, 2017 Report Share Posted September 8, 2017 Can you please provide instructions on how to bypass OK Screen at startup using this Golden Egg? Did a quick search, can't find anything. Thanks! only works on the x000 platform (incl. 5000-8000NEX/F960BT/F60DAB, AVIC-F960BT / AVH-X8600BT / SPH-DA120). Not on the x100! pass: avic411 Download file Unpack downloaded file(s) into FAT32-formatted USB stick, insert stick into USB1 (USB2 isn't working). Your device will reboot into testmode. Select Write program forcedly => Copy Script, script will patch your system and reboot. Remove USB stick after script finishes. ​NEVER ENTER COPY DEVICE MODE, YOU WILL BRICK YOUR DEVICE! remove_pl_and_smartphone_OK_screen_x000.zip Quote Link to post Share on other sites
antony cheys Posted September 12, 2017 Report Share Posted September 12, 2017 Hello, i want install the cracked navi software on my F60DAB / NEX 8000 but i have firmware v 1.15. so i cant use the - x000(5000-8000NEX F960BT/DAB F60BT/DAB) FW 1.11/1.13 /1.14 x000_1.11_9.18.28.610126.rar 7.23MB 435 downloads can i downgrade my firmware version to 1.14? where can i get the 1.14 firmware? Quote Link to post Share on other sites
JhonataKFZ Posted September 13, 2017 Report Share Posted September 13, 2017 What changes in this version? my last was AVIC-F980BT 1.04 Quote Link to post Share on other sites
jdmoreir Posted October 1, 2017 Report Share Posted October 1, 2017 Dear I have a Pioneer AVIC F960BT With new 1.15 version,You have a new testmode_a.key compatible??? Thank you... Quote Link to post Share on other sites
SpecTrax Posted October 1, 2017 Report Share Posted October 1, 2017 Dear I have a Pioneer AVIC F960BT With new 1.15 version,You have a new testmode_a.key compatible??? Thank you... Hi, read this thread again......your answer is there (and file) Quote Link to post Share on other sites
Navst3r Posted October 10, 2017 Report Share Posted October 10, 2017 SpecTrax will this work nex8100? platform x100: AVH-X8700BT - 1.10 - download Quote Link to post Share on other sites
