Anyone needing wire info
By brachoza · Jul 19, 2006in Vehicle Specific Wiring💬 183 posts👁️ 87,850 views
Page 4 of 8
Posted Jan 11, 2007 · 03:47 UTC#76
2006 Toyota 4Runner
Speed Sense purple/red ECM, 2nd plug from bottom, pin 8
Notes: The ECM (Engine Control Module) is behind the glovebox.
Also found at the radio harness or, if equipped, the stereo amplifier behind the passenger side quarter panel.
Reverse Light red/yellow + left of fuses, 16 pin plug
merry xmas
Posted Jan 15, 2007 · 00:51 UTC#77
Working on the installation for avic80 on my 2002 lexus rx300. I have been trying to find the VSS wire with no luck. Appreciate some guidance.
PS. I found one piece of info from Directwire. it says the speed sensor is the violet/white wire out of the cruise control computer above the driver fuse box. I assume it's the fuse box below the instrument panel and the two connectors right above it, but had no luck in locating it there...
Posted Jan 16, 2007 · 10:44 UTC#78
VSS for a 1998 Mercury Grand Marquis LS
Any help would be appreciated, thanks!
Posted Jan 25, 2007 · 15:58 UTC#79
VSS wire for 1995 3000GT VR4! THANKs!!!!
Posted Jan 25, 2007 · 16:35 UTC#80
yeah, for a 1999 3000gt also (should be the same)
Posted Jan 25, 2007 · 23:14 UTC#81
1995 Mitsubishi 3000 GT
Speed sense yellow/white at the cluster
1999 Mitsubishi 3000 GT
Speed sense white/red at the diagnostics plug
merry xmas
Posted Jan 25, 2007 · 23:29 UTC#82
merry xmas
thank you...
Posted Jan 25, 2007 · 23:29 UTC#83
no prob
Posted Jan 28, 2007 · 16:42 UTC#84
2006 chevy silverado
i have looked in every book and i cant seem to find it also the auto dimming i have all the wires hooked up to the harness and the dimming feature doesnt worked
denny
thank you in advance
Posted Jan 28, 2007 · 16:50 UTC#85
Speed Sense = dk. green/white 4K instrument cluster, pin A4 or PCM
The PCM (Powertrain Control Module) is in the left front of the engine compartment to the left of the fan shroud.
On gas models, the VSS wire is in the green plug, pin 50.
On diesel models, the VSS wire is in the black 58 pin plug, pin 42.
thats all i got
Posted Jan 28, 2007 · 16:56 UTC#86
i have notice on the intrument cluster there was 4 dk grn wires can it be hooked up to that
denny
Posted Feb 01, 2007 · 04:38 UTC#87
anybody knows the VSS and REVERSE wires for a 2007 nissan frontier crew cab and location on the harness to tap into.
also same wires for a 2006 toyota corolla. thank you very much.
Posted Feb 01, 2007 · 04:45 UTC#88
frontier, 06 i dont have 07 info, but 06 is
Speed Sense = lt. blue radio harness or cluster, pin 6
May not be present on vehicles with base level audio systems.
Reverse Light = lt. blue + driver kick, harness to rear
Toy cor. 06
Speed Sense = purple/white ECM, second plug from right, pin 17 The ECM (Engine Control Module) is behind the glove box.
Reverse Light = red/black + front of fuse box, 10 pin plug
Posted Feb 01, 2007 · 05:12 UTC#89
Toy cor. 06
thanks for the reply. i will try them. also i forgot....
same wires for a 2006 honda pilot without RES or Navi.
will be installing pioneer N3' on my frontier and corolla and pioneer z1 on the pilot. thanks
Posted Feb 01, 2007 · 05:17 UTC#90
pilot 06
Speed Sense = blue/white driver multiplex ctrl unit, pin 14 The driver multiplex control unit is attached to the driver side fuse box. It has a green 22 pin plug on the side of the fuse box facing the firewall.
Reverse Light = green/black + passenger kick, harness to rear
Posted Feb 05, 2007 · 01:51 UTC#91
thanks for the reply and i manage to do all of three this past weekend. i ran ito a problem tho with the frontier. for the reverse wire, you said light blue in driver kick panel, harness to rear. can you explain this a little further? i have a couple of harness back there (6 to be exact) and some of them have light blue ones. would you know how many pins on this harness you are talking about? appreciate your help. thank you.
Toy cor. 06
Posted Feb 05, 2007 · 02:38 UTC#92
The post in my sig should answer that question for you.
Posted Feb 05, 2007 · 04:10 UTC#93
you could just test each one with a meter to see what works for you to, I dont know more then I posted, sorry
Posted Feb 11, 2007 · 23:14 UTC#94
I need help with a 2007 Toyota Sequoia SR5 with JBL Premium sound:
Where is the speed sense wire, reverse wire and ILL?
Tx.
Posted Mar 07, 2007 · 22:35 UTC#95
I'm going to install my Z1 in a 04 SRX AWD 3.6L with Onstar/phone, and no Bose system or factory navigation. My questions are where do I locate the VSS and reverse wires? Also, I know I'll keep the Onstar, though will I lose the the Onstar phone capability in the car? I was told I'll lose the dash computer display capability and Onstar/phone/nav display readout on the factory radio when I install the Z-1. Any tips on popping off the dash trim plates for the install are appreciated as well.
Posted Mar 07, 2007 · 22:45 UTC#96
Where is the VSS for a 3000gt?
Posted Mar 08, 2007 · 02:09 UTC#97
Search and ye shall find. that has been posted for both a 95 and 98.
Posted Mar 08, 2007 · 03:45 UTC#98
yup impecable memory. I asked a long time ago.
Posted Mar 24, 2007 · 17:43 UTC#99
Does anyone happen to know where the VSS wire is located in the 2005 Chrysler Pacifica. I am trying to install a AVIC Z1 into my Pacifica and need the wiring info. Also I have misplaced my connector 1 wiring harness but I have an AVIC N2 wiring harness does anyone have a wiring diagram for the AVIC Z1 connector 1 harness?
Thank for the help
Posted Mar 26, 2007 · 17:39 UTC#100
Anyone know the location of the illumination wire in a 2003 Camry w/ stock JBL?
Page 4 of 8
