Anyone needing wire info
By brachoza · Jul 19, 2006in Vehicle Specific Wiring💬 183 posts👁️ 87,850 views
Page 5 of 8
Posted Mar 29, 2007 · 17:28 UTC#101
Hello,
I was just wondering where I could find the VSS wire for a 2002 Mitsubishi Eclipse
Ant
Posted Mar 29, 2007 · 18:57 UTC#102
05 Pacifica
2 options either go to a wheel speed sensor or you can get a canbus interface from pac-audio.com
03 Camry
The illumination wire is green in the radio harness. VSS is purple/white in the clock's harness
02 Eclipse
Speed Sense white/blue center console
Notes: Located in a large white 38 pin plug behind the radio.
merry xmas
Posted Mar 29, 2007 · 19:43 UTC#103
Your great! Thanks
Posted Mar 29, 2007 · 21:59 UTC#104
For the reverse wire, couldnt I just wire it into the positive on the Backup lights?
Posted Mar 30, 2007 · 02:41 UTC#105
Yes you could run a wire ALL the way to the back of the car or you can get it in the front of the car, here
Reverse Light red/blue + pin 9, 43 pin plug in driver kick
merry xmas again.
Posted Mar 31, 2007 · 23:01 UTC#106
i need to find he vss and the reverse wire on a 2003 ford f150 harley davison edition pickup truck.. does anyone know where to find them?
Posted Apr 01, 2007 · 00:36 UTC#107
Vss is gray/black in the radio harness. Reverse is black/pink in the driver's kick.
Posted Apr 01, 2007 · 04:23 UTC#108
vss and reverse for 04 camry..thanks
Posted Apr 01, 2007 · 05:33 UTC#109
Posted same as an 03
Posted Apr 01, 2007 · 10:38 UTC#110
Hi,
I went to the web site the OP pointed to to find vss for 97 camry v6. I must have spent an hr looking for the violet/yellow wire but couldn't find it. I could find the 22pin connector on the ECM but the color doesn't match. Could anyone help? Thanks.
aqn
Posted Apr 01, 2007 · 18:47 UTC#111
Looking for the location of the vss wire in a 2006 Toyota RAV4.
Thanks for anyone's help.
Posted Apr 01, 2007 · 19:17 UTC#112
I tapped my Vss (gra/black) (using a T-tap) at the radio plug (the secondary plug not used with the adapter for the aftermarket HU) and it worked ok for a while then my GPS started going haywire, showing me driving backwards and sideways. Did I do something wrong, do I have a bad connection maybe, is there some setup Im doing wrong?
Posted Apr 03, 2007 · 23:53 UTC#113
i need to find where my wires are for the vss and the reverse i have a 2003 ford f150 harley davison edition truck i looked for the vss in radio harness and cant find it.
Posted Apr 04, 2007 · 06:22 UTC#114
Hello,
I'm looking for the VSS wire for a 2001 Honda Accord EX manual transmission vehicle. I read that it was suppose to be in the passenger side center console under the carpetting, but I was unable to locate it. Is the ECM computer in a different location for a manual transmission Accord? Thanks in advance for any help provided.
Posted Apr 04, 2007 · 06:43 UTC#115
Hi there!
Just wondering what is the VSS and reverse light wire for the 2001 Nissan Frontier crew cab v6.
Thanks in advance!
Posted Apr 04, 2007 · 11:50 UTC#116
reyd1 said:
Hi there!
Thanks in advance!
Speed Sense dk. green/black ECM
The ECM is located below the heater box to the right of the accelerator pedal, behind trim panel. The tach is in the top row, 3rd pin left of center of the plug. The VSS is in the 2nd row from the top, 4th pin right of center.
Posted Apr 04, 2007 · 11:52 UTC#117
Mossman said:
Hello,
Speed Sense blue/white ECM
Located at the first plug on the ECM, it is a 32 pin gray plug. The ECM plugs can be accessed by pulling up the carpet on the passenger side of the center console. There are 4 plugs total.
Posted Apr 04, 2007 · 11:55 UTC#118
Speed Sense purple radio harness (except JBL)
On the JBL audio systems, the VSS wire is at the amplifier in the passenger side rear quarter panel.
Posted Apr 04, 2007 · 11:58 UTC#119
Speed Sense purple/white clock
Reverse Light red/black + driver kick, harness to rear
Posted Apr 04, 2007 · 14:27 UTC#120
2007 camry Se with the jbl system speed pulse and reverse....and if ive read correctly somewhere...the speed pulse is under the center console...and for the reverse do i connect back at the light?
Posted Apr 04, 2007 · 15:15 UTC#121
Brachoza,
Do you have the vss wire for 2007 VW Eos. I asked this question few months back and you didn't have it. I am hoping that you might have the information by now.
Thanks,
Posted Apr 04, 2007 · 16:05 UTC#122
HELLO!!! :roll:
Posted Apr 04, 2007 · 17:36 UTC#123
MisFit said:
reyd1 said:
Hi there!
Thanks in advance!
Cool thanks.. Anyone know where the reverse wire is or should I wire it from the rear?
Posted Apr 04, 2007 · 23:45 UTC#124
Reverse Light red + driver kick, 17 pin plug, pin 9
Speed Sense purple radio harness or amp under pass seat
Posted Apr 05, 2007 · 13:36 UTC#125
I'm looking for the VSS/reverse/brake connections and box location on a 2004 Ford Excursion (diesel).
I'm installing an AVIC-Z2 this weekend and can use any help anyone has to offer.
Thanks, in advance.
--Ryan
Page 5 of 8
