All Activity
- Past hour
InvisibleKnight joined the community
- Today
resistol started following Smartphone Confirm bypass for x000 units
I Need the Password. ThankYou
- Yesterday
Read this thread to find and install the last firmware and maps for the AVIC F920-BT http://avic411.com/index.php?/topic/85011-new-release-f20bt-f30bt-f40bt-f920bt-f930bt-f940bt-f840bt-etc-2019/&do=getNewComment Note: the firmware and maps are updated together, not separately. Bluetooth drivers are a separate step. You say your Bluetooth is not working, so it might have a hardware problem which new firmware can't fix. These units are about 15 years old so hardware problems are common. You sound unfamiliar with Pioneer nav units. The SD is ony used for updates, and to play m
zapzap started following Old AVIC-F920BT brought back to life
Hello everyone! Apologies in advance for terrible english, but whatever. I came across an older Pioneer, an AVIC-F920BT and scored a great deal on it and figured I'll put it to use right away. Everything of the wiring was hassle-free to mount and connect, but the software itself seems to be a challenge for me. I have done a fair bit of googling around on it and found out I've got stuck and am now going to ask the professionals for help.... on this forum, that is. I want to upgrade the firmware on it, since it is platform version 2.000 and Application version i
zapzap joined the community
- Last week
Hello, sorry for my bad English. (Google translator) My radio, AVH-Z9200DAB, also gave the error message a few days ago, software error. I would now like to install the firmware from the AVH-Z9100DAB. I found the firmware on the Pioneer website. It is a zip file, how do I make an image from it? I hope you can help me.
sayj joined the community
khokharimran266 joined the community
Did the file from the first post but then the radio goes into the firmware failure screen and I did everything right but can't write a different file or anything. It's the 4400nex
Xnitro67 joined the community
Hi, can you provide the detailed instrucitons on how to repair or point me the way. thanks i know how to solder, board level IC.
I have seen some people here that say they know the password code to unlock the sd card, but I do not know it and I don’t even know how to unlock it even if I did. There are far smarter people than me that show up from time to time that could maybe help, but unfortunately that person is not me. Sorry I cannot help any further, that is all I know.
Jammer70 joined the community
Thanks, Datsun, for the info. Does this mean that there is no way to duplicate a working stock sd card?
If you pulled this card from a working 4200 then the card is password protected. Once you place the stock sd card in a unit and turn it on the unit it will protect the card.
I have the stock SD card out and I want to backup the image. But I still don't know how. I'm happy to share it here if I could extract the image from the stock SD card.
I have removed the SD card from my AVH-4200NEX headunit. The pupose is to backap the image file. However, using an SD card reader, the stock SD card is not detected in WIndows. The SD card reader is working with other SD cards. So how to backup the stock SD card in Windows 11? I installed Ubuntu WSL (in windows 11) but the stock SD card is still not detected. Any help would be greatly appreciated.
SandPatrol joined the community
- Earlier
Thanks for sharing, this helped me out too for DMH-1770NEX. So far my car radio seems better off, but the problem has been intermittent before the fix, so may take a week or two to know for sure if this fixed it on my end. There was nearly no solder on the pins as-is, so hoping this will stay ok. I'm curious if anyone has the forced update files for DMH-1770NEX? I have the latest firmware (CUST_PIO.BIN w/ CUST_PIO.md5), but wasn't sure if the additional files (ISPBOOOT.BIN, ISPBOOOT.md5, turndegradedmode) from the upload are compatible with this model. Would like to do this just to have a
Thanks for your feedback. we now know it works I was glad to help
@asd255 i know its been a while since you posted this, but i joined the site just to thank you...my 1770nex was freezing and rebooting nonstop...only once a white screen....when i pulled the unit apart, the chip didnt even look soldered, i flowed it, but also tapped it with the iron so i could actually see some solder...so far hasnt frozen once....so thanks very much!!!
How do I import a GPX file with routing data and way points. It is from an RV safe routing program but I want to use my indash GPS.
I have the same problem with my engine. I also think I messed up by forcing it. Did you find any solution?
So I recently had this problem. Happy to have found this thread. Even though I still encountered some hurtles. So have a ZF9350BT. Basically the SE Asian equivalent. On this unit the face is on a set of rails that slide out from the bottom which made this a challenge to get to the hidden SD card. The power went while I was working this at my kitchen table and I accidentally damaged the ribbon connection to the screen. Luckily I was able to have my local computer guy fix it for $60. But had a seemingly good idea. He asked if I intended to sell the head unit. I said no, I’ll use it til
drgsrbad81 changed their profile photo
Double checking my F90BT map and license install is correct.
samsonwilliams replied to TimboZero's topic in Hacks/Mods
No other map files are active on your system. -
I don´t want the unit to select source by it self
Optimus posted a topic in Problems/Troubleshooting
I have a Pioneer AVIC-F80DAB and I want to charge my phone with USB from the device even though I want to listen to regular FM radio. But the device changes source every time I plug it in and go into Apple Carplay. If I have then selected Phone there, the sound is not interrupted, but it goes to Phone on Carplay but continues to play FM radio. If i played Spotify the last time, Spotify starts playing when I connect the phone. But I would like to choose manually to go to Carplay (or other source) but I can't find anywhere to turn off the auto-selection. Is there any possibility to do -
mitsumi99 changed their profile photo
w4500nex [FIX] SDCard Failed? Software Error on your w4500nex? Look here!
Datsun replied to slackwaredragon's topic in NEX Series
There is nothing that I know of that can be done once the sd card is locked. Someone else can chime in if they have an answer. -
Tekem replied to slackwaredragon's topic in NEX Series
Is there some test-mode that we can boot into for the W4500NEX? I tried using what i found on the forum, even on my older 4201NEX, and I was unsuccessful. If I can boot in a test-mode and can make a backup image, it would probably be ideal -
F970BT suddenly not updating maps anymore
mitsumi99 replied to heeranders's topic in Problems/Troubleshooting
#!/system/bin/sh set -e set -x mount -o remount,rw /system #patch iGO cat /mnt/udisk/updates/libigo_jni.so >/system/lib/libigo_jni.so chmod 644 /system/lib/libigo_jni.so #backup iGO cp -R /extdata/iGO /mnt/udisk/backup/iGO #copy files iGO chmod -R 777 /extdata/iGO/ rm -f -r /extdata/iGO cp -R /mnt/udisk/updates/iGO /extdata/iGO
