All Activity
- Today
Купить Кокаин в Москве и России? Сайт - KOKS.CC Купить Лучший Кокаин в России? САЙТ - KOKS.CC . . . . . . . . . Как Купить Кокаин в Москве и России 24/7 САЙТ - https://koks.cc/ Где Купить Кокаин в Москве закладкой 24/7 САЙТ - https://koks.cc/ Заказать Кокаин в Москве с доставкой? САЙТ - https://koks.cc/ Покупка в руки лучший Кокаин в Москве 24/7 САЙТ - https://koks.cc/ Качественный Кокаин в России Купить через САЙТ - https://koks.cc/ . . . . ДЛЯ ЗАКАЗА КОКАИНА В ДРУГИХ ГОРОДАХ РОССИИ НУЖНО НАПИСАТЬ НА САЙТ - https://koks.cc/ . . . . . . . .
Thanks for sharing, this helped me out too for DMH-1770NEX. So far my car radio seems better off, but the problem has been intermittent before the fix, so may take a week or two to know for sure if this fixed it on my end. There was nearly no solder on the pins as-is, so hoping this will stay ok. I'm curious if anyone has the forced update files for DMH-1770NEX? I have the latest firmware (CUST_PIO.BIN w/ CUST_PIO.md5), but wasn't sure if the additional files (ISPBOOOT.BIN, ISPBOOOT.md5, turndegradedmode) from the upload are compatible with this model. Would like to do this just to have a
SnoopKatt joined the community
- Yesterday
blackpink jennie, one in all the stylish icons, has seen a sequence of alexander wang outfits on ig before and has triggered lots of echoes. this difficulty is wearing mild monster sunglasses to "burn" anyone! in this promotional photo, now not best jennie is wearing a photo, however additionally the canine at home is dispatched to help "deliver the products". it's so adorable~ Brisbane asian escorts
smoovla1 joined the community
- Last week
Thanks for your feedback. we now know it works I was glad to help
Jason pioneer joined the community
Ambroseakic joined the community
@asd255 i know its been a while since you posted this, but i joined the site just to thank you...my 1770nex was freezing and rebooting nonstop...only once a white screen....when i pulled the unit apart, the chip didnt even look soldered, i flowed it, but also tapped it with the iron so i could actually see some solder...so far hasnt frozen once....so thanks very much!!!
jb. joined the community
Glenntikdah joined the community
azombie8me joined the community
How do I import a GPX file with routing data and way points. It is from an RV safe routing program but I want to use my indash GPS.
- Earlier
I have the same problem with my engine. I also think I messed up by forcing it. Did you find any solution?
So I recently had this problem. Happy to have found this thread. Even though I still encountered some hurtles. So have a ZF9350BT. Basically the SE Asian equivalent. On this unit the face is on a set of rails that slide out from the bottom which made this a challenge to get to the hidden SD card. The power went while I was working this at my kitchen table and I accidentally damaged the ribbon connection to the screen. Luckily I was able to have my local computer guy fix it for $60. But had a seemingly good idea. He asked if I intended to sell the head unit. I said no, I’ll use it til
drgsrbad81 changed their profile photo
Double checking my F90BT map and license install is correct.
samsonwilliams replied to TimboZero's topic in Hacks/Mods
No other map files are active on your system. -
I don´t want the unit to select source by it self
Optimus posted a topic in Problems/Troubleshooting
I have a Pioneer AVIC-F80DAB and I want to charge my phone with USB from the device even though I want to listen to regular FM radio. But the device changes source every time I plug it in and go into Apple Carplay. If I have then selected Phone there, the sound is not interrupted, but it goes to Phone on Carplay but continues to play FM radio. If i played Spotify the last time, Spotify starts playing when I connect the phone. But I would like to choose manually to go to Carplay (or other source) but I can't find anywhere to turn off the auto-selection. Is there any possibility to do -
mitsumi99 changed their profile photo
w4500nex [FIX] SDCard Failed? Software Error on your w4500nex? Look here!
Datsun replied to slackwaredragon's topic in NEX Series
There is nothing that I know of that can be done once the sd card is locked. Someone else can chime in if they have an answer. -
Tekem replied to slackwaredragon's topic in NEX Series
Is there some test-mode that we can boot into for the W4500NEX? I tried using what i found on the forum, even on my older 4201NEX, and I was unsuccessful. If I can boot in a test-mode and can make a backup image, it would probably be ideal -
F970BT suddenly not updating maps anymore
mitsumi99 replied to heeranders's topic in Problems/Troubleshooting
#!/system/bin/sh set -e set -x mount -o remount,rw /system #patch iGO cat /mnt/udisk/updates/libigo_jni.so >/system/lib/libigo_jni.so chmod 644 /system/lib/libigo_jni.so #backup iGO cp -R /extdata/iGO /mnt/udisk/backup/iGO #copy files iGO chmod -R 777 /extdata/iGO/ rm -f -r /extdata/iGO cp -R /mnt/udisk/updates/iGO /extdata/iGO -
What is the history of this unit? Did you buy it used and install it yourself, or maybe bought a car with it already installed? The grayed settings indicate it isn't properly installed. There's lots of info on how to do the parking brake bypass, sounds like you need to read-up or watch YouTube vids. However if the parking brake wire is indeed missing from the harness, that must be corrected regardless of whether you install it as specified by Pioneer or do the bypass (moving the mute wire) Btw, the x910bt has Bluetooth (that's what "bt" stands for in the model name). So don't blame Pionee
Why can't I get into my settings menu? It's all grayed out and the only thing that works is the radio? I can't get into settings and I believe the parking wire is missing when it was bought is there anything I can do to fox this? Do I jus move the mute wire over to the other spot that everyone's mentioning? Someone please help? And the fact that it doesn't have Bluetooth is pretty crappy.. Why would pioneer do such a thing?
[HELP] - Apple iPad 10th Generation has been locked
Annetta replied to Annetta's topic in iPod/iPhone/iPad
Finally I have unlocked my iPad. After posting the thread here when I did not get any response then I searched on Google and came across this useful guide. The task which I followed to unlock my iPad, first I pressed & hold the top button until see the power off slider. Then dragged the slider for turning of and waited for a while for it to shut down completely. It was a painful experienced I never forget. But now I feel relax to solve the issue. -
Once the sd card is placed in a unit and turned on the card becomes password protected. There are people here who say they know that password but I do not. Even if I did, I do not know how to unlock the card. Maybe others can help. -
I need a serious help friends. I have forgotten my Apple iPad 10th generation password. After trying a several attempts, my iPad has been locked. Can anyone please help me how to unlock my iPad?
TimboZero replied to TimboZero's topic in Hacks/Mods
No one able to assist please? -
I have a working W4500NEX SDcard. How can we go about test booting the W4500NEX unit to make a good a backup copy that can be applied to a higher quality SD card?
I have two W4500NEX headunits. the SD card failed on one of them. How do I backup the other one on the unit that is still working? I easily removed the SD card, but I cannot read it in Windows to backup up or make an image. I merely want to make a block level copy so I can use a reputable SD Card brand to mitigate this issue. -
Pen3 replied to RonS's topic in Hacks/Mods
Thank you, it worked immediately. -
RonS replied to RonS's topic in Hacks/Mods
Download the attached file and unzip. Then replace the Cardinfo.cif file on the update SD with the unzipped one. Z110Z120X920CARDINFO.zip
