DJDisturbed Posted April 16, 2009 Report Share Posted April 16, 2009 Has anyone else gotten the "LoadLanguages init failed" error when trying to load up iGo from LeetLauncher 3.0? edit: Looks like the reason this was happening is because the LeetLauncher 3.0 zip is set up with a sys.txt that points at a language file it doesn't ship with. You can either fix the sys.txt, or just grab the file from APL2\iGo\CONTENT\LANG\Lang_English-us.zip I'm getting this same issue, can you explain exactly what to change in the file? the sys.txt file all has links in it pointing to "MYFLASHDISK" and i want to make shure that i'm putting the right codeing in there to make it work right. HELLO? anyone help out here. BTW, after every time i try leetlauncher and i take out the sd card to go back to the original avic software the avic sortware keeps hanging up in the "Please Wait system loading/starting" thing and I have to hit the reset button like 3 or 4 times for it to start up right and not lock up. This only happends after i use leetlauncher. Quote Link to post Share on other sites
dpdurst Posted April 16, 2009 Report Share Posted April 16, 2009 I don't recall if I had the problem or not, I think I did and just copied the leetlauncher 2.0 files for IGO to the 3.0 and ran it. Then I copied my files over I had saved. As for your other problem, are you turning the car off, removing the SD card and then starting the car up? As long as you do do that it should work fine, mine does. Quote Link to post Share on other sites
DJDisturbed Posted April 16, 2009 Report Share Posted April 16, 2009 As for your other problem, are you turning the car off, removing the SD card and then starting the car up? As long as you do do that it should work fine, mine does. thats exactly the same way i did it, dunno whats causing the issue but oh well, I just wanted to have a look at it. I'm still trying to learn the f90 (i just put it in last week) so I don't want to mess around with it too much. Quote Link to post Share on other sites
basstoy Posted April 16, 2009 Report Share Posted April 16, 2009 ok a few questions,,, 1. does this run off the sd card? or do I have to modify the unit.... meaning that if I dont like it I just remove sd card reboot avic and Im back to what I had before... 2. say I have tom tom, igo8 and garmin maps and cracks/licences... where would I put these? thank you Quote Link to post Share on other sites
dpdurst Posted April 16, 2009 Report Share Posted April 16, 2009 ok a few questions,,, 1. does this run off the sd card? or do I have to modify the unit.... meaning that if I dont like it I just remove sd card reboot avic and Im back to what I had before... 2. say I have tom tom, igo8 and garmin maps and cracks/licences... where would I put these? thank you 1. Yep runs off the SD card, if you don't like don't run the SD card. 2. All GPS run off SD card as well. There is directory for IGO already. I have no clue about TOMTOM or Garmin 3. Pioneer unit options other than USB, BT Phone, CD do not work in this version. Music and Movies run from SD as well. Quote Link to post Share on other sites
yoav Posted April 17, 2009 Report Share Posted April 17, 2009 HELLO? anyone help out here. I guess I assumed my description of the fix was 'good enough'. I guess not. If you are getting the LoadLanguages Init failed error, you need to put in the LeetLauncher SD and boot up the machine. Then from Applications (system), you need to select 'Windows Explorer' (or somesuch name.. it's a system tool that basically lets you muck around with the filesystem. sorry I dont have the car with me.. Then, at the *start menu at the bottom, you need to open up an explorer window, and go to the Flash Disk (double-click it). In there is a folder named APL2 -- double click -- iGo -- double -- CONTENT / LANG / In that folder is a file named Lang_English-us.zip . Click on it once to select. Then from the menubar at the top, select 'Edit.. Copy' Now use the back arrow to go all the way to the top, and instead of selecting the Flash Disk, you should select the Storage Card (the one you have LeetLauncher on). In there, go to iGo/Content/Lang/ and select from the menubar 'edit... paste'. Ok that should fix *THAT* problem for you. You will still need to get maps, keys, etc so you have a LOT more crap to do. Quote Link to post Share on other sites
yoav Posted April 17, 2009 Report Share Posted April 17, 2009 2. say I have tom tom, igo8 and garmin maps and cracks/licences... where would I put these? Given that tomtom and garmin don't have a 'crack license' I don't think you have those. iGo goes under IGo8/License/ TomTom should have come with instructions. it's not a license.. you need to unlock a map to your nav system based on the map's key and your nav's key. Map goes in toplevel. Key goes under TomTom/ Garmin goes in the Garmin/ folder. Again it's a generated file. Anyways, whatever you did should have come with instructions. Quote Link to post Share on other sites
DJDisturbed Posted April 17, 2009 Report Share Posted April 17, 2009 HELLO? anyone help out here. I guess I assumed my description of the fix was 'good enough'. I guess not. If you are getting the LoadLanguages Init failed error, you need to put in the LeetLauncher SD and boot up the machine. Then from Applications (system), you need to select 'Windows Explorer' (or somesuch name.. it's a system tool that basically lets you muck around with the filesystem. sorry I dont have the car with me.. Then, at the *start menu at the bottom, you need to open up an explorer window, and go to the Flash Disk (double-click it). In there is a folder named APL2 -- double click -- iGo -- double -- CONTENT / LANG / In that folder is a file named Lang_English-us.zip . Click on it once to select. Then from the menubar at the top, select 'Edit.. Copy' Now use the back arrow to go all the way to the top, and instead of selecting the Flash Disk, you should select the Storage Card (the one you have LeetLauncher on). In there, go to iGo/Content/Lang/ and select from the menubar 'edit... paste'. Ok that should fix *THAT* problem for you. You will still need to get maps, keys, etc so you have a LOT more crap to do. ok so i just need to move the original lag file to the sd. I'm doing this on my computer since i have a compleat back-up my the flash disk here. Quote Link to post Share on other sites
gepap01 Posted April 18, 2009 Report Share Posted April 18, 2009 superr Quote Link to post Share on other sites
adamtaylorpcb Posted April 18, 2009 Report Share Posted April 18, 2009 cat get it to load the update i unzipped it to the sd card and it dosnt work am i supposed to just leave the big "3.0" folder on the sd or do i need something else on the base of the sd? Quote Link to post Share on other sites
minifreezer Posted April 18, 2009 Report Share Posted April 18, 2009 copy everything inside the 3.0 folder to the sd card Quote Link to post Share on other sites
DJDisturbed Posted April 18, 2009 Report Share Posted April 18, 2009 copy everything inside the 3.0 folder to the sd card AND get the maps files for the diff programs and add them to there right places. Quote Link to post Share on other sites
adamtaylorpcb Posted April 18, 2009 Report Share Posted April 18, 2009 do any of the maps require anything more than just the maps? like subscription or a crack Quote Link to post Share on other sites
minifreezer Posted April 19, 2009 Report Share Posted April 19, 2009 copy everything inside the 3.0 folder to the sd card AND get the maps files for the diff programs and add them to there right places. Oh yeah and do that too. Thanks DJDisturbed Quote Link to post Share on other sites
adamtaylorpcb Posted April 19, 2009 Report Share Posted April 19, 2009 do any of the maps require anything more than just the maps? like subscription or a crack Quote Link to post Share on other sites
Join the conversation
