misterblue Posted October 11, 2009 Report Share Posted October 11, 2009 In this version you can not disable the audible speed camera by simply clicking on the alert window visual ? Quote Link to post Share on other sites
ill.die.trying Posted October 11, 2009 Author Report Share Posted October 11, 2009 In this version you can not disable the audible speed camera by simply clicking on the alert window visual ? Â it should be a longclick Quote Link to post Share on other sites
misterblue Posted October 11, 2009 Report Share Posted October 11, 2009 In this version you can not disable the audible speed camera by simply clicking on the alert window visual ? Â it should be a longclick ok, but it only appears more icon to indicate that the audible speed camera is off, on which you click to activate this function? Quote Link to post Share on other sites
maleon Posted October 11, 2009 Report Share Posted October 11, 2009 warning radar in Spanish? are very large buscar Quote Link to post Share on other sites
ill.die.trying Posted October 11, 2009 Author Report Share Posted October 11, 2009 warning radar in Spanish? are very large buscar  i don't know what you mean? Quote Link to post Share on other sites
maleon Posted October 11, 2009 Report Share Posted October 11, 2009 warning radar in Spanish? are very large buscar  i don't know what you mean?   I mean the voice that speaks, if I could speak Spanish Quote Link to post Share on other sites
misterblue Posted October 11, 2009 Report Share Posted October 11, 2009 do you like me, you are properly registered voice in your language and you change the language files from the UK want. Quote Link to post Share on other sites
maleon Posted October 11, 2009 Report Share Posted October 11, 2009 do you like me, you are properly registered voice in your language and you change the language files from the UK want. Â as I do that??? Quote Link to post Share on other sites
ill.die.trying Posted October 11, 2009 Author Report Share Posted October 11, 2009 Â thanks for the donation bro Quote Link to post Share on other sites
69sixpackbee Posted October 11, 2009 Report Share Posted October 11, 2009 No sabes Quote Link to post Share on other sites
pkbristol Posted October 11, 2009 Report Share Posted October 11, 2009 Hi IDT. I just installed your latest mod, it's very good, one thing i have notuced though, i can't switch my unit off via the menu>source>off, i have to actually switch off the ignition. Â One more question, if i try to find an address via a post code and that post code happens to be an unmarked road, the unit freezes up and i get a little grey widow pop up saying something about not having enough memory, and something about the cache too, i can use the hard menu button and select the source>radio or whatever and get to that, but i can't get back to the map. Any thoughts ? Â Thanks, Paul. Quote Link to post Share on other sites
ill.die.trying Posted October 11, 2009 Author Report Share Posted October 11, 2009 Hi IDT.I just installed your latest mod, it's very good, one thing i have notuced though, i can't switch my unit off via the menu>source>off, i have to actually switch off the ignition. Â One more question, if i try to find an address via a post code and that post code happens to be an unmarked road, the unit freezes up and i get a little grey widow pop up saying something about not having enough memory, and something about the cache too, i can use the hard menu button and select the source>radio or whatever and get to that, but i can't get back to the map. Any thoughts ? Â Thanks, Paul. Â i will try to find out regarding the running out of memory, Â regarding the turning off, AFAIK the mod has nothing to do with it as that would be handled by av.exe and not igo, though i will try on mine and see if it acts the same way Quote Link to post Share on other sites
misterblue Posted October 12, 2009 Report Share Posted October 12, 2009 bug report on version TMC. i'm EU user -In demo mode, the buttons do not appear unless the button "Stop" Â -When I appear the second window info (long click on the hour) . If I click on the button "return", a "day / night" mode is in "auto" . If I click on the button "Map", a "day / night" becomes "day" forced (checked in options) Â -When there is a radar warning (visual mode "Full" and audible "activated") and I am a "longclick" on the high alert window and I released, the small window appears altert visual and sound of alerts is not muted. By cons when looking at the radar via the option menu, it is clear that audibly alerts are disabled. Yet radar audible alarms continue to function. Then it is impossible to return to the great visual alert window by clicking on the small alert window, why we must cut the contact. Â I can not find the alert mode reduces visual interesting. I find it better to have the possibility to mute the radar alerts by simply clicking on the alert window. For the rest of this mode is really great, thank's IDT. Quote Link to post Share on other sites
pkbristol Posted October 12, 2009 Report Share Posted October 12, 2009 Hi IDT. The switching off issue has gone away, it only happened after the first boot up after the new mod was installed, so i can now switch off via the menu. Â The pop up window saying out of memory and the cache thing still comes up when i try and find or navigate to a postcode on an un-named road, this happens on both of my F910's, one has the final tmc mod, the other has the previous mod. If someone out there (UK based) has an unmodded unit then perhaps they could try this postcode, GL19 3BE, please could you post what happens. Â Thanks. Paul. Quote Link to post Share on other sites
DocBen Posted October 12, 2009 Report Share Posted October 12, 2009 Excellent work IDT. Thanks for everything. I have been wondering to myself how long you would keep at this...you kept it up longer than I would have. Salud! Quote Link to post Share on other sites
Join the conversation
