diaftia Posted January 23, 2010 Author Report Share Posted January 23, 2010 Maybe Merten or Diaftia can use the speedsign to access TMC In navigatemap_800_480.ui Change this ;Posted Speed To This ;Posted Speed Currently clicking on the Speed Limit Sign will add a new speed cam. With the change above this will happen on a long click. A short click will take you to the TMC events Cheers 34by151 This will work fine but I would suggest using a different image. The image you are using I am pretty sure is the posted speed sign the only shows when the map data knows what the speed is on that road. I would use the "your speed" sign instead since its always displayed on the map. Quote Link to post Share on other sites
merten3000 Posted January 23, 2010 Report Share Posted January 23, 2010 if you use the new TMC button it messes up the settings screen. After that all settings screens atre messed up even if you go there through the other ways In navigatemap_800_480.ui / Change this line to Cheers 34by151 Thnx again!!! Will give it a try and if it works I will send Alex DaftiaV2.3_EU_fixed.rar with all your fixes applied!! Have to wait for testing untill my wife gets back from groceries with the car... Just tested and yes it fixes the whole TMC bug! Works like a charm now. Will up fixed EU version so Alex can replace the bugged version! Thnx again 34by151!! Quote Link to post Share on other sites
34by151 Posted January 23, 2010 Report Share Posted January 23, 2010 This will work fine but I would suggest using a different image I agree, not the choice I would make for myself. I have found that I don't need to look at the TMC events very often which is why I put the link in the Quick menu in the first place. I will have new TMC code ready soon which includes, among other features, event based voice warnings and visual references. The Voice warnings announce "TMC type" "Ahead" Ie "accident ahead", "blocked road ahead" ect. The stock code will only announce "Traffic Jam Ahead" even if it it something like an accident. The Visual references allow you to click on the TMC event on the map screen and it will show a pop-up with all the event details. Also a text box on the map screen shows the details on the nearest Tmc Event along your route. Check out the Aussie thread for all the details Just tested and yes it fixes the whole TMC bug! Works like a charm now. Will up fixed EU version so Alex can replace the bugged version! Thnx again 34by151!! You may want to check the code my Aussie version as it switches the functions between TMC and MSN. this way the version is not TMC specific. Cheers 34by151 Quote Link to post Share on other sites
ovalball Posted January 24, 2010 Report Share Posted January 24, 2010 Just took V2.3 EU on a good test drive.Brilliant Mod.Only thing I noticed was that in split screen mode,the numbers aren't in the centre of the speed limit sign ie they are hgalf in the circle and half out.Any ideas on a fix please?Rest of it performed perfectly. Quote Link to post Share on other sites
Segler1963 Posted January 24, 2010 Report Share Posted January 24, 2010 Hi Guys, I'm quite exited after the first test drives today, looks just great. One question: In order to speed up the sattelite fix I have set the following in SYS.TXT: default_latitude="50.10411" default_longitude="8.44079" but it seems to have no impact. Do I need the minus in front of the 8 ? any other ideas? Since I started using mods the sattelite fix takes up to 5 Minutes, I'm sure it has nothing to do with the Antenna or the wiring, as it is much better with the stock verion of the software. Thank for any thoughts Jörg Quote Link to post Share on other sites
merten3000 Posted January 24, 2010 Report Share Posted January 24, 2010 Just took V2.3 EU on a good test drive.Brilliant Mod.Only thing I noticed was that in split screen mode,the numbers aren't in the centre of the speed limit sign ie they are hgalf in the circle and half out.Any ideas on a fix please?Rest of it performed perfectly. Hmmm, thought I fixed that one...but maybe I forgot to change something... will take a look at it later this evening... EDIT: Just checked and are perfectly centered on my device... I use Daftiav2.3_EU_fixed Quote Link to post Share on other sites
ovalball Posted January 24, 2010 Report Share Posted January 24, 2010 Just took V2.3 EU on a good test drive.Brilliant Mod.Only thing I noticed was that in split screen mode,the numbers aren't in the centre of the speed limit sign ie they are hgalf in the circle and half out.Any ideas on a fix please?Rest of it performed perfectly. Hmmm, thought I fixed that one...but maybe I forgot to change something... will take a look at it later this evening... EDIT: Just checked and are perfectly centered on my device... I use Daftiav2.3_EU_fixed Thanks for youe reply.Is Diaftias 2.3_EU_fixed available for download on page 1?I downloaded the version i am using a couple of days ago.Thanks again for your help. Quote Link to post Share on other sites
merten3000 Posted January 24, 2010 Report Share Posted January 24, 2010 Ok, just found out that all my PM's get stuck in my outbox and I can not figure out a way to fix this... Anybody else have problems with the PM's from this forum? That's probably why alex did not receive my PM with the new links. I will put them here and hopefully Alex will change them in 1st post. And I hope even more that the PM system starts working again... Here the links for DaftiaV2.3_EU_Fixed.rar: first post updated by daftia see first post for links to avoid misunderstandings Greetz Merten Quote Link to post Share on other sites
ovalball Posted January 24, 2010 Report Share Posted January 24, 2010 Ok, just found out that all my PM's get stuck in my outbox and I can not figure out a way to fix this... Anybody else have problems with the PM's from this forum? That's probably why alex did not receive my PM with the new links. I will put them here and hopefully Alex will change them in 1st post. And I hope even more that the PM system starts working again... Here the links for DaftiaV2.3_EU_Fixed.rar: http://rapidshare.com/files/340016896/D ... _fixed.rar and http://www.megaupload.com/?d=KCH4RG9P Greetz Merten OK Merten thank you. Update Installed 2.3 EU_fixed and numbers are bang in the middle!Thanks again! Quote Link to post Share on other sites
diaftia Posted January 24, 2010 Author Report Share Posted January 24, 2010 First post updated. Merten and ovalbal you might want to remove these links so when we update in the future someone doesn't come across these links and get an older version. Quote Link to post Share on other sites
merten3000 Posted January 24, 2010 Report Share Posted January 24, 2010 First post updated. Merten and ovalbal you might want to remove these links so when we update in the future someone doesn't come across these links and get an older version. done... Alex as you can read my PM system is fried somehow so please mail me if needed (merten3000@yahoo.com) Quote Link to post Share on other sites
SooTyLaD Posted January 26, 2010 Report Share Posted January 26, 2010 This stuff is flipping brilliant, I went from being really ****** off at the whole thing since it knackered up during the official update, right now its all running and its allllll good Anyway, a quick question regarding the overlay trip computer in the latest EU update (thanks Merten ) - I press the time and it pops up and looks great, but how exactly do you switch it off? I would have thought pressing the clock again would do this but it doesn't - it is switched off another way? Secondly, the display mode seems to keep flicking back to 2D - once again is this me doing something wrong or is there a setting I can change? Cheers guys! top mod! Quote Link to post Share on other sites
ndy4eva Posted January 26, 2010 Report Share Posted January 26, 2010 It doesn't happen all the time but it flips to 2D view once destination is set. Quote Link to post Share on other sites
hma Posted January 26, 2010 Report Share Posted January 26, 2010 Hi, I have a small problem with this brilliant mod. After installing the mod and removing all files from the "save folder" and disabling the "Automatic zoom", I can select a few different view angles of the 3D map (I prefer about one fifth of the image as sky). But after a "navigation of a route", the view angle of the map is only changeable between a min and max. value. Has someone an idea of the reason? Rgds, Hugo Quote Link to post Share on other sites
diaftia Posted January 26, 2010 Author Report Share Posted January 26, 2010 This stuff is flipping brilliant, I went from being really ****** off at the whole thing since it knackered up during the official update, right now its all running and its allllll good Anyway, a quick question regarding the overlay trip computer in the latest EU update (thanks Merten ) - I press the time and it pops up and looks great, but how exactly do you switch it off? I would have thought pressing the clock again would do this but it doesn't - it is switched off another way? Secondly, the display mode seems to keep flicking back to 2D - once again is this me doing something wrong or is there a setting I can change? Cheers guys! top mod! Each of the boxes in the trip computer are shortcuts. The very last one on the right hides it again. The second to the last one resets it. As far as the map goes (if I recall correctly) it saves your position when you are navigating and not navigating. Just switch it in both places and you should be fine. Let me know if this is not what you are seeing and I will look into it. Alex Quote Link to post Share on other sites
