Rubberguy Posted March 18, 2013 Report Share Posted March 18, 2013 If you were able to downgrade to iOS 511 you would have everything working don't know if that's possibility for you?? Link to post Share on other sites
mikedecaro Posted March 18, 2013 Author Report Share Posted March 18, 2013 I have a unlocked jailbroken iPhone 4 IOS 6.1.2, I also have the pioneer appradio 2 ver 2.1.0 and have appextensions 2.0.1-42 . I have installed siri onto my phone but can't see siri on my appradio nor can i control most apps. Any help with this would be great. I want to voice get and reply if possible.. thanks in advance The Siri button will only show up and work on the 4S. any news about the dev thats updating backgrounder ??? whats the status of the update ? I'm waiting on some news about backgrounding as well. Once that happens, I can start figuring out how to get touch controls back. can someone please give me a working configuration for my devices: iPod 4G with iOS5 Appradio 2 with firmware 8.17 i have already tried newest appradioextensions from cydia with appradio version 1.8.2 and also with the newer versions. unsupported apps still do not work please help me You need AppRadio app v1.8.2 and AppEx 2.0.1-1 (Cydia). I never tested on an iPod Touch but that is the only configuration that will work on iOS 5. Maybe something else installed is conflicting with it? Link to post Share on other sites
minulshah Posted March 19, 2013 Report Share Posted March 19, 2013 Hi Mike, It seems you are genius - looks amazing! Would this work on AVH-X2500BT or other units that have App Mode? It will be my decision maker on what unit to get! Link to post Share on other sites
mikedecaro Posted March 19, 2013 Author Report Share Posted March 19, 2013 Would this work on AVH-X2500BT or other units that have App Mode? I've heard it does, though I've never personally confirmed. Link to post Share on other sites
GoGo22 Posted March 19, 2013 Report Share Posted March 19, 2013 Hey Mike, i read something about a app called FLEX. you can add patches in that app and also a patch called "backgrounding Apps never automaticly Die" did you heard about this or did you already tried that ? Maybe it could be a backgrounding replacement ? Link to post Share on other sites
fatrabitt Posted March 19, 2013 Report Share Posted March 19, 2013 Hi Mike, It seems you are genius - looks amazing! Would this work on AVH-X2500BT or other units that have App Mode? It will be my decision maker on what unit to get! Yes it will... I have the same unit!!! Link to post Share on other sites
oneyozfest182 Posted March 19, 2013 Report Share Posted March 19, 2013 Hey Mike, i read something about a app called FLEX. you can add patches in that app and also a patch called "backgrounding Apps never automaticly Die" did you heard about this or did you already tried that ? Maybe it could be a backgrounding replacement ? I think this will work similarly like "InfinityTask" but it could be worth looking into, just in case... Link to post Share on other sites
alex0ne Posted March 19, 2013 Report Share Posted March 19, 2013 Hi Mike, It seems you are genius - looks amazing! Would this work on AVH-X2500BT or other units that have App Mode? It will be my decision maker on what unit to get! I have the same HU and AppEx is working pretty good. Just the mirroring seem to be configured for the 7 inch monitor not for a 6.1 inch. The output goes a bit out of screen. I already asked Mike via twitter if there is a chance to change this in the TvOut plugin. Lets wait for his answer Link to post Share on other sites
preamble Posted March 19, 2013 Report Share Posted March 19, 2013 The Siri button appears on screen using the iPhone 5 as well. There are a host of other issues when using an iPhone 5 (such as supported apps like GMusic not scaling properly on the screen, and RDIO filling up about 1/4 of it). I've read that the HDMI adapter (required for iPhone 5 use) isn't true 1080 so that probably has something to do with it. BTW, the Gmusic app for $3 is absolutely wonderful and allows you to host up to 22,000 of your favorite songs in the cloud! Link to post Share on other sites
sgiftakis Posted March 20, 2013 Report Share Posted March 20, 2013 Gmusic is an appradio supported app? It's not in the apps section yet on the unit! Link to post Share on other sites
VBLUE42 Posted March 20, 2013 Report Share Posted March 20, 2013 Gmusic is App Radio compatible but barley. It is loaded with bugs that make it difficult to use for head unit purposes. It needs a lot of work. It is worth checking out though. Link to post Share on other sites
chino73 Posted March 20, 2013 Report Share Posted March 20, 2013 Hey Mike, since the iPhone 5 now works like the Android devices (a Bluetooth connection transmits X&Y touch coordinates from the AppRadio's touch screen to the AppRadio app running on the Phone) do you think an approach like ARLiberator is doable for the iPhone? Thanks for all your hard work! Link to post Share on other sites
terngz Posted March 21, 2013 Report Share Posted March 21, 2013 I have a question about the appradio on iPhone 4S Can I close the screen or dim the screen while i connect and use with appradio? Link to post Share on other sites
VBLUE42 Posted March 21, 2013 Report Share Posted March 21, 2013 No. Link to post Share on other sites
dasLetzte Posted March 21, 2013 Report Share Posted March 21, 2013 You need AppRadio app v1.8.2 and AppEx 2.0.1-1 (Cydia). I never tested on an iPod Touch but that is the only configuration that will work on iOS 5. Maybe something else installed is conflicting with it? Thanks for that help, unsupported apps are working again, BUT: supported apps like carmedia player or aupeo! do not work anymore. maybe the actual versions are not compatible with appradio v1.8.2, do i need older versions of these apps? Will there be a version off appradio extensions working with appradio app v2.0 for ios5? Link to post Share on other sites
