WhatIsWhatIsWhatIsWhat Posted August 1, 2015 Report Share Posted August 1, 2015 [deleted post] Quote Link to post Share on other sites
AdamOutler Posted August 2, 2015 Report Share Posted August 2, 2015 I got the image from the deck. Attached is a picture. adamoutler@adamoutler-desktop:~/Desktop/Untitled Folder 3$ fdisk -l ./fullsd.img Disk ./fullsd.img: 16.1 GB, 16130244608 bytes 128 heads, 16 sectors/track, 15383 cylinders, total 31504384 sectors Units = sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk identifier: 0x00000000 Device Boot Start End Blocks Id System ./fullsd.img1 1050624 1071103 10240 83 Linux ./fullsd.img2 1071104 1091583 10240 83 Linux ./fullsd.img3 1091584 3573759 1241088 5 Extended ./fullsd.img4 3573760 30197759 13312000 83 Linux ./fullsd.img5 1091585 1153023 30719+ 83 Linux ./fullsd.img6 1153025 1214463 30719+ 83 Linux ./fullsd.img7 1214465 2263039 524287+ 83 Linux ./fullsd.img8 2263041 2525183 131071+ 83 Linux ./fullsd.img9 2525185 3573759 524287+ 83 Linux adamoutler@adamoutler-desktop:~/Desktop/Untitled Folder 3$ upload will take a while. Quote Link to post Share on other sites
WhatIsWhatIsWhatIsWhat Posted August 2, 2015 Report Share Posted August 2, 2015 [deleted post] Quote Link to post Share on other sites
bass_rock Posted August 2, 2015 Report Share Posted August 2, 2015 As we start acquiring system images, is there a collective place we can store these for all? I tried uploading mine to mega but it kept failing. So uploading to google drive right now. Quote Link to post Share on other sites
Lucca Posted August 3, 2015 Report Share Posted August 3, 2015 Can anyone confirm is iGo license will fail after cloned sd card replacement? I'm asking about hardware identification information for iGo. This hardware id data exists only on sd card or in nor flash too? Is it possible to get SD card image with latest iGo maps from another man and write this image into my device? Will iGo licenses work with it? Course,hardware identification information for iGo exist,NNG insert its own ID on sd card as well as strict dependance of the unique SWID of the device (nor flash) and sd card S.N. So, the iGO shouldn't work with out "special" manipulations... Quote Link to post Share on other sites
WhatIsWhatIsWhatIsWhat Posted August 3, 2015 Report Share Posted August 3, 2015 [deleted post] Quote Link to post Share on other sites
ils15 Posted August 3, 2015 Report Share Posted August 3, 2015 oh guysi have a rar archive with a lot of licensesdownload it and try to useIn Brazil, we have HERE MAPS 2015 Q1, but i can't update it because i don't know how to generate update stm archive in synctools folderIGO generate a md5 and stm file to indicate files to update.if it missed, update will be failAfter use naviextra software to performe some update, the software generate two new files here the .stm file structure Quote Link to post Share on other sites
ils15 Posted August 3, 2015 Report Share Posted August 3, 2015 This *.stm-files is not license files. This files is instructions for igo with information what to copy and where to copy. *.md5-files is MD5 checksums. It was possible to use naviextras toolbox to generate this files with my own contents to upload my own contents to device, but this is useless now as we can copy files directly to device using testmode. below there are some license files for diferent gps products you can donwload and test it look for that http://www.datafilehost.com/d/4f7fdff3 Quote Link to post Share on other sites
Lucca Posted August 3, 2015 Report Share Posted August 3, 2015 It seems that you are well versed in this. Is there any chances to upload different or updated maps? Uploading new maps into internal flash isn't problem using testmode. Problem is getting licenses for this maps. Tnx Mate! To completely finish the work (to enable online services [wheather,fuel,local search & online parking]),I need the one missed license (Pioneer_NA_Connected_Services_2014_Q4.lyc).May be someone,have been updated via toolbox,can share it with me !? If so - wellcome to PM. Quote Link to post Share on other sites
AdamOutler Posted August 3, 2015 Report Share Posted August 3, 2015 I have tested USB-UART devices (FT232RL and CP2102) and USB-Ethernet adapter: <7>[ 155.086565] ehci_fsl_bus_resume begins, Host 1 <7>[ 155.098306] ehci_fsl_bus_resume ends, Host 1 <6>[ 155.358341] usb 2-1: new full speed USB device number 3 using fsl-ehci <6>[ 161.273178] usb 2-1: USB disconnect, device number 3 <7>[ 163.498318] ehci_fsl_bus_suspend begins, Host 1 <7>[ 163.498395] ehci_fsl_bus_suspend ends, Host 1 <7>[ 167.296746] ehci_fsl_bus_resume begins, Host 1 <7>[ 167.308316] ehci_fsl_bus_resume ends, Host 1 <6>[ 167.558301] usb 2-1: new full speed USB device number 4 using fsl-ehci <6>[ 170.422095] usb 2-1: USB disconnect, device number 4 <7>[ 172.618383] ehci_fsl_bus_suspend begins, Host 1 <7>[ 172.618550] ehci_fsl_bus_suspend ends, Host 1 <7>[ 202.275666] ehci_fsl_bus_resume begins, Host 1 <7>[ 202.288316] ehci_fsl_bus_resume ends, Host 1 <6>[ 202.548341] usb 2-1: new full speed USB device number 5 using fsl-ehci <6>[ 208.890184] usb 2-1: USB disconnect, device number 5 <7>[ 211.428366] ehci_fsl_bus_suspend begins, Host 1 <7>[ 211.428462] ehci_fsl_bus_suspend ends, Host 1 <7>[ 223.007508] ehci_fsl_bus_resume begins, Host 1 <7>[ 223.018323] ehci_fsl_bus_resume ends, Host 1 <6>[ 223.268310] usb 2-1: new high speed USB device number 6 using fsl-ehci <6>[ 230.009255] usb 2-1: USB disconnect, device number 6 <7>[ 232.428337] ehci_fsl_bus_suspend begins, Host 1 <7>[ 232.428364] ehci_fsl_bus_suspend ends, Host 1 <6>[ 246.524370] usb 1-1: USB disconnect, device number 2 <7>[ 249.468365] ehci_fsl_bus_suspend begins, DR <7>[ 249.468670] ehci_fsl_bus_suspend ends, DR <7>[ 251.608627] ehci_fsl_bus_resume begins, DR <7>[ 251.628292] ehci_fsl_bus_resume ends, DR <6>[ 251.878310] usb 1-1: new full speed USB device number 3 using fsl-ehci <3>[ 252.034812] usb 1-1: device v10c4 pea60 is not supported <6>[ 255.825946] usb 1-1: USB disconnect, device number 3 <7>[ 258.428354] ehci_fsl_bus_suspend begins, DR <7>[ 258.428672] ehci_fsl_bus_suspend ends, DR <7>[ 262.078712] ehci_fsl_bus_resume begins, DR <7>[ 262.098319] ehci_fsl_bus_resume ends, DR <6>[ 262.348311] usb 1-1: new high speed USB device number 4 using fsl-ehci <3>[ 262.512100] usb 1-1: device v0b95 p772b is not supported <6>[ 265.213849] usb 1-1: USB disconnect, device number 4 <7>[ 267.428406] ehci_fsl_bus_suspend begins, DR <7>[ 267.428841] ehci_fsl_bus_suspend ends, DR <7>[ 269.338706] ehci_fsl_bus_resume begins, DR <7>[ 269.358322] ehci_fsl_bus_resume ends, DR VID 10c4 PID ea60 from CP2102 VID 0b95 PID 772b from ASIX ethernet adapter Looks like this devices has no drivers. But there is no "not supported" line for FT232RL USB-UART adapter. So it supported or I do something wrong? Also I have tried to change USB OTG ID to HIGH. After this change device reboots and USB Host/Function field of USB1 (device calls USB1 = Port1 and USB2 = Port0) is changed from USB Host to USB Function. After this change, USB1 is working like slave device, it is not possible to insert and use USB-flash in this USB1. I think this can help finding USB ADB, but I do not unserstand how to connect, for example, my laptop (I need USB-male<>USB-male cable?). Also maybe I need to change debug serial setting to ON (default is OFF). update: there is not very clear scheme of work, you should select port number (0 = USB2, 1 = USB1) in submenu and then use other menus of USB test. Also I have tried to change product information. (Write product information (manual) menu). It is possible to change long 16-digit number (something like serial), but I think this product info is not affects iGo license. I changed last digit from 2 to 3 and reboot device. iGo software ID's isn't changed, licenses still working, so I revert this digit back to 2. Using copy_script.sh, get the output of 'netcfg' before and after the usb device is connected. if that doesn't work, check "ifconfig eth0", "ifconfig usb0", and "ifconfig wlan0", then change the 0's to 1s Quote Link to post Share on other sites
bass_rock Posted August 3, 2015 Report Share Posted August 3, 2015 Thank you, I'll try later. How to connect pioneer device in device (not host) mode to laptop? I must use USB-male <=> USB-male cable? Is it possible to check is pioneer's USB ADB enabled and working using USB-microUSB cable and my Samsung Galaxy Note 3 phone ? Is it possible to view usb device information from USB-OTG connection from my phone? You should be able to but you will need a USB-A to USB-A cable. I bought one but when I switch my Radio to Device mode my computer does not detect it. As for the ethernet, I have noticed the device as network drivers of some sort, have you tried connecting it and then running a scan of your network and seeing if the network lights turn on? Quote Link to post Share on other sites
Join the conversation
