blacknoi Posted July 16, 2015 Report Share Posted July 16, 2015 Well, I just took the plunge and updated. The update went fine and, so far, I notice absolutely zero difference. Boot time seems exactly the same. But, I guess it's good to be current. Would you mind confirming your GPS was reset back to factory? Also, did you have the bypass enabled before / or if not, does it still work now? I'd like to give it a try this afternoon. Quote Link to post Share on other sites
blacknoi Posted July 16, 2015 Report Share Posted July 16, 2015 IDK as I haven't tried it, but perhaps backup and restore through Naviextras Toolbox??? https://www.naviextras.com/shop/portal/p2howto-guide?guide=Toolbox&topic=Backup Interesting, never saw that toolset before. Quote Link to post Share on other sites
Pjrm68 Posted July 16, 2015 Report Share Posted July 16, 2015 Would you mind confirming your GPS was reset back to factory? Also, did you have the bypass enabled before / or if not, does it still work now? I'd like to give it a try this afternoon. I don't have GPS (it's the 4000NEX). But my bypass still works fine. Quote Link to post Share on other sites
BigCiX Posted July 16, 2015 Report Share Posted July 16, 2015 So this update can be found on the pioneer website? Quote Link to post Share on other sites
EvgaGaming Posted July 16, 2015 Report Share Posted July 16, 2015 The website states that the update is strictly for the 8000NEX. Has anyone tried it for the 4000NEX thru 7000NEX models? If so, what were the results? Quote Link to post Share on other sites
Pjrm68 Posted July 16, 2015 Report Share Posted July 16, 2015 The website states that the update is strictly for the 8000NEX. Has anyone tried it for the 4000NEX thru 7000NEX models? If so, what were the results?Actually, I'm pretty sure the update (1.09) is only for the 4000NEX. Is there one for the 8000 too? Quote Link to post Share on other sites
msooffutt Posted July 16, 2015 Author Report Share Posted July 16, 2015 The website states that the update is strictly for the 8000NEX. Has anyone tried it for the 4000NEX thru 7000NEX models? If so, what were the results? I'm not sure exactly where you read that, but when I looked up my 6000NEX, that's the firmware that shows up for it. I'm hoping to try it out later this evening. Quote Link to post Share on other sites
msooffutt Posted July 16, 2015 Author Report Share Posted July 16, 2015 Actually here is a link to pioneer's update info. http://www.pioneerelectronics.com/StaticFiles/PUSA/Car_Electronics/Firmware%20Update%20Files/NEX%20&%20SPH%20iDataLink%20Maestro%20v1.09%20&%20v1.10/1.10%20Maestro%20FW%20Update%20Letter%205000_6000_7000NEX.pdf Quote Link to post Share on other sites
jhren Posted July 16, 2015 Report Share Posted July 16, 2015 here's the current updates for NEX models: Quote Link to post Share on other sites
BAFU Posted July 17, 2015 Report Share Posted July 17, 2015 5000 device here. Update went smoothly, took about 10 minutes for the firmware and another 7/8 minutes for the BT update. So far I've noticed faster loading times when car is turned on. Also: yes it did reset my GPS settings, no biggies. Music: haven't tried it yet. Went from v1.06 to v1.10 with this update. Quote Link to post Share on other sites
DP3343 Posted July 17, 2015 Report Share Posted July 17, 2015 Did you install 1.09 or 1.10? 1.09 is the new firmware for the 4000 nex and the appradio 4. 1.10 is for the 5000-8000 nex. I have the 4000nex so I installed 1.09. They all came out on the same day. Quote Link to post Share on other sites
nolarola Posted July 17, 2015 Report Share Posted July 17, 2015 Not to be redundant, but I installed 1.09 on my 4000 and upgraded Bluetooth yesterday. I had some issues with the unit recognizing the update (after looking for the update, it would say "NO DEVICE") from my flash drive but it eventually loaded fine after two resets. Seems a bit faster to load but that's probably a placebo effect from reading this thread. Quote Link to post Share on other sites
KarNPlay Posted July 17, 2015 Report Share Posted July 17, 2015 5000 device here. Update went smoothly, took about 10 minutes for the firmware and another 7/8 minutes for the BT update. Not to be redundant, but I installed 1.09 on my 4000 and upgraded Bluetooth yesterday.How/Why are you upgrading Bluetooth separately? I assumed that following Pioneer's instructions would update the firmware and Bluetooth at the same time (or, perhaps to be more precise, sequentially). Updating my 8000 to 1.10 via an SD card went smoothly, but now I'm concerned I've missed out on a Bluetooth update. Quote Link to post Share on other sites
BAFU Posted July 17, 2015 Report Share Posted July 17, 2015 Kar: I've never assumed that the BT update will be "automatically" taken care of at the same time the Pioneer update is done. So I just do it manually to make sure. Can't hurt right? Same procedure as the firmware update except you go to the BT page and update from there. Quote Link to post Share on other sites
donmontalvo Posted July 18, 2015 Report Share Posted July 18, 2015 5000 device here. Update went smoothly, took about 10 minutes for the firmware and another 7/8 minutes for the BT update. So far I've noticed faster loading times when car is turned on. Also: yes it did reset my GPS settings, no biggies. Music: haven't tried it yet. Went from v1.06 to v1.10 with this update. OK, so I didn't lose my POIs, that was my biggest concern. Settings are easy to re-setup. Following the instructions I disconnected USB1 and USB2, then inserted the USB2 (FAT32) thumb drive into USB1. Update went smoothly, got to 1.10 within 10 minutes. I let Pioneer know that the "AVIC-7000NEX_UC_FW-Update_v1.10_20150605.zip" updater I downloaded expands to "AVIC5000NEX"...who's watching the kids over there? Don Quote Link to post Share on other sites
